I.M. Weasel
![]() I googled around a little bit and did not find much information on 8v head install with head studs. Nothing came in the box from Yoshifab either. I found a torque value of 90ft.lbs in one of the threads, is this correct?
Living life one day at a time. Stopping to smell the oil slick beneath my Volvos. |
Kapitän Klugscheißer
![]() 1. Clean and inspect holes in block.
2. Thread bolts* into block by hand 3. = 15ftlb 4. = 45ftlb 3. = 90ftlb ARP moly lube (or 120ftlb with 30wt oil) ![]() *bolts = studs in this application For future searchers - Arrow is pointing to front of vehicle. Straight from https://yoshifab.com/store/webdocs/torquespecqrr.htm |
I.M. Weasel
![]() Thanks, I didn't find that but I was searching from my phone. I've seen that other people use moly assembly lube, I'm guessing that's similar to the arp lube.
#4 | |
![]() Torque and relieve them. 3x was what arp told me after my hg popped right after install
The Build Thread SVEA - PUSHROD TURBO! |
#5 |
I.M. Weasel
![]() Arp lube was in the package! :-) so do the whole procedure 3x?
#6 |
![]() I didn't do that and never had an issue. MLS gasket and an o-ringed block though.
I did re-torque them after ~some miles, and they needed to be. |
#7 |
![]() ARP recommends doing it three times to properly seat the bolts
#8 |
#9 |
#10 |
#11 |
yv1a.com
![]() I've installed two sets so far.
I installed them and torqued. Next day, I loosened and torqued one at a time. Ran the motor and drove around for a bit. Came out the next morning and loosened and torqued one at a time. Done. Stock Elring HG both times. |
#12 |
The MP
![]() Use the moly grease, not only on the threads. Get it on the washers, too.
Follow the de-torque sequence as well (reverse). I would think one time de-torque and re-torque would work, but it's yours, so rock on.
#13 |
![]() also make sure the washers don't turn on the head of they do sand them on the head side
#14 |
yv1a.com
![]() On another note, I was able to install the studs on my 83 and then put the head on. On my 91, I was unable to do so. I had to set the head in place and then thread the studs in place.
