Old 06-01-2021, 12:17 PM   #1
golddayton101
Default NA vs Turbo Tailpipe
My 84' 245T is being restored and wanted to know if the tailpipes (S pipe) are the same for NA and turbo models? Looks like the turbo Starla ones are backed ordered with no ETA. The NA pipe looks the same but didn't know if the ID/OD are different.
golddayton101 is offline   Reply With Quote
Old 06-01-2021, 12:25 PM   #2
white855T
Not the same. n/a is 2 inches and turbo is 2 1/4. I believe you can order the s pipe from Volvo.
Old 06-01-2021, 12:50 PM   #3
golddayton101
Only I can find through Volvo is the L-shaped tip.
Old 06-01-2021, 12:56 PM   #4
The Librarian
Here you go.
https://www.ebay.com/itm/29418061996...8AAOSwnPJgopWm
Old 06-01-2021, 12:58 PM   #5
golddayton101
Thank you! I guess either or will do.
Old 02-13-2022, 03:13 PM   #6
golddayton101
Bump! Does anyone
know where I can get one new?
Old 02-13-2022, 04:31 PM   #7
Old and boxy but good.
Try VP Autoparts. They probably have it available. Not a common part so if it's available order it and be patient.
Old 02-13-2022, 04:41 PM   #8
The Librarian
VP sells the "L" shaped pipe and the website says it's in stock.
https://vp-autoparts.com/en/artiklar...9et_b21et.html
Here's an "S" shaped pipe in Germany.
https://www.ebay.co.uk/itm/224820798...cAAOSwWY9h-34p
I may have an "S" shaped pipe. It looks correct but the part number tag has fallen off.
Old 02-13-2022, 05:51 PM   #9
- Stock PSI Or Bust -
Originally Posted by golddayton101 View Post
Bump! Does anyone
OG stock Volvo 60mm or 2.25" Starla / Walker?
how psi stock cna sprout?
Old 02-13-2022, 09:26 PM   #10
OldCarNewTricks
OldCarNewTricks's Avatar
What is the purpose of the S shape, anyway?
OldCarNewTricks is offline   Reply With Quote
Old 02-13-2022, 10:57 PM   #11
PCH
Probably to move it away from trunk/tailgate area for leg safety. Also if you accidentally back into the hard object the S pipe will bend instead of stressing the exhaust manifold.
Feedback: http://forums.turbobricks.com/showthread.php?t=341280
Old 02-13-2022, 11:27 PM   #12
Take it to an exhaust shop and have them do what they do best?
