Old 01-12-2018, 10:05 PM   #1
57plymouth
57plymouth's Avatar
Default LS swap question
Simple question; does anyone daily drive their LS swapped 240? I'm thinking of a simple 5.3 truck engine swap with no turbo. Fairly stock, with a 4l60e or 700r4 transmission. I don't want a stick shift daily driver.
How is it to live with an LS swapped 240 daily? Any real world mpg?
Sven, the 1991 245
Old 01-12-2018, 10:10 PM   #2
I.M. Weasel
You know that flat torque curve and your right foot will reduce any chances of better than 15mpg.
Living life one day at a time. Stopping to smell the oil slick beneath my Volvos.
Old 01-12-2018, 10:21 PM   #3
57plymouth
57plymouth's Avatar
I drive like an old man. Let's pretend that will continue.
Also the cops in my area are vicious with their fundraising efforts.
Old 01-12-2018, 10:25 PM   #4
Same story with a turbo redblock, honestly
Old 01-12-2018, 11:12 PM   #5
vertigosity
vertigosity's Avatar
I've gotten between 16 and 20 depending on conditions (weather - it's been pretty much either 100 degrees or 20; aggression level - pretty much either old man or hair on fire) in town, around 24 the only time I've taken it anywhere. I think I could probably get the highway number up with a 3.3 rear or T56, but that in-town range is pretty much it. '04 5.3, 2.8/0.64 "street and strip" TKO, 3.73 rear.
Pretty much what I got with a turbo redblock, honestly!
93 245 5.3L LSx / 90 Miata / 90 Spec Miata
Old 01-13-2018, 08:34 AM   #6
57plymouth
57plymouth's Avatar
Thank you.
Old 01-13-2018, 12:19 PM   #7
volvo?
That One Guy
Mine has been my daily driver for 2 years now. I jave had no major break downs. It passes emissions tests and gets 20 mpg in town and 24 on the highway. It is probably the best car I have ever owned.
volvo? is offline   Reply With Quote
Old 01-13-2018, 12:52 PM   #8
- Stock PSI Or Bust -
Phhhst I got that in my '68 GTO 400 / 400 with 365NA insta-ponies at the tap of the pedal.
You did it wrong.
how psi stock cna sprout?
Old 01-13-2018, 01:01 PM   #9
I.M. Weasel
You did it wrong.
Too bad those ponies were distributed over 2 tons.
Old 01-13-2018, 01:03 PM   #10
# 3750 not that much heavier than a 240.
And don't forget the giant LSD pumpkin and driveshaft, so it could actually put it down.
Old 01-13-2018, 01:14 PM   #11
Wilford Brimley
Is posting from the grave
Wilford Brimley's Avatar
This, my milage went to crap
Deb the 940T Tina XC90 T5
Old 01-13-2018, 01:52 PM   #12
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
the 940 does alright, but the transmission isn't loving life right now (suspect I should've replaced the pump when I went through it). I haven't had any kind of serious problems with it in the three years its been running. I don't DD it for a variety of reasons (mostly because the a/c leaks down), but there's really no compelling reason I couldn't.
Megasquirt Tuning!
Old 01-13-2018, 02:13 PM   #13
Texas240
Prius Owner
Texas240's Avatar
I drive mine a few days a week, use it on the weekends to grab hardwood and metal tubing for home projects. Taken it to a few car shows around town, some 500 mile round trips and hoon it from light to light every so often. Been doing this for over a year + now. Zero break downs other then a power steering fluid leak thats fixed. I get around 18-24 city/highway. Sounds amazing and has great torque curve for city.
93 245 LS Engine Swap GONEProject
79 242GT 2016 LT, Mustang II front end, 2001 C5 Rear assembly
Old 01-13-2018, 02:57 PM   #14
283SD
While I don't have an LS motor in my wagon,I have the old school 350/350 Chevy in it. It is now coming up on 30 years that I have been driving it. I have put 285,000 miles on it so far. I have put 2 starters 2 alternators 2 fuel pumps and 1 water pump on it, in the last 30 years. I now run 3.31 gears and get 16 mpg on the highway. I did not build it for MPG I built for sheer fun.The exhaust is S/S built in 1990, The brakes, I put every thing on new from Volvo in 1991, cross drilled all the rotors [120 holes each] the rear pads will have to be changed this year, the front pads are 1/2 worn. I plan on building a 2nd car soon.
