Old 09-08-2022, 02:07 PM   #1
Vwrado
Vwrado's Avatar
Default Springs for a 240 wagon Lesjofors vs IPD
245 sags quite a bit when there is just a little weight in the back and even more with a couple passengers in the rear. If I were to get either the Lesjofors or IPD, would that help my situation?
Lesjofors are progressive so this possibly might help?
Does anyone know the spring rate of IPD?
Anyone have pictures of either of these springs installed? I am looking to go with one with less lowering.
Vwrado is offline   Reply With Quote
Old 09-08-2022, 02:26 PM   #2
- Stock PSI Or Bust -
Hard to beat the Moogs price wise from rock auto.
https://www.rockauto.com/en/catalog/...il+spring,7512
That said I'm happy with my old style IPD non progressive overloads on my 82 245 & the Lesjofors overloads on the 93 245.
Not at all a fan of progressive springs FYI.
*moderators note: Ken passed away on September 26, 2022. His contributions to the forums and his dry wit will be missed.
Memorial thread:
https://forums.turbobricks.com/showthread.php?t=365641
how psi stock cna sprout?
Old 09-08-2022, 02:41 PM   #3
Vwrado
Vwrado's Avatar
Thank you for the input Redwood.
What is the ride quality of the progressive springs that you didn't like? Also, for the overload spring, Are they higher spring rates and do they sit at the same height when the car is not loaded?
Old 09-08-2022, 04:09 PM   #4
Progressives might be nice if they made progressive shock absorbers but they don't.
Yes the overloads are thicker wire and sit ~3/4" higher, but that's easily fixed by snipping the first turn of the top of the spring.
Old 09-08-2022, 05:18 PM   #5
Vwrado
Vwrado's Avatar
Great! I am leaning to this.
For the price, it seems hard to beat.
Would you happen to know if the overload springs are stiffer than say IPD lowering springs?
Old 09-08-2022, 05:23 PM   #6
No idea probably similar though.
Also there's the older black IPD lowered low life springs, and the newer blue lowered low life springs that are a bit thicker, but I don't mess with them poncy poseur springs so I really can't say.
That said these are the old skool IPD overloads that are currently on my 82 245GLT.
https://forums.turbobricks.com/showt...hlight=springs
Old 09-09-2022, 09:44 AM   #7
OVERDRIVE
OVERDRIVE's Avatar
I have the progressive ipd springs on my sedan, and they do what they're suppose to, but they leave much to be desired regarding ride quality. There are people who swear by the moog cargo coils. If you're into doing your own experimentation your could get rear adjustable coilover sleeves from BNE and adjust the spring rate and height to what fits your car.
1990 244 DL AW70 189 white.
OVERDRIVE is offline   Reply With Quote
Old 09-09-2022, 12:00 PM   #8
That's a damper issue, not a spring issue.
Old 09-09-2022, 01:01 PM   #9
OVERDRIVE
OVERDRIVE's Avatar
Do you think it's an under damping issue? I decided to upgrade the shock to TC's to try to match the spring rate. I don't like the TC's, I know that much. They're harsh over road imperfections and the rears rattle. I sold my stock sedan rear springs to a guy who had B6's and IPD overloads on his sedan and he didn't like springs, wanted to go back to stock.
I wish I could drive a nicely set up 240, right now It's just trial and error over here.
Old 09-09-2022, 01:10 PM   #10
Both B4 and B6 are valved to match stock spring rates. It just is what it is. You are better off getting a used set of B6s and sending them off to be revalved, but that still won't get you a nice digressive damping curve.
Unfortunately that's life with a 240. You have 3 options:
1. Leave it stock and use nice parts
2. Reengineer everything from the ground up
3. Pay big bucks for a very nice off-the-shelf solution
Old 09-09-2022, 01:35 PM   #11
OVERDRIVE
OVERDRIVE's Avatar
Thanks for the pointers.
Old 09-09-2022, 02:27 PM   #12
Old and boxy but good.
I chose revalving for my turbo with the B6 shocks. They are great. The wagon uses cargo springs from FCP and the fronts are the 242GT front springs. Also from FCP. The ride is not cush anymore it's very firm with some harshness over rough stuff. Rear Bilteins and front Swedish Car Parts on the wagon.
1982 242 turbo. 338k miles. MVP/ BNE coilovers and 3" exhaust. Flowed 405 with a V15T. Cossie turbine housing with upgraded compressor housing. With wildly uncontrolled wastegate. 90+, IPD remote oil filter. Some other goodness, too. Restored in 2k. Now ready for a 2nd restoration.
Old 09-10-2022, 03:43 PM   #13
sloopy
2-digit whp
sloopy's Avatar
I just bought the lesjofors sport lowering kit just so I could run the rear progressive springs. I have coilovers in the front and koni sport dampers all around. i really like how it rides. It's pretty low. The rear wheel is just beginning to tuck behind the arch. I can get a picture if you're interested.
1992 volvo 240 wagon: black
> engine: b230f, a-cam, tube header
> drivetrain: m47ii, 4.10 gear, wavetrac lsd
> front suspension: bne coilover, 200 lb/in spring, koni sport damper, bne qsrc v2, bne strut mount, 23 mm bar
> rear suspension: lesjofors 131-188 lb/in spring, koni sport damper, 19 mm bar
> wheel: 15x7 multi-x
> tire: 225/60R15 bfgoodrich radial t/a
> misc: 6 lb lithium battery
sloopy is offline   Reply With Quote
Old 09-10-2022, 04:35 PM   #14
Vwrado
Vwrado's Avatar
I would really appreciate it if you can get some pictures. I still haven't decided on which springs to get yet.
Old 09-11-2022, 01:13 PM   #15
sloopy
2-digit whp
sloopy's Avatar
I don't have the rear seats or any of the cargo area flooring in the car so I compensated by putting a 62 lb and a 71 lb kettlebell in the back.
https://i.imgur.com/iu6oSjj.jpg
https://i.imgur.com/ENU0p6A.jpg
https://i.imgur.com/vkikfuD.jpg
Old 09-12-2022, 11:46 PM   #16
Vwrado
Vwrado's Avatar
Thanks for the photos! I think I'll be getting these springs since I like how they sit in the rear.
Old 09-17-2022, 09:40 AM   #17
OttoB
I got about 1,5-2 coils shortened overload springs and red Konis on my 245
I really like my rear. Nice and tight.
