Old 06-01-2022, 01:17 PM   #1651
Old and boxy but good.
Easy to apply excessive belt tension with the VW type of tensioners. When I replaced the belt on my 924 long ago. I made the belt too tight and it was screaming. Even the cam was making a sound.
I used VWs belt tension recommendation which was to turn the belt 90 degrees. I thought it had to be hard to turn but they want it rather easy to turn to check tension.
1982 242 turbo. 338k miles. MVP/ BNE coilovers and 3" exhaust. Flowed 405 with a V15T. Cossie turbine housing with upgraded compressor housing. With wildly uncontrolled wastegate. 90+, IPD remote oil filter. Some other goodness, too. Restored in 2k. Now ready for a 2nd restoration.
Old 06-12-2022, 11:20 AM   #1652
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
What a mess.. 2 things from my experience.. The thing with overtightening the belt is a bit a miracle.. It is just a bit while tightening and then you need to turn the engine over two times to check tension.. I ****ed 2 bearings with an overtightened belt and you will hear the bearings scream and get very hot if it's too tight.. Also I had to machine down the yoshifab tensioner plate one millimeter to make the belt run in the middle of the tensioner pulley cause mine started also to eat out the belts rim..
Old 07-05-2022, 01:50 PM   #1653
Missed your replies.
So far there has been zero damage to the belt itself with the tensioner barely tensioned. Guess the spring-loaded mechanism doesn't do much.
To wit, I do not like the way the belt rides at the moment. Machining down the tensioner side 1mm seems like a good idea. I'll have that done the next time the engine is apart.
Old 07-06-2022, 11:42 AM   #1654
Lord_Athlon
300+ Clurb
Lord_Athlon's Avatar
Got it running. Then broke it again.
I want to touch it.
Originally Posted by RvolvoR View Post
simple...just throw the redblock in the trash and install, well, almost anything modern
Yet Asher here went with...
Old 07-10-2022, 09:40 PM   #1655
Quin
ಠ_ಠ
i want alex to touch it.
Originally Posted by apachechef View Post
have you tried searching over on the turbobricks forums? a lot of jerks there, but some good info
Old 09-21-2022, 05:20 PM   #1656
Fixed the timing belt issues for good, by not paying attention to the spring-loaded tensioner alignment marks. Put a new timing gear in.
It still smoked after sustained boost, so the turbo came off. Then noticed that the adapter to bellhousing bolts on the trans got loose, so the transmission came off for inspection. Possible culprit was identified as aftermarket bearing retainer fouling on V-Performance adapter plate. Some very rough die grinder action seems to have resolved it.
Then the new baby, as it turns out, requires round-the-clock care. So the car has been sitting in a partly disassembled state since June. While sitting on the couch in my new job and new baby stupor, a Tilton concentric slave type release bearing showed up at my door. Looks like the clutch pedal is gonna get smoother, at least. On the con list, the do-do list has gotten significantly larger than it lready was at the beginning of the year:
[]Replace bellhousing bolt at starter (fouls on firewall)
[]Install replacement turbo
[]Swap in v2 QSRC
[]Install coilover tender springs
[]Apply Loctite to pillow ball bearing shell in BNE Comfort strut mount
[]Swap brake fluid reservoir (leaking at o-ring)
[]Relocate shock mount on rear control arm; add reinforcement
[]Relocate torque rod mounts on axle (back and down a bit
[]Move rear axle forward 1/4"
[]Build new turbo oil drain
[]Replace front pads and rotors
[]Install Tilton throwout bearing
[x]Glue shifter foam pill back together
[x]Trans output shaft seal
[x]Clearance trans tunnel for big dampened yoke
Old 09-21-2022, 06:59 PM   #1657
Quin
ಠ_ಠ
again?
Old 09-21-2022, 07:29 PM   #1658
again?
There is a giant ass slash on the hose. No idea how.