Old 01-13-2018, 03:05 PM   #15
Dan
Fought Covid and won
Dan's Avatar
My 5.0 Chevy TPI motor in my 740 with 3.73 gears and locking tq converter TH 700 r4 gets 15 around town and just over 21 at 75. I would think an LS with newer FI would get slightly more, depending on gearing, I still turn 2500 rpm at 70 or so. I imagine i could get more in town, but it's too much fun to drive the snot out of it, and since its a gray grandpa car, I don't attract much attention
1985 Chevy TPI V8 740.
Old 01-13-2018, 03:19 PM   #16
2manyturbos
It's going to depend on what rear end gears you choose and how much of a lead foot you are. The LS with an automatic gets an average of 17/27 according to EPA fuel mileage studies in a Camaro Z28 body. They are more aerodynamic than a 240, so, that will definitely come into play. I would expect you to get 25 mpg on the highway at a minimum if you set up the final drive gearing the same. The LS is an excellent engine. Super flat power band.
Old 01-14-2018, 01:38 AM   #17
Onefastpig
I have a turbo 5.3 in mine and I can get 15-20mpg depending on how it's driven and that's 50/50 city/highway. Mine is a 5 speed though. Mine has a pretty quiet exhaust system and sound deadening in the cabin which helped quite a bit.
Onefastpig is offline   Reply With Quote
Old 01-15-2018, 12:22 PM   #18
Trevor57
Trevor57's Avatar
I would daily drive mine, but my wife and daughter don't like it. I drive mine any time I am alone, or with my son. Only problems with the car I have had were self imposed.
86 245 lsx/t56 / 92 245 / 21 model 3 / 04 325xi / 16 Silverado /
Trevor57 is offline   Reply With Quote
Old 01-15-2018, 12:27 PM   #19
JohnMc
JohnMc's Avatar
I'll let you know in 5 to 6 months.
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 01-15-2018, 01:08 PM   #20
I.M. Weasel
Who's 240?I guess if you don't think a 1000lbs. Is much more.
Old 01-15-2018, 01:23 PM   #21
They weigh ~ #3200 stock.
Old 01-15-2018, 01:23 PM   #22
cosbySweater
cosbySweater's Avatar
My turbo lsx 244 gets like 15-16 if that. However I have a 25 inch tall tires and 3.73s I'm looking to get some bigger tires on it and possibly regear it
1992 GMC Typhoon
1995 Porsche 993
2013 VW Passat TDI
Old 01-15-2018, 01:25 PM   #23
JohnMc
JohnMc's Avatar
I think that's perhaps the most weight a stock 200 series ever weighed. V6 lump with an automatic trans.
https://www.volvoclub.org.uk/pdf/bro.../Volvo1979.pdf
Page 11, various weights for different models. The V6 automatic wagon is 3223. The 244 manual trans is 2794.
Old 01-15-2018, 07:09 PM   #24
Trevor57
Trevor57's Avatar
My 1986 245 with an aluminum 5.3, t56, and 7875 turbo is 3200 lbs. I weighed it at the scrapper.
Old 01-15-2018, 08:03 PM   #25
M.H. Yount
M.H. Yount's Avatar
82 242 with manual windows, seats, etc., PS, A/C. With Ford 5.0L, manual trans and 8.8" rear end mine weighed 3036 lbs. on corner scales with about 3/4 tank of fuel and the spare removed from the trunk. With both the Ford and the LS3 I'm seeing 18-22 mpg around town and 24-27 on the highway -- provided you keep your foot out of it. 45-50k miles over the last 22 years -- one broken throttle cable. That's it - dead reliable. Oh - 3.73 gears with the Volvo rear, 3.55 with the Ford.
