Old 12-31-2007, 05:23 AM   #1
Poik
Backwards Turbo
Poik's Avatar
Default Poik's 1988 744ti
So, I came to Turbobricks in the beginning of 2005. I had a 1985 Volvo 745GLE that my dad bought new, and it was a piece of ****. I didn't really care, it was my daily driver and I already had a cool car. But it was slower than balls and I wanted to turbocharge it. After prowling and searching for a few months I made my prerequisite first newbie post asking if I was missing anything about turbocharging my car.
I was originally turned onto the idea of a turbo brick when I saw grebnut's 744ti (http://www.turbobricks.com/forums/sh...ad.php?t=50476) at Pacific Raceways on opening day of 2005. I went over and checked it out before racing started, and it was badass. When racing started, my first run happened to be against the very car. My clutch blew up that day at the track, but he stuck with me until I hit about 3rd gear, and I was like "OMG this isn't happening." That was impressive, and I knew I wanted to have a quick Volvo.
So I started looking for a parts car to grab all the turbo parts off of, and I found an '88 744ti on craigslist just a couple miles away from my house. The guy was asking $500, but I snaked it for $300 because I am a business man. The guy thought it had some serious problem, turns out the 90º elbow from the throttle body to the cold side intercooler pipe was disconnected. It also had a kind of busted up front right corner, he said his friend backed into him. So the hood was crunched up a little and the headlight support metal was pushed in. It had some starting problems as well, which I finally tracked down to something involving the factory Volvo alarm system. I remedied this by installing a push button start button. Here's the original thread:
http://www.turbobricks.com/forums/sh...ad.php?t=39243
Here's how the car looked when I got it:
So I bent the crunched up metal enough to get some headlights on there, and aligned the hood latch enough so that I didn't have to use a crowbar to open the mangled hood. Then I washed it.
The hood would always get stuck closed, so I ended up just putting hood pins on it. Two of the dracos on the car were bent, so I got one on turbobricks, and found a Sirius wheel at the junkyard that I threw on the front right. I also put on a K&N air filter and a Turbo-XS BOV. Also I put an MBC on and set the boost to 12psi, it was fun. And then I got a straight hood from the junkyard and painted it super dooper flat black (bad idea). It was basically a chalkboard, and since that day it was never washed.
I drove it like that for awhile, and then I got a crush bent downpipe and 3" exhaust that dumps before the axle for about $190 with a 3" Magnaflow muffler. cheap cheap. But then my clutch ate it.
So I put a Clutchnet 4-puck in using my stock pressure plate. This was the first transmission swap I had ever done. James (945ti) helped me out a ton (thanks again). At the same time I purchased MegaSquirt to put in it, this was February 2006. I didn't end up putting the MS box in it, because a month later I got an AQ171c, decided my 744 was not worthy, and then in another month I had an '84 242t that I alloted MS to. And this is largely how the car stayed for awhile. It would run consistent 15.2s at 90mph and I thought that was pretty neat for the amount of money I had into the car.
So sometime after that I got the open differential welded up, and I have loved it ever since. In February of 2007 I bought an ebay intercooler for $90 shipped, and put that in. Wished I would have done it sooner, as it improved my 1/4 mile trap speed by 2mph, with a best of 15.04 @ 92.17. Around the same time I finally found a 601 red 740 at the yard that I took the hood from. Also by this time I had found another draco, so I had all matching wheels (even tires), and matching paint! It was a large breakthrough.
Over the course of my ownership of the car I had been amassing performance parts. I got a 90+, but couldn't put it on because it was a TD05 and people told me it didn't work. I bought a turbocharger for a pretty good deal, an IPD turbo cam when they had a sale, some various other little things.
I drive my car hard by the way. Really hard, like shifting the M46 as fast as possible and being sideways as much as possible. The only thing I managed to break was a torque rod and my overdrive. But by this time my engine had developed a laughable amount of piston slap, when cold, when hot, whenever. But I outsmarted the car, and got a complete 1993 B230F L-block for $150. This is how it looked when I got it on the stand:
I stripped it down, pressure washed it, wire wheeled it, acetoned it, and then painted it Chrysler Red.
