Old 05-28-2009, 07:03 PM   #326
Mr.Borrie
The Sneaky F*ing Russian
Mr.Borrie's Avatar
I know something to really piss them off! MWhaahahahahahaha
760 Turbo 86|Volvo 360 cup|Volvo XC90 04|Volvo C70 C 03|Porsche 924 79|BMW 116I cup|
My Seller Feedback
Old 05-28-2009, 07:36 PM   #327
foggyjames
Ryan's spanner monkey
foggyjames's Avatar
Hey Fred...a couple of things for the first post, perhaps...
Firstly, the reversing light switch is the same as for the M45, M46 and M47. No need to buy a brand new replacement at $40+ if it breaks. I found that out after I sheared the top off my M56 one, and spent the cash...and chopped the original plug off the loom...
Secondly....no love for the Diesel M90 there ;)
cheers
James
'13 V70 D4
'89 740 Turbo Intercooler
'88 360 Turbo Intercooler
'84 360 GLT
'81 343 GLS R-Sport
'80 343 DL
'70 164 - Under Restoration
PM me if you're looking for Euro parts!
foggyjames is offline   Reply With Quote
Old 05-29-2009, 03:13 AM   #328
Turbosteen
I was born at a young age
Turbosteen's Avatar
And I said this before in another thread: Some M46 gearbox cross members are the same as the M90 one....
You can change that as well in your first post.
Philip
Project '82 760 16vT | Amazon | B204GT | Feedback |
Husqvarna Nuda 900
Turbosteen is offline   Reply With Quote
Old 05-29-2009, 06:16 AM   #329
frpe82
Guest
So M56's newer than '95 use something else, but it's ok for all years of M90?
I sometimes get the feeling volvo just makes this stuff up as they go along...
Originally Posted by JW240 View Post
yeah.... same here. first the ....645 oil was for M90/M56 etc, aka 95+. now ....645 is for everything until 1995 (M90, M46, M56 etc), and the .....745 is for everything after that date. I think someone is having a lot of fun somewhere in Sweden, changing oil specifications and other stuff "just because he can".
Both yes and no...
The 645 oil have been used for quite some time, and the first generation of M90 boxes were suppose to use that oil as well (with a manufacture date up to early/mid '96). When the second generation M90 boxes came out (and some other FWD boxes), the oil specification got changed.
The newer boxes should only use the 745 oil, and not the 645 oil.
Even though the 645 oil is for the older M90 boxes, the recommendation is to use the newer 745 oil even in the older gearboxes nowadays.
Old 05-29-2009, 06:19 AM   #330
frpe82
Guest
They don't offer any reverse light switches with original plugs for any gearbox here in Sweden now. They have been phased out. If you order a switch for an M46 or an M59 or whatever, you will still get the newest switch + a new plug and crimp connections.
Old 05-29-2009, 06:19 AM   #331
frpe82
Guest
I will do that later today if I haven't already changed it a while ago. I will have to check.
Old 05-30-2009, 12:09 PM   #332
Captain Bondo
Exklusiv Zubehör Klub
Captain Bondo's Avatar
But, it says all years of M90 right on the bottle...
-Kenny
Old 05-30-2009, 12:45 PM   #333
Mr.Borrie
Mr.Borrie's Avatar
The reversing light switch is the same as for the M45, M46 and M47.
How does that hook up anyway.. mine still doesnt work (we also redid the wiring but no worky)
Old 05-31-2009, 08:13 AM   #334
frpe82
Guest
That was probably written before the 745 oil was offered as the better oil.
Old 06-01-2009, 06:45 PM   #335
foggyjames
foggyjames's Avatar
Sure...but it means the pool of boxes you can pull an original switch from is much larger than you might otherwise think
I believe the switch grounds the feed from the lights. The ones on Ryan's 740 don't work either, so I may not be the best person to ask
cheers
James
Old 06-09-2009, 06:03 PM   #336
HansW
HansW's Avatar
Seal size drive shaft: 39.4 - 65 - 10
940 classic Cd 1997
B230FT / M90L
530 head planed, KG 2T cam
Head gasket: Elring standard (Mls 0.35 was too tight, -- piston- head contact),
1041 axle 3.74, M90
15G at 0,85 bar
3" turbo back JT-superflow
3" Amm. + 42lbs injectors
STONI chips in 984 ecu and 167 EZK
Bosch WR5 DC+ (+15)
HansW is offline   Reply With Quote
Old 06-19-2009, 11:03 AM   #337
frpe82
Guest
Updated.
