Nikolaos244Turbo
- Sep 9, 2007
- Hellas(Greece)
Hello,
I'm using 25mm spacers (et48 steelies) and as you can see I manage to mount the hab caps on the ring from the spacers that exceeds over the wheel.
But I'm planning to flip the wheels in order to achieve zero offset an therefore will be no need for the spacers...but then,where can I mount the hab caps?
I'm thinking if I can weld a ring 10mm around the wheel center...what do you guys think?