It looks really orange under the 500w halogen light, but in natural light it looks very Redblock red.
I've always liked the way the 90+ rear bumpers look because they are a little skinnier and don't have the crazy accordian things, and the front bumper on the 90+ cars is way more aerodynamic than the swiss cheese lower "air dam" that I had on the car, so I snagged a pair from the junkyard. I dyed the rear bumper with Forever Black, which worked pretty well. I ran out of sunny days to do the front bumper, so it still looks horrible. I also tinted my rear tail lights because I was feeling frisky.
So one day in October I was driving to Seattle early in the morning from Bellingham to go to work. I got on the freeway and everything was great. I drove for about 30 miles, and then I went to pass someone and the car didn't, um, go... I got off the freeway and drove around a few blocks. Yeah, no more turbo spooling noises, no more blow off valve, the turbo had frozen up. The power felt exactly the same up to about 3k, and even if I floored it in neutral it wouldn't rev over 4.2k or so. So I drove it like that for another 2 weeks or so, and then it was time. After 232k miles, on Thanksgiving weekend, the B230FT came out of my car.
My best friend Alec and I with the tired engine.
While the engine was out I took the time to clean the engine bay. When the car went back together I really didn't want anything dirty to go back on the car. So I hooked up my pressure washer to the hot water in the house, and gave the engine bay a bath a few times, with degreaser in between. It worked pretty well I thought.
I also cleaned up the parts that were going to go on the engine:
Then I spent a lot of time porting and polishing the 530 head that I was going to use on this engine. Mainly for practice, but I was very pleased with the results. I posted a thread in showroom, and here are a few pictures as well:
http://www.turbobricks.com/forums/sh...d.php?t=119733
Then I got some M10xM8 transition studs so that I could mount my Volvo TD05 turbine housing to the 90+ manifold that I ported. The housing is a Volvo unit that I got from thelostart of, but it has been machined out for the larger TD05H wheel, and ported a ton. The turbo is an EVO III 16g6. That means it is a little bigger than a "Big" 16g and has an inconel turbine wheel, which is lighter and better for heat. Here are some pictures of it on the 90+:
And then it was time to start putting everything together:
I used turbo exhaust valves that I got from John (The Aspirator) in the 530 head that came on my B230F.
New exhaust studs:
And in she goes:
I also installed an e-fan (from a Dodge Spirit), knocksense, and an oil pressure gauge.
On my first attempt to start the car, it started right up, I was very, very happy. Everything sounded normal, but there was a pretty bad oil leak coming from the exhaust side. I thought that it must be the o-ring that seals the oil filter relocation arm, so I got one of those at the dealer the next day and replaced it. That is one thing that is a lot easier to do while on the engine stand
Yesterday, the 29th of December, 2007, it was time to take the car for a test drive. At first we didn't make it very far though...
Enter Super-Truck!
It's been raining so much lately that the back yard is pretty much a swamp, but we were able to tow it out backwards and up to the street.
And here's me posing for the camera, excited to drive the car:
And a short blurry night time teaser video of the car:
The way it drives right now is not very impressive. If you're just putting around town it's ok, if you are above 3.5k and you floor it, it hauls ass, but the knock light blinks pretty often. The boost is set at 9psi right now, and it is definitely faster than it was before above 3k. Under 3k the turbo spools and the car just doesn't go, it's weird, it's LH2.2 for ya.
So, now that it runs, my list of things to do has grown a lot smaller. I have a set of 46lb CFI injectors that I need to have cleaned and flow tested, and then the next thing I need to do is make an adapter box for installing MS, and after that I need to spend awhile tuning it. I'll also get a methanol injection setup relatively soon. And after that, it's dyno time. I really am going to need a Getrag or something pretty soon as well.
Well, there's the history of my 744, I left out the boring parts. Comments and constructive criticisms welcome.
