![]() Hi i have read a lot on this forum and know that you guys are very knowledgable on volvo transmissions, and i am out of my depth . I have a MG TD which is going to have a volvo B20 engine I am now in the process of trying to find a automatic transmission to go behind the engine. Looking for either a AW 70 or 71 i understand i have to make a adaptor plate to stand the transmission upright behind the engine that is all taken care of. Question i have is i can only find transmissions from fuel injected cars and they all have a position sensor on the flex plate does this mean that i cannot control the transmission only by electronic's i am hoping to couple it to the twin carbs just like the old 35 transmissions were . I know its a very long post but i need info before i commit to buying , also would a AW70 transmission be a good bet or should i look for a 71 i have lots more to ask but will stop there
Bored member
![]() AW70/71 are not electronically controlled, you don't need any additional wiring outside of the OD solenoid. That flywheel sensor is for the ECU/EZK, if your running carbs it's not necessary.
The Librarian
![]() You can buy an adapter to rotate the transmission. It requires the bell housing to be machined down by the thickness of the adapter.
http://www.hukebasart.nl/huke/?Koppelingshuizen AW70 and 71 transmissions are not computer controlled. The sensor you're seeing is for the ignition. If you plan on using a cable driven speedometer you'll need an earlier transmission. AW70s are used behind naturally aspirated engines while AW71s are for turbos. They're essentially the same save for some extra clutches and revised shift points. |
#4 |
![]() Hi Thanks as its a total manual automatic i can just disregard the sensor thats great to know now i have read a lot of negative on the AW70 but in a less stressfull inviorment will it be a good transmission because otherwise i get into the next problem of lockup torque converter etc which i do not thing i need very helpfull replies and i think i will be back with more questions on adjustment of the kick down etc thanks Mike The adaptor plate is already on the drawing board ready to machine out when i get that far Mike
#5 |
Old and boxy but good.
![]() If you want to run a manual trans you can use the Volvo M40 or M41 with overdrive. No adapter plate needed and it'll be more fun shifting gears. The MG already has a hydraulic clutch setup which is what those volvo transmissions use.
Dave, 1982 242 turbo. 338k miles. MVP coilovers and 3" exhaust. Flowed 405 with a V15. Cossie turbine housing with upgraded compressor housing. 90+, IPD remote oil filter. Some other goodness, too. Been lots of fun over 25 years. Restored in 2k. Now ready for a 2nd restoration. 1993 245 Classic, 440k miles, enem V15. IPD bars and chassis braces. Simons sport exhaust from Scandix. sbabbs ezk chip. Been a good road warrior. Genuine Volvo rebuilt leaky M47. ![]() |
#6 |
![]() Hi brought this up to the front i have now got my transmission home its a gear driven spedo and all seems fine !!!!!!! But the flex plate is 8 bolt and crank is 6 bolt is this going to be near impossiable to find anything other that will fit or do i hve to machine the centre and make a 6 bolt to fit my crank your input please In reply to go manual i have the m41 set up with hyd clutch but i want to go automatic not much room down the front to put 3 pedals would be better with only 2 also there are lots of volvo MG conversions but very few have gone down the automatic path so Mike
#7 |
Bored member
![]() There are 6 and 8 bolt b20 crankshafts, earlier models being 6 bolt. My assumption is you'll have to find a 6 bolt b20 flex plate, but I don't know off hand if the AW70 torque converter bolts up.
#8 |
The Librarian
![]() It does.
I have 6 bolt flex plates. |
#9 |
![]() Hi so i guess they are available its a shame that you are the other end of the world to me i will start a search for one near home thanks mike
#10 | |
- Stock PSI Or Bust -
![]() Quote:
Best bet is going to be an AW71 from a Turbo car for the swap. |
#11 |
![]() Best bet is going to be an AW71 from a Turbo car for the swap. Sorry that is not what i want small b20 engine natural asperated the 70 will be a lot kinder to it treated correctly a 1000 lb car with driver will be no load for it Mike
#12 |
![]() It doesn't weigh any more, lasts longer and has better shift points, but it's your car.
