This is a scatter shot question since I don't have any specifics to provide other than after running the car for more than 20 minutes, it starts to idle rough. I can turn the engine off, then start it again and it will still idlel roughly, but after I run it a bit more it seems to smooth out. Starts fine and runs fine with lots of acceleration. I replaced an old fuel pressure regulator thinking that due to its extreme age, that it was causing issues. Does run much better, but the rough idle is there, but not as bad as before with the older fuel pressure regulator.
Any ideas would be appreciated. Thanks.
Steve
Steve