Even more pictures of the project are in this album:
http://eric-o.com/gallery2/main.php?g2_itemId=3021
Thanks for looking,
- Eric
Eric Olsson's 242 Turbo | 245 DL | 744 Turbo
Poik is offline   Reply With Quote
Old 12-31-2007, 05:33 AM   #2
adrianpike
adrianpike's Avatar
Note the third gear scratch of woot.
I'm looking to buy, PM me if you've got any of it: LS bits, 93 850 bumper, ford 8.8", T5 WC, T56, Mustang IRS
Adrian is omniscient, you will never escape his wrath. - 500dollar744ti
doug was here
adrianpike is offline   Reply With Quote
Old 12-31-2007, 05:52 AM   #3
Disco Inferno
Disco Inferno's Avatar
That's very nice work. Interesting you blame LH 2.2 for the gutlessness under 3000rpm, my car does the same thing... No nice linear acceleration to be had, did it with the T cam, still does it with iPd powah.
So I guess a broader powerband is one more thing to look forward to when I go Haltech. Still can't justify how much I plan to spend on that silly business.
Originally Posted by badvlvo View Post
Oh look, a tire review on TB. In true TB fashion it's about used tires. Used Chinese tires.
Duuuuddee.....weed snot a drug
____caligamerbong___--''"
Originally Posted by coonmanx View Post
I'm going with Windows 9.
Disco Inferno is offline   Reply With Quote
Old 12-31-2007, 01:21 PM   #4
buzz
To inspamity, and beyond!
buzz's Avatar
Kickin' ass bro!
Originally Posted by Råda View Post
I usually don't get compliments on my penis from guys, but thanks!
I used to be indecisive. Now I'm not so sure.
The Phoenix
buzz is offline   Reply With Quote
Old 12-31-2007, 02:05 PM   #5
500dollar744ti
still rides with MrDoug
500dollar744ti's Avatar
my lh2.2 had tons of balls under 3000rpm but only when it wasn't off melting my pistons did i get to enjoy so much of that... ms ftw
and NOICE port work there buddy, i wish i had the time and patience to work it like that.
-Matt
1989 Volvo 744T- 16v turbo, '94 FD-block, RSI pistons/rods, GT35R, Tial 38mm, RFL, MSnS-E, DSM spark, 100lb Delphis, 4.6 springs, Bondo header, Heebspeed intake, Q45 90mm TB, Bosch 044 FP, 12x24x3 ebayIC, w/c t5, Clutchnet 4puck/PP, 4.10 G80, IPD sways, 960 brakes.
1998 Volvo S70 T5m- Stock, 229k
1998 Jeep Cherokee XJ- Stock, 154k
1983 Ford F150- '89 5.0 H.O, C6/4x4, F+R LSD 4.10, 7" lift, 35s.
1990 Cobia San Marino 225 ECS- MCM 350 Mag, GM Bowtie Intake, HR-Titan 19p.
500dollar744ti is offline   Reply With Quote
Old 12-31-2007, 02:38 PM   #6
stylngle2003
stylngle2003's Avatar
nice thread man. that IC pipe you have in the pic of the engine going in the car is freakin sweet. what's it from?
-Billy
Volvoless for the first time since 1990...
2002 Toyota Avalon XLS (comfy gradma car)
1996 Chevrolet Tahoe LS 2WD (hauls ass)
1990 Mazda Miata (track toy)
stylngle2003 is offline   Reply With Quote
Old 12-31-2007, 02:55 PM   #7
shaved240
shaved240's Avatar
so what did the car run?
1979 242 Turbo: b230f+16v, Holset HX40, Getrag
1990 745 Turbo: Ipd Bars, Bilsteins, BBS Wheels
2001.5 S4 Avant: Stock for now.
1988 244: b230f+t, M46:PARTED
1995 960: SOLD
1994 945: SOLD
on the hunt for the elusive zf diff.
Originally Posted by jungledorifuto View Post
ship me that m46 for 40 bucks and im game
shaved240 is offline   Reply With Quote
Old 12-31-2007, 09:19 PM   #8
Poik
Backwards Turbo
Poik's Avatar
Thanks for the compliments guys! I forgot to mention that I also put IPD 25/25 sway bars on the car, and I used a Cometic MLS gasket from RSI on the new engine. I used .040" thickness to give me .032" squish. My LC-1 is being weird, it works with the engine off, but when I have the engine running it won't talk to the laptop. It was working before, I'm going to try changing the grounds and seeing if that helps out.
