Old 03-07-2022, 02:40 PM   #1
Markos Simopoulos
Default liquid urethane
hello everyone, I am in the process of swaping a zf s5-18/3 trans into my volvo 240. I discovered that the bushing for the trans mount is worn out, I did some thinking and I found this video( its an explanation of DIY liquid urethane)
https://www.youtube.com/watch?v=2_0B...riving4answers
I was wondering if anyone has done this before. I am mainly interested in doing this because sourcing a trans mount for a maserati biturbo is difficult/more expensive and I want something that will last, however if possible I don't want it to be too harsh. anyways I hope that is enough info thanks in advanced.
Markos Simopoulos is offline   Reply With Quote
Old 03-08-2022, 01:01 AM   #2
The Librarian
I have no clue how well it will hold up in that application but I've had good luck using Smooth-On products to make shifter bushings. VytaFlex is available with a shore hardness rating of 10 to 60 so you can choose how stiff you want it to be.
https://www.smooth-on.com/product-line/vytaflex/
Here's a new mount in the US if you don't want to try making your own.
https://www.ebay.com/itm/Maserati-Bi...75.c1#viTabs_0
I'm curious about the trans adapter you're using. Do you have any details? I also have a ZF s5-18/3 trans from a Maserati Biturbo that I'd like to put behind a redblock.
Old 03-12-2022, 06:41 PM   #3
Markos Simopoulos
sorry for the delay,
My brother is a sort of machining/fabricator hobbyist, so I am paying him to do it, and he is teaching me as best as he can along the way. Our plan for the adapter plate is, to make a plate the mounts to from a p1800 bellhousing to the Maserati gear box, with a flat flywheel. He is 3d printing a test peice to verify everything works. I will post pics of our progress below.
Old 03-12-2022, 06:46 PM   #4
Markos Simopoulos
Screenshot-20220312-145857
Old 03-12-2022, 06:50 PM   #5
Markos Simopoulos
started a print this morning
Screenshot-20220312-145708
Old 03-12-2022, 07:04 PM   #6
Markos Simopoulos
2022-03-12-Copy
Old 03-12-2022, 07:15 PM   #7
Markos Simopoulos
if you would like, I can ask him to make a second adapter plate when we go to make mine feel free to pm me.
Old 03-12-2022, 10:00 PM   #8
The Librarian
That would be awesome. PM incoming.
Old 03-12-2022, 11:36 PM   #9
spock345
spock345's Avatar
What material are you printing the adapter plate from?
1998 S70, grandma-mobile
Old 03-13-2022, 11:30 PM   #10
Markos Simopoulos
The adapter plate will be aluminum, but we are 3d printing a plate just to verify fitment. The print is made from PLA and PVA just to support the plate during the print.
Old 03-13-2022, 11:38 PM   #11
Markos Simopoulos
just finished the print a few hours ago yay!
Screenshot-20220313-213013
Screenshot-20220313-212954
Old 03-14-2022, 10:30 AM   #12
spock345
spock345's Avatar
I was intrigued by what looks like two different plastics.
Old 03-14-2022, 10:52 AM   #13
240wagonguy
Yes i've used liquid urethane to fill Honda motor mounts before. Make sure you seal the bottom real well so the stuff doesn't leak out.
Old 03-14-2022, 01:37 PM   #14
Markos Simopoulos
The white stuff is water-soluble so its great for support structures that you want to remove later for the print.
thank you will do.
Old 03-14-2022, 02:16 PM   #15
culberro
culberro's Avatar
This, or the fast setting urethane caulking/construction adhesive.
There's some black stuff that's pretty common in the US.
Head work: https://forums.turbobricks.com/showthread.php?t=349975
Temp Sender Adapters: https://forums.turbobricks.com/showthread.php?t=348169
Old 03-15-2022, 11:57 PM   #16
Markos Simopoulos
slight mistake..... we realized that we mirror imaged the transmission bolt pattern, but everything else fits perfectly. Here is the corrected image, now to find some big ole chunks of aluminum.
2022-03-15
IMG-20220315-083459
