I just got a '95 964 and I have a few questions about them.
The PO said it had a bad carrier bearing and that it makes noise when it gets hot. I haven't driven it enough to hear it and confirm it, but I'm assuming I have to change the diff assembly, or R&R and rebuild it. How hard is it to pull on a 960 with a transverse fiberglass leaf? Are there different rear end ratios on these cars, or are they all the same?
The driver's inside door handle works but it flops loose. I haven't taken it apart to look but I assume the return spring is broken or something like that. Is there an easy fix and do they get worse over time or is it OK to ignore?