That is a "j-pipe" for a 1g (I think) DSM when they convert to a front mount intercooler. It bolts onto the 16g housing, I had to cut it to make it work though.
What do you mean, price wise..?
Tomorrow I don't have to work, so I will try to get some more (and better) footage.
Old 01-08-2008, 07:11 PM   #9
Poik
Backwards Turbo
Poik's Avatar
Today I got around to installing my ebay catch can. Oily residue in my brand new turbo and motor be gone! I used a hammer to round the corners on the mount that came with the kit, and then I was able to just tap it into the opening that is on the insides of the strut towers. I know, good idea right?
Basically the car hauls ass above 4k. At 4k it just comes on and pulls HARD. I floored it in 4th gear the other day starting at 3k rpm, turbo spooled instantly, but the car barely accelerated until it hit 4k and just took off and started pulling harder and harder. The knock light didn't even blink when I did that, but it will always blink in gears 1-3. Hopefully tuning and more boost will get rid of most of the dead spot!
Old 01-11-2008, 12:11 AM   #10
dbh86
What's a 16V?
dbh86's Avatar
Can you come clean my engine bay so it looks like yours???
'07 MS6 - DD/DSP of doom
'92 245 - Eternal Project
Incidentally, if we're going to follow this other train of thought, you should install your spare tire while the vehicle is cruising at 55mph, since that's about where it'll be used most often.
dbh86 is offline   Reply With Quote
Old 01-11-2008, 01:29 AM   #11
GrandmaSideways
AW71AW71AW71 AW71AW71AW71
Probably used the time the engine was out to do a good long wax and polish.
GrandmaSideways is offline   Reply With Quote
Old 01-11-2008, 02:41 PM   #12
dbh86
What's a 16V?
dbh86's Avatar
Needs more Sequential COP and MOAR VALVES!!!!
Old 01-11-2008, 03:01 PM   #13
Mark
sex lights
Mark's Avatar
Looks great Eric! I can't believe that's the same engine bay.
I'll miss the "slap slap slap slap" sound of the old motor idling though...
M.
Originally Posted by Double02 View Post
Classic TBricks - pages of discussion debating whether or not to spend $20. On a tractor.
Incorrect, the Frigidaire is Mark's 86 745. It's in appliance white and it is Best Car.
The Fridge; '86 745 DD-with full '94 LH2.4 swap. Now with M90!
2000 AMG E55 wagon.
'78 Honda GL1000- naked Goldwing.
'76 265 wagon with Megasquirted 350 chevy and T56. Scrapped
Mark is offline   Reply With Quote
Old 01-11-2008, 04:15 PM   #14
GrandmaSideways
haha I loved that. Sounded like it was about to throw a rod.
Quite frankly you should have made it do it the last day, haha.
Old 01-11-2008, 04:17 PM   #15
Tick
ASSFACEHOLE
Tick's Avatar
Nice project. In fact I may be copying the 90 bumper as an alternative to fixing my fog lights since I have one hanging in my rafters.
67' 220
84' Honda sabre v65
85' Ford Econoline E350 Box Van
90' 740 16v
90' 740 turbo (parts)
00' xc70
Originally Posted by Disco Inferno View Post
**** you, filthy ****ing non-smoker. I hate your type, and when I see you coming I intentionally exhale strongly in your direction.
Tick is offline   Reply With Quote
Old 01-11-2008, 05:07 PM   #16
Poik
Backwards Turbo
Poik's Avatar
For a price
Actually the pressure washer and degreaser did all that. There are still a few spots that I could touch up by hand though.
M.
Yes, and the plume of burning oil. She shall be missed...
If I could've blown the motor up in one last glory run, I would have, but since the turbo went first, I didn't really have the power necessary to do that.
