Old 02-27-2022, 03:43 PM   #1
durk80
durk80's Avatar
Default Does the position of ATE caliper pistons matter?
Taking apart the rear ATE pistons and replacing the seals. Does the position of the piston matter? The top edge of the piston that presses the brake pads together is not flat all the way around.
durk80 is offline   Reply With Quote
Old 02-27-2022, 03:51 PM   #2
tintintin
Yes, to properly set the pad toe-in, for avoiding chatter. Template should be widely available.
Old 02-27-2022, 04:56 PM   #3
The Librarian
There's a tool to rotate the piston and one to align it. Let me know if you would like to rent them.
http://hiperformanceautoservice.com/...9992919jpg.jpg
Old 02-27-2022, 05:51 PM   #4
MasterBlaster
MasterBlaster's Avatar
Missed that actual angle (20°) , if you want to "wing it" without the tool.
Basically, the "open" part of the piston is at the leading edge (bottom) of the pad, greeting the rotor as it rises up to meet it. (I assume) that counterbalances the pad's tendency to slightly rotate and "dig in" at the leading edge, keeping the wear even across the pad's surface.
1990 740GL
536,000 km so far...
Old 03-03-2022, 12:37 PM   #5
shoestring
shoestring's Avatar
If you got the Ate seal kit, it's in the instructions. It's very simple.