Old 08-04-2009, 06:41 AM   #338
daruu
When installing the m90 in a 240, what kind of driveshaft (right word?) is best too use?
If i am not completely wrong you either have to shorten or lengthen it anyway(or make a spacer, which i want to avoid if possible), but what do you do with the mounting to the tunnel/floor(the one with the bearing inside the rubber thing)?
Make a new custom one?
Hopefully some of you understand what i mean, even though my writing isn't that good
daruu is offline   Reply With Quote
Old 08-04-2009, 01:40 PM   #339
foggyjames
foggyjames's Avatar
I would either use a standard 240 item and adjust the length, or use a 7/900 series propshaft / driveshaft (yes, it's the right word ) with this conversion: http://www.rsphysse.anu.edu.au/~amh1...ng_upgrade.htm
cheers
James
Old 08-04-2009, 05:28 PM   #340
Sander
Good news everyone!
Sander's Avatar
I made a nice comparison picture of the difference between the Redblock M90 and the Diesel M90. The one on the left is for the redblock and the one on the right is a Diesel one.
The most obvious way to recognize a Diesel one is that it's covered in inches of greasy crap and the red and whiteblock ones aren't The Diesel one also has a different driveshaft and flange. It has, just like the whiteblock M90, a round 4 bolt flange instead of a triangular shaped flange with 3 bolt holes and doesn't use a rubber hardy disk but has a normal cardan. The flanges are interchangable though. I swapped them on my M90's as I don't have a redblock varient driveshaft but do have a diesel one. It all fits and is now mounted under my car.
This is a diesel driveshaft compared to the redblock M46 one:
Old 08-05-2009, 09:51 AM   #341
SteveMD
Membro
SteveMD's Avatar
Would a flat-surfaced lh2.4 dog dish flywheel work with a M90 set-up on a redblock? See this thread http://forums.turbobricks.com/showthread.php?t=177742
Old 08-05-2009, 02:10 PM   #342
foggyjames
foggyjames's Avatar
They're just taking chunks out of the sides...? Sure, that'll work. A flat flywheel with LH2.4 timing marks and a suitable clutch would work too.
cheers
James
Old 08-05-2009, 02:14 PM   #343
SteveMD
Membro
SteveMD's Avatar
cheers
James
Yep, I like the idea of flattening the bugger as chunkifying it seems risky as John V. would point out (in length with many a 'fawk')
Old 08-05-2009, 06:47 PM   #344
foggyjames
foggyjames's Avatar
I'd be tempted to jump straight to a billet piece at that point. Isn't there that place that Fred got his from in Sweden that does them for quite sensible money?
cheers
James
Old 08-05-2009, 07:38 PM   #345
volvorsport
yeah , i just need to chase him up again foggy !!
itll be a straight replacement for a dual mass flywheel with 850 r clutch for m90 cars .
muhahhahahhhahhaha !!!!!!!!!!!!!!!!!
volvorsport is offline   Reply With Quote
Old 08-05-2009, 07:40 PM   #346
CHESH740R
lacking enthusiam
CHESH740R's Avatar
Location: England, that little island that everyone fled except me.
The Billet Flywheel for the whiteblocks is £250.68 Shipped within the UK.
I just enquired as my bank rang up and said you havent been buying any carparts for a few months.
I would imagine the Redblocks price isnt that far off.
87 745 Turbo & 88 744 Turbo & 96 945 Sport Turbo
1 RIP, 1 750R and 1 Sold Many moons ago!!!!
05 Jeep Grand Cherokee for DD Duties these days.
CHESH740R is offline   Reply With Quote
Old 08-05-2009, 07:42 PM   #347
volvorsport
really ? , thats gone up a bit .
the redblock price is a bit cheaper than that , well i suppose with shipping itll not be much cheaper than that .
Old 08-22-2009, 10:02 PM   #348
Rogue242GT
Rolling Swedish Gravitas
Rogue242GT's Avatar
Great write up
Many thanks to frpe82 for all his time and effort composing this article.
'06 Megane II DCI
'79 242 GT BW55
'91 940 SE M46 338k sold
'90 740 GLE AW71 127k sold
Inspirational 240 porn
Rogue242GT is offline   Reply With Quote
Old 08-23-2009, 10:12 AM   #349
15A
World's Oldest Brewery
15A's Avatar
I took the side of the reverse light harness off from the AW71 shifter and made an adapter. IIRC, it was the same plug end.
(this on a 90 765).
15A is offline   Reply With Quote
Old 08-23-2009, 11:04 AM   #350
Mr.Borrie
Mr.Borrie's Avatar
you dont happend to have a pic of that
