Old 02-08-2022, 03:50 PM   #1
dandeluca
Default Correct throwout bearing for M46?
I need to replace the throwout bearing for the M46 I am swapping into my 91 245 auto.
I see the Sachs SN3727 from FCP Euro. Is the the correct part. It looks a little different from the bearing I pulled off.
Here is the set up on the M46 I purchased a new fork, but it matches what is pictured here.
Thanks for your help
dandeluca is offline   Reply With Quote
Old 02-08-2022, 03:57 PM   #2
The Librarian
Throw out bearings are different for Sachs and Borg & Beck clutches. The bearing pictured is for a Borg & Beck clutch.
https://vp-autoparts.com/en/artiklar...1_b23-67-.html
Old 02-08-2022, 04:00 PM   #3
Old and boxy but good.
You need the one that the bearing slides onto the locating pins in the release arm. https://www.fcpeuro.com/products/vol...40-760-3549881
That is correct one in the picture.
Old 02-08-2022, 05:40 PM   #4
dandeluca
I have this Luk clutch and pressure plate. They are in like new condition and I figured I would use them.
I understand these are similar/the same as the Sachs clutch.
That seems to be the same one in my FCP cart, inching closer to putting the new transmission up....
Old 02-08-2022, 07:43 PM   #5
spock345
spock345's Avatar
I learned that the hard way. The clutch just refused to work correctly until I figured out there were two versions.
1998 S70, grandma-mobile
Old 02-08-2022, 08:21 PM   #6
dandeluca
I do not believe my previous message was clear. Can anyone confirm that the Sachs style throw out bearing will work with the Luk clutch?
Old 02-08-2022, 08:26 PM   #7
The Librarian
It sure looks like the Sachs style bearing.
Old 02-08-2022, 08:40 PM   #8
2turbotoys
Salaminizer
2turbotoys's Avatar
There are also 2 different pilot bearings for the M46, found that out the hard way.
1978 242, 5.3 L33
1979 242, MS, R brakes
2006 V50 T5 AWD @ 17 PSI
Old 02-08-2022, 09:06 PM   #9
dandeluca
Just when I thought I had it figured out
How do I know what pilot bearing to order?
Old 02-08-2022, 09:17 PM   #10
2turbotoys
Salaminizer
2turbotoys's Avatar
Buy both, they are cheap. The one I ended up with also fit a Mustang of some sort. Been too long since I did it to remember. I actually had to cut the old one out, it was so beat up and missing bearings.
Old 02-08-2022, 11:26 PM   #11
VolvoLatAm
what would happen during operation?
VolvoLatAm is offline   Reply With Quote
Old 02-08-2022, 11:27 PM   #12
VolvoLatAm
did the bearing simply not fit or did something else happen?
Old 02-09-2022, 03:13 PM   #13
Use the 6202 RS bearing for the pilot bearing. Yes, the Sachs release bearing works with the LUK pressure plate. That is what I have in my 93 wagon.
Old 02-09-2022, 03:46 PM   #14
spock345
spock345's Avatar
Depending on the combination of the mismatched clutch and throwout bearings the clutch would either not disengage all the way when the pedal was pressed or it would slip all the time. I wasn't able to adjust the clutch arm and slave cylinder to make it work right. Then I figured out I had the wrong throwout bearing for the clutch I was using.
