Angus242164
- Jul 5, 2004
- Victoria, Australia
I've just been doing some experimenting with some parts I've got, and I've determined that I can fit Virgo's to the 1990 740 ABS struts/hubs/brakes I've got, if I use 8mm thick wheel spacers. I will also need to grind a very small amount (~1.5mm) from the corners of the caliper brackets to stop them scuffing, but that's no big deal.
These are available aftermarket easily enough, 8mm seems to be a standard thickness, but for peace of mind I would like to use longer wheel studs, as the standard studs don't protrude through the Virgo's as much as I'd like.
I have heard that Ford studs can be used, can anybody give me info on these, eg: how much longer they are etc?
Also, the ABS hubs have the signal ring for the ABS sensors pressed on to the back of them, which look like they will interfere with removing and replacing studs. Is it hard to remove these rings? These struts/hubs/brakes are going on an '85 760 so none of the ABS components are needed.
Finally, will altering the offset this much (wheels will sit 8mm further out) on the front of the car have any impact on handling?
Any help is appreciated.
