Old 04-27-2021, 09:19 PM   #1
VolvoGuy123
VolvoGuy123's Avatar
Default Will these (wheels) tires fit?
I recently installed a set of 18" Eikers with 225/40/18's. Now they are fine but would like alittle more meat in width and height which I have the room for except for the strut perch clearance. (*see pictures) So, now I'm switching to my other set of 18" (X 8.5" wide) Ocean MK18's (with 245/40/18's?) These are a tad bigger in diameter but the tires I believe might just fit (up front.) The rears I'm not as concerned with as we all know there is more room back there. Any opinions or experiences are most welcomed and appreciated!
VolvoGuy123 is offline   Reply With Quote
Old 04-27-2021, 09:35 PM   #2
2turbotoys
Salaminizer
2turbotoys's Avatar
https://www.willtheyfit.com/
1978 242, 5.3 L33
1979 242, MS, R brakes
2006 V50 T5 AWD @ 17 PSI
Old 04-27-2021, 09:42 PM   #3
Jack
junkman
Jack's Avatar
The pictures need to be life sized to figure this out
I love you even more Jack.
Old 04-27-2021, 10:13 PM   #4
VolvoGuy123
See, I have been using that but it's so close that even a change in brand name of tire might make the difference. I need someone who has done this setup (or similar) before to shed some insight. I appreciate the response tho, thank you.
Old 04-27-2021, 10:17 PM   #5
VolvoGuy123
Well, close. lol. And you aren't wrong, pictures really don't do it justice. I'm probably going to serve as an example one way or another and just buy the tires, cross my fingers and report back to you guys. Atleast this way I can help those in the future with similar fitment issues. Thanks btw, I appreciate your response.
Old 04-28-2021, 10:29 AM   #6
Acke
Acke's Avatar
I'm guessing they'll rub the inner fenders at least. I have been trying out 17x8,5" ET13 super DTMs with 215/45-17 and 225/45-17 and so far it seems they are going to rub a bit (during suspension compressing). Haven't been able to test drive yet since the motor is out atm...
Acke is offline   Reply With Quote
Old 04-28-2021, 10:55 AM   #7
RvolvoR
245/40-17s are pretty much the max you can do without some pain in the ass work. So going to a 245/40-18 will be a bit of a chore without starting to cut stuff up.
Old 04-29-2021, 05:28 PM   #8
VolvoGuy123
Well, I do have a few advantages most do not. My car is only lowered 1.5" or so, my fenders are already rolled and u have (air-lift) bags in the rear springs (to adjust height a bit) and for more stability while going sideways! LoL! Plus I have a set or two of H@R spacers in a more extreme measure. But I'd rather them just bolt up normally. I guess we will see soon enough. Thanks yall!
