Old 04-16-2020, 11:48 PM   #1
GratefulNed
GratefulNed's Avatar
Default I need more traction!
So my sbc 350 v8 swapped volvo is almost done (build thread coming), im wrapping up the exhaust, wiring, and still procrastinating on power steering.
Needless to say, with 10:1 compression, "ported" heads, mild cam and rpm performer intake, holley sniper EFI and a heavy foot, my rear tires don't have much to say except "SKRRTTTTTTT". One tire fire baby...
So once the burnout contests are through and the smoke clears, I want some more traction.
I currently have stealies on it that came with it, and a tired set of 185/70-r14 perelli p4's.
I was thinking of replacing the rears with Virgo turbos, but at over $150 each on ebuy "refurbished", i looked into other options as well.
I found some american racing outlaw ii's with 5x108 pattern, 14x7 size and 0mm offset.
I know pretty much nothing about rims so here goes: 240's supposedly have a 20mm offset, so these AR outlaws would stick out an extra 20mm, which would help the fact I'm thinking i want to use atleast 205mm width, which is 8.07", much wider than the stock 5.5" width i got now. Right?
Set me straight TB
VOLVO 240 V8 SWAP SBC 350
GratefulNed is offline   Reply With Quote
Old 04-17-2020, 12:38 AM   #2
James M
Bored member
James M's Avatar
You should be able to get virgos a lot cheaper locally if you look, but at 6 inches wide they don't offer a ton of space for wide tires
Old 04-17-2020, 02:34 AM   #3
Sjeng
Sjeng's Avatar
A locker/limited slip differential will help. Powertrax 2210-LR is a cheap, strong option for the dana30.
Old 04-17-2020, 11:46 AM   #4
Fred Gwynne
That got my attention.
Fred Gwynne is offline   Reply With Quote
Old 04-17-2020, 11:53 AM   #5
- Stock PSI Or Bust -
Set me straight TB
It's gonna rub like a cheap lapdance.
Maybe some Hydras since there's better tire choices in 16".
That said $150 isn't bad for a Virgo since powder coating or painting is ~$100 per wheel now, so what's another $50 for a straight Virgo?
Which in and of itself almost is an impossibility anymore.
how psi stock cna sprout?
Old 04-17-2020, 12:06 PM   #6
Heh yea like buy 20 or 30 of them to get a straight set.
DAMHIK.
Old 04-17-2020, 12:12 PM   #7
culberro
culberro's Avatar
It's hard to find decent tire selection in 16s now. 17s are the new 15/16.
OP needs some 7" wide wheels minimum, and some good tires.
Head work: https://forums.turbobricks.com/showthread.php?t=349975
Temp Sender Adapters: https://forums.turbobricks.com/showthread.php?t=348169
Old 04-17-2020, 12:38 PM   #8
Nagrom
Nagrom's Avatar
205mm pirelli p7s on my hydras and I haven't heard my tires since.
Nagrom is offline   Reply With Quote
Old 04-17-2020, 01:36 PM   #9
GratefulNed
Thanks for the replies guys!
This car is about 30% rust, especially in the rear fenders. I’m no stranger to a sawzall, or a welder, and don’t mind making custom fender flares.
https://www.bbwheelsonline.com/ameri...-machined-0mm/
Here’s the rims, will they rub on the inner body side, or the outer fender? How bad? Cut half my rear quarter panel out bad, or roll with a baseball bat and massage with a sledgehammer bad?
Assuming I’m willing to cut outer fender/make flares, do you think it will clear the brake calipers and all?
Old 04-17-2020, 04:27 PM   #10
redblockpowered
cone dodging dilettante
redblockpowered's Avatar
What kind of tire can you get for those? Replacing poop all-seasons with wider poop all-seasons will hardly do much.
I sell chips for LH 2.4!
If you live in the Northeast US, I'll drive to you and tune your LH 2.4 car!
Old 04-17-2020, 04:43 PM   #11
2manyturbos
If you really want more traction, think posi-traction/locker. You are going to break that differential putting a bunch of power out through the spider gears of that open differential.
Old 04-17-2020, 05:38 PM   #12
GeneralBurrito
GeneralBurrito's Avatar
You can go with 16s and get some Toyo R888Rs in 205/50r16 size, which is 24.1" diameter, not too far off the stock 24.2"
Old 04-17-2020, 11:25 PM   #13
GratefulNed
Yeah, i just read on IPD volvo's offset is positive (away from the car), so these wheels are 20mm farther in, not out like i thought, and 1.5" wider, so thats definitely not going to work for those not inclined to enjoy the rub of a cheap lapdance.
I'm now leaning toward the Virgo's, which should be able to do a 205mm width from what I've read, as well as welding the diff for now.
I actually bet my uncle $100 I could smoke his 2004 F150 lariat 5.4l and he took it, so after welding the diff and getting some rubber I should be able to take his hundo and put it towards a 912A585 Detroit Truetrac (which i think fits... not sure tho)
Old 04-17-2020, 11:55 PM   #14
Old 04-18-2020, 12:06 AM   #15
2turbotoys
Salaminizer
2turbotoys's Avatar
If you make any real power, 205's aren't gonna cut it.
A zero offset will fit, but there is a real chance of the tire rubbing on the inside. And if they are wide enough they will rub on the outside as well. On my 79 242, a 245/40-17 (8" wide) with a 6mm offset makes a clean spot on the inside, and if you hit a large bump the fender hits the tire, even after a bunch of trimming. A 225/45 is a better choice.
Use this, it will help. https://www.willtheyfit.com/
1978 242, 5.3 L33
1979 242, MS, R brakes
2006 V50 T5 AWD @ 17 PSI
Old 04-21-2020, 05:56 PM   #16
c1800
Or this:
https://www.wheel-size.com/calc/
Old 04-21-2020, 08:10 PM   #17
2turbotoys
Salaminizer
2turbotoys's Avatar
Originally Posted by c1800 View Post
Nice! I was looking for that recently and couldn't remember the sites name. Thanks!
Old 04-30-2020, 10:38 PM   #18
turbotankshane
I've got a spare set of hydras for the back of my 4.8 turbo setup in a 91 240 sedan, with a 245/55r16 nitto nt555r on em. My buddy had em laying around and i'm notoriously cheap, I had to remove some the tank shields for them to fit and even then with any passengers in the car they like to rub over bumps, and they're too wide to use the entire tread on that narrow of a wheel anyway. So a 225-235 may be the widest you really want to go on a hydra.
For crusing I just put the stockers back on with 195s and send it
Old 05-04-2020, 09:14 AM   #19
Pillow
Sleazebag 7-9 Owner
Pillow's Avatar
This. Get some cheap 17 take offs with IPD adapters and put GOOD 225/45/17 tires on them.
Plus the locker as mentioned above.
While you are at it, make sure your brakes are 100% proper with quality pads.
... 15s if you want to run drag slicks. But that is another story.
2010 Porsche Cayenne S - My ride - 99k stock
2010 Cadillac Escalade ESV - Wifeys ride - 205k stock
2007 Audi A4 3.2 M6 - daughters ride - 166k stock
2006 Volvo XC70 Wagon - sons ride - 175k stock
1992 Volvo 965 - "Savage Wagon" w LS 5.3 LM7 + LS7 cam + GM T5 swap in progress.
1979 Porsche 911SC - stock
1948 Spartan Mansion travel trailer - aluminum greatness
