Old 06-05-2016, 02:39 PM   #1
Sine Qua Non
American Psycho
Sine Qua Non's Avatar
Default 1974 144 wires
https://www.flickr.com/photos/141499.../shares/v608Wu
I made my question inside each photo.
Cross posted.
Can anyone help with this? Mostly wires at this point and one hose connection.
Thanks
Crush them all!
Sine Qua Non is offline   Reply With Quote
Old 06-05-2016, 02:41 PM   #2
- Stock PSI Or Bust -
This content is currently unavailable
The page you requested cannot be displayed right now. It may be temporarily unavailable, the link you clicked on may have expired, or you may not have permission to view this page.
how psi stock cna sprout?
Old 06-05-2016, 03:45 PM   #3
Sine Qua Non
American Psycho
Sent you an e-mail.
Old 06-05-2016, 05:17 PM   #4
Sine Qua Non
American Psycho
Fixed with flicker attachment
Old 06-05-2016, 05:59 PM   #5
sksmith
sksmith's Avatar
First picture is the power junction block. The hot from the alternator and a hot of the battery run to it. I don't recall the others, maybe the headlights?
There's another pic with the block. It has 2 red wires & 3 phillips head screws. This goes with the pieces in the first picture.
You have a mess on your hands. If nothing was labeled, you really need to get abold of a 74 Greenbook for a good wiring diagram, and start tracing wires down.
Good luck,
Steve
Old 06-05-2016, 06:04 PM   #6
Sine Qua Non
American Psycho
Good luck,
Steve
Yeah, it was a mess.
Old 06-05-2016, 06:06 PM   #7
Sine Qua Non
American Psycho
Good luck,
Steve
I have Greenbooks and parts catalog but the wiring diagram in it is not readable to me. The owner passed away while having the engine rebuilt. It's been a long road getting it all back into the car. The end is near and it involves these wires.
Old 06-05-2016, 08:16 PM   #8
The Librarian
I'll do my best to help with the limited information given.
This harness connects to the throttle switch and the EGR solenoid. The pins on the solenoid look bent, so you'll need to straighten them. The ground wire for the throttle switch goes to one of the bolts on the bracket.
These two wires go to the coil. Red to +, black to -. They're for the Pertonix electronic ignition.
I'm fairly sure that the brown and black wires connect to the thermal timer. Check continuity between the brown wire and the brown wire connected to the cold start valve. Do the same for the black wires. If they have continuity, connect them to the thermal timer. Black wire to terminal W, brown wire to terminal G. The letters are cast into the plastic on the thermal timer. You'll need an insulator and the correct terminals which I can provide.
This thing is an insulator that holds the main battery junction to the inner fender. Be careful, the top piece breaks easily and is NLA. If it breaks and the junction touches something grounded, sparks will fly.
The wires from the voltage regulator go to the alternator. Black to one of the alternator case studs, green to the field connector on the brushes and red to the D+64 terminal.
This is the reverse light and seat belt reminder switch. It screw into the side of the M40/41 transmission top cover.
That is the barb for the booster. You have the booster connected to the ported fitting for the breather cap hose.
I'll need more info to help with the other wires.