You might already know, but you'll need to have the 90+ bumper shocks as well. Also the sheetmetal is different on the 89-, so for the sides you will probably have to drill some holes in the metal to move the side mounts around, or use bolts, whatever. I just have the slide mount things in the stock location, with only one bolt attached to allow it to pivot. It's alright, but when I take the bumper off to make it black, I'll put it back on better so that it lines up on the side. You will also have to spacer your headlights out a bit because of the curved shape of the bumper.
Here are some pictures I took today of the methanol injection system that I installed yesterday. First I took the windsheild washer reservoir out and cleaned it inside and out, cleaned the filter, and got any gunk out of the inside. Then I drilled a hole in the back of it to put in the fitting for the feed of the methanol pump. I mounted the pump next to the reservoir on the passenger side with some self tapping screws:
Then I took the cold side pipe off and drilled it for the nozzle. I'm using an M5 nozzle which is ~374cc/min at 150psi, which is a little on the high side for the power I am running right now, but should be about right when I get the bigger injectors installed and double the boost. There is also a check valve right before the nozzle, so that water/methanol does not get sucked into the engine when not boosting, and also to stop boost pressure from pushing the water/methanol back through the pump.
Old 01-12-2008, 08:30 PM   #17
dbh86
What's a 16V?
dbh86's Avatar
Trade a set of ITB's for a cleaned engine bay?
Old 01-17-2008, 11:06 PM   #18
Poik
Backwards Turbo
Poik's Avatar
So the other day when I was testing out my methanol injection, I floored it in 2nd, no knock, let off, and then my muffler fell off when I was going about 45. Grrr. This was among many other bad things that happened to me on Monday. Anyways, today I went up to John Lane's and he helped me fix my exhaust up. I didn't bring my camera, probably should have, but I did take 2 crappy camera phone pictures! We added a 3" Dynomax ultra-flow bullet muffler, as well as brought the exhaust up and over the axle, and put the 3" Magnaflow chambered muffler (the one that fell off) at the back. It turned out really well, and it only took about 2 hours to do. Thanks a bunch John!
Here is the Dynomax bullet that starts the incline over the axle:
And here is the view of the back:
Yeah, I need to get the factory hanger installed. Right after I find it.
Old 01-30-2008, 03:09 AM   #19
Poik
Backwards Turbo
Poik's Avatar
Today I made the harness to adapt LH2.2 to the MSnS connector by following 500dollar744ti's article:
I still need to finish a couple things on my MS box, and then I can rip out the EZK box to do the jumpering. After that it's go time. Most likely that will happen next week though.
Old 01-30-2008, 12:25 PM   #20
Alex Buchka
8 cylinders
Alex Buchka's Avatar
Looks awesome man, you'll be megasquirting down the street in no time.
Alex Buchka is offline   Reply With Quote
Old 01-30-2008, 01:18 PM   #21
amargill19?
Barry McCockiner
amargill19?'s Avatar
loooookin' goood bud!
now who are you going to face off against in the ol' mission raceway drag grudges now that John is in the east?
think you'll have enough power to take me on? Hope you can pump 28psi into that bitch! muahahahahahahah!!1
Originally Posted by Dan Wood View Post
Now, two years later, after a move to Oklahoma, a job in a potato salad plant, and many other assorted ventures, I have plans to visit Paraguay.
amargill19? is offline   Reply With Quote
Old 01-30-2008, 06:14 PM   #22
Poik
Backwards Turbo
Poik's Avatar
Yeah I think I scared away the last of the competition. Looks like it's smooth sailing from here on out.
Old 01-30-2008, 06:45 PM   #23
amargill19?
Barry McCockiner
apparently you don't want to mess with 240 powwah either huh?
Old 01-30-2008, 06:55 PM   #24
dbh86
What's a 16V?
dbh86's Avatar
Do I need to bring my 240 up there?
Old 02-01-2008, 09:37 PM   #25
Poik
Backwards Turbo
Poik's Avatar
The hose clamps were very tbricks, but they had to go. Here's what I came up with today:
No more rattles, so I am pleased.
