#1 | |
![]() The list goes on with my freshly rebuilt 5.0L swap.
No temp gauge. Fixed No cooling fans. Fixed Starter electrical (ground). Fixed Now there is a host of idiot lights on the dash. Charge light. Brake failure, E-brake, and lamp failure lights are all on. The new Napa alternator isn’t charging. So I get the Charge light. Are all the others supposed to come on when there is an alternator failure? Or is the wiring just half-assed. surprised the previous owner had zero troubles with it.
#2 |
![]() Those are always on with the key in the run position until you start the car and the alternator starts charging. Totally normal. Is the alternator properly grounded?
#3 |
junkman
![]() Rebuild the engine again
#4 | |
![]() Quote:
Will have to rework the wiring... |
#5 |
![]() Make sure the alternator is properly grounded to the block.
Trying to understand stupid people is like trying to pick up a turd by the clean end. |
#6 |
![]() The Napa reman failed after 30min... they refunded my money. Going with an ACDelco.
So... during a charge failure. Why are the brake/light failure idiot lights being engaged? Is there some wiring I need to refurbish? Last edited by BeaverMeat; 05-01-2021 at 03:22 AM.. |
#7 |
![]() It's completely normal on any car of that era for lots of the dashboard lights to turn on when the alternator isn't working. This is used as a bulb check before starting the car. If the alternator goes slightly bad, the Alt light will come on by itself while running. If the alternator goes completely bad, or the belt breaks, you get a light show.
#8 |
![]() Makes sense. Haven’t driven a car this old since high school... I haven’t drove this car for 6 months
Thread Tools | |
Display Modes | |
