![]() I am nearing the the end of my manual swap. I have purchased the upper and lower harness for a m46 from Dave Barton’s site. I also have an overdrive relay. My question is how to use the relay.
There are some plugs on the harness that are meant to be connected under the dash. Would I be right to assume that these plugs won’t exist on my car? I can follow the wording diagram and hook up power, ground and an overdrive light. I am just not sure what exist on my car. |
Old and boxy but good.
![]() You are probably going to have to run the power wire from the fuse box to the relay. For the overdrive light in the cluster you can use the up arrow light from the automatic overdrive. I can't recall any plugs under the dash you'll need or may be existing. The overdrive up arrow would have a wire running to the old automatic relay so you can splice into that easily. Just be careful to insulate the wiring where it goes through the shifter hole.
Dave, 1982 242 turbo. 338k miles. MVP coilovers and 3" exhaust. Flowed 405 with a V15. Cossie turbine housing with upgraded compressor housing. 90+, IPD remote oil filter. Some other goodness, too. Been lots of fun over 25 years. Restored in 2k. Now ready for a 2nd restoration. 1993 245 Classic, 440k miles, enem V15. IPD bars and chassis braces. Simons sport exhaust from Scandix. sbabbs ezk chip. Been a good road warrior. Genuine Volvo rebuilt leaky M47. ![]() |
![]() If your car originally had an automatic with overdrive (AW7X) and you have the push button shifter and relay for the M46 I think you can just replace the automatic relay with the manual one and connect your old overdrive button wires to the ones in the manual shifter. IIRC the only difference between the manual and automatic overdrive relays is the automatic relay is on by default and the manual one is off by default.
#4 | |
![]() Quote:
Other wiring includes jumping the neutral safety switch and hooking up reverse lights. These are fairly simple you just have to find the wiring jacks that hooked up to the switch that was in the auto shifter. (They are on the drivers side down at the bottom of the center stack. The wiring harness I bought has all the wires and connectors that go to the actual M46 and a socket for the relay. Those include overdrive solenoid, 4th gear lockout switch and the momentary overdrive switch at the top of the shifter. |
#5 | |
The Librarian
![]() Quote:
