#501 | |
![]() Quote:
Thanks for all the advice and support in this thread!
1988 745T http://forums.turbobricks.com/showthread.php?t=356096 1972 142S http://www.turbobricks.com/forums/sh...d.php?t=311926 1991 780 Sold 1979 244DL Sold 1986 740+T Sold 1983 242T Sold |
#502 |
![]() I also just raised my front end up about an inch and the rear 3/8". It's SO much more enjoyable to drive. I think our cars were at a similar height before.
#503 |
![]() Happy to hear that you've decided to hold on to it. Every time I see this car it makes me want a 140 that much more.
#504 |
![]() Where is the best place to mount a Malpassi Fuel Pressure Regulator on a 140? Inquiring minds want to know...
#505 | |
![]() Quote:
Will this spot work? I know it should be kept away from heat (ie the headers) but this side of the engine bay is so much less crowded. Anyone with some experience doing something similar? ![]() |
#506 |
The Librarian
![]() This is from Skandix's site.
![]() I don't like how far the fuel lines need to be run to put it there. I'd try to mount it to the lip on the firewall (or bend the bracket 90° and bolt it thru the firewall). That will keep the lines nice and short. |
#507 | |
![]() Quote:
When I plumbed it in the fuel pressure was at like 6psi. I backed it down to 3 (the lower limit with the spring that came with the Fuel King) later today I will readjust the idle mixture/speed and jets and possibly the main jets too. I feel like an idiot for not doing this sooner. I bet it solves all the little nagging issues with the car. When I first installed the Weber I read that the fuel pressure should be between 2.5 and 3PSI but thought that didn't apply to me. The car has run fine after a lot of fiddling around but the idle was still a little high no matter what size jet I put in the idle circuit. |
#508 |
#509 |
![]() That fuel line draped over the exhaust manifold makes me nervous.
#510 |
![]() I hear what you are saying but that photo is a little misleading. It really wasn’t that close to the manifold. After cars and coffee today I spun the fuel line holder bracket around so it was pointed to the fan not the carb.
#511 |
![]() Once the engine cools down I am going to move the line under the radiator hose and back into its repositioned holder
![]() Last edited by Coupid; 01-22-2018 at 01:54 AM.. Reason: final photo |
#512 |
![]() Your car is begging for dual Webers. Ditch that single downdraft, it limits power and dual Webers aren't complicated to tune.
Ian, why does the length of the fuel line matter ? Is it a safety issue or does it affect the fuel pressure/flow at all ? |
#513 |
#514 | |
The Librarian
![]() Quote:
The shorter the lines, the less chance for chafing and less chance for heat to be absorbed. |
#515 | |
![]() Quote:
Gotcha, that makes sense. |
#516 |
![]() Don't think I havent been watching that for sale thread intently. It's a great deal but still hard to justify spending that much on carbs when the current weber does the job just fine.
#517 | |
![]() Quote:
My first Amazon had your set up, it worked fine since the car was just used in town. Then I moved to AZ, got stupid and wanted more and I haven't looked back. |
#518 | |
![]() Quote:
#519 |
![]() My box from VP Autoparts showed up yesterday!
![]() It includes new upper and lower control arm bushings, ball joints, tie rod kit, lower control arm bolts and idler arm bushing. While I'm at it I will swap the front springs to 5x9.5 800lbs to raise up the front end. I went to the garage to open the box and take inventory with no intention of working on the car. Two hours later... ![]() Can't wait to see how the car drives when it is all back together! |
#520 |
Keep it clean...
![]() Heck yeah! That’ll make a nice difference.
Derek 1 Owner - 85k mile 1980 242 Recaro LX Bs - 16" ARE 398s - 25/25 Sway Bars - Bilstein HDs - SuperPro Poly/STS Derlin Bushings - MSD - R Sport Wheel -Project Thread- Follow on IG: @vol242vo |
#521 |
![]() Nice improvement for sure. I like VP's stuff, there's no drama involved.
#522 |
![]() VP is top-notch (as are Eric & Ian!).
Mattias at VP is very good to deal with. I still have in-laws in Charleston, so I usually plan a pick-up around trips down there. Sure saved on shipping when I picked up my upholstery and exhaust system. |
#523 |
![]() Good god, whats the trick for getting these lower ball joints off? They are stamped "Volvo" and might be original. They don't want to leave their home no matter what I do with the loaner ball joint press from Orielly's.
#524 |
The Librarian
![]() Hold the A arm by the end with the bushings and slam the ball joint stud onto a steel table, vice anvil or something similarly hard a few times until it pops out. This might be difficult if the stud is really floppy.
#525 |
![]() there's something I hadn't thought of doing. Now to find an anvil!
