Thread Tools | Display Modes |
Making Volvo Parts Fit
![]() Join Date: May 2008
![]() Searched, but didn't find definitive posts.
Just want to know what spacers/ hub centric adaptors are needed to fit P1 wheels to the live rear axle 745 wagon. C30 wheels are 63.4 hub bore/ approx ET45-50 - looking online 700's have 65.1 bore ET20 offset? 20/25mm spacers all around? Or less because the 17-18" wheels are all wider? I always get confuddled when it comes to calculating offset/width changes (most math, honestly) Thanks in advance |
Amateur hour!
![]() https://www.willtheyfit.com
I like to use this so you get a visual of how the new wheel/tire will sit in comparison to the current one. |
- Stock PSI Or Bust -
![]() 700 wheels are 25et except for the multi-X which are 20et.
#4 |
![]() Join Date: Jul 2002
![]() You would want something in the 25-32 range
#5 |
#6 |
![]() We could probably modify a set here to have the requested CB on the wheel side. We try to stay away from customs though
#7 | |
![]() Quote:
#8 |
#9 |
![]() Also make sure you check the size of the lugnut holes. If they're the same as V50 wheels which are also P1s you may need to use the original lugnuts. I ran Clavas (16x6.5) from a V50 on my 242 and later on a 940SE for awhile and the lugnut holes were much larger than on any other wheel I've seen. My stock 240 lugnuts pulled straight through the holes and the aftermarket lugnuts I ordered with decent sized shoulders were still too small.
#10 |
Who engineered this?
![]() Buy the propus c’s in for sale section.
Buy a set of Ben’s extended studs and 25mm spacers. Install is easy. Bolt wheels on. Happy day. |
#11 |
8 cylinders
#12 | |
![]() Quote:
#13 |
8 cylinders