Old 09-23-2022, 06:52 PM   #1659
Tfest
Hipsters ruin everything™
Tfest's Avatar
ass slash
Lifted 240 Build Pages
TB Build Thread
Instagram Page
Tfest is offline   Reply With Quote
Old 09-24-2022, 11:50 PM   #1660
Wilford Brimley
Is posting from the grave
Wilford Brimley's Avatar
Originally Posted by Lord_Athlon View Post
I want to touch it.
Twss
Deb the 944T Tina XC90 T5
Old 10-19-2022, 11:43 PM   #1661
Sitrep. Pretty much nothing since June. Also haven’t forgotten to update thread, but too busy and too tired even for that.
Old 10-21-2022, 04:16 PM   #1662
LC4CARL
Aero challenged
LC4CARL's Avatar
Remember this?
@PDXvolvo on IG
Old 10-21-2022, 06:01 PM   #1663
Stiggy Pop
Stiggy Pop's Avatar
Re: QSRC's - is this just a change to the "new style" with ackerman adjustment? I've considered that but never could justify the price, especially since I don't really understand ackerman adjustments.
Re: pull axle forward - didn't you already shorting your trailing arms? Ben if you read this I've been seeing teaser pics of the new adjustable rear arms forever lemme buy some!!!!
Re: turbo drain hose - I replaced mine every year forever because the header always ate it. No amount of heat shield could stop it. Bending a piece of stainless tube to make a hard section for one was such a great peace of mind mod for me.
'79 242
943 pickup
Old 10-21-2022, 07:24 PM   #1664
I've been working on them forever,
Just made the final tweaks to the arms themselves and have the adjustment plates mostly roughed out.
finalizing the drop brackets now.
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 10-21-2022, 07:52 PM   #1665
Quin
ಠ_ಠ
he stopped by and forgot to address this part, which i was also curious about.
Old 10-21-2022, 08:26 PM   #1666
Stiggy Pop
Stiggy Pop's Avatar
In an alternate universe my car runs and they’re needed. In this one they’ll look real good on the shelf for 6 months.
Old 10-21-2022, 08:41 PM   #1667
Quin
ಠ_ಠ
what have you done now? wasn't it together and great like a month ago?
Old 10-21-2022, 10:26 PM   #1668
Stiggy Pop
Stiggy Pop's Avatar
Let’s not let my habitually broken 8v distract us from Harald’s habitually broken 16v
Old 10-21-2022, 10:54 PM   #1669
LC4CARL
Aero challenged
LC4CARL's Avatar
Old 10-22-2022, 12:09 AM   #1670
Quin
ಠ_ಠ
it's a fierce battle for the most Sorted disassembled 242 in the country.
Old 10-22-2022, 01:07 AM   #1671
#sorted
Head work: https://forums.turbobricks.com/showthread.php?t=349975
Temp Sender Adapters: https://forums.turbobricks.com/showthread.php?t=348169
Old 10-23-2022, 07:03 PM   #1672
mblue240
mblue240's Avatar
Swing by and see me, I'm 99% sure I have a bell housing for you.
Old 10-24-2022, 12:47 AM   #1673
Tentshedtrev
Tentshedtrev's Avatar
After years of messing around with every kind of fancy flexible material and heat shielding to boot, I too, have finally seen the light with using hardlines as much as possible. Those OEM's were on to something.
Life is too short to stay redblock..
06' V70R m66, stock, and keeping it that way
1990 740 SE, Eaton m90 supercharged b230F drift car *parted and crushed*
1981 242 turbo t5 whiteblock swap (in progress) (He351, MS3x, WC T5)
1990 245 Mitsubishi 4D56 turbo diesel km132 transmission, water/meth *sold*
1983 245 LQ4 6.0/ar5 trans/8.8 diff, longtubes, intake, sloppy stage 2, BMW front suspension, dual calipers
1990 740t WC t5, 15g, greentops, chips, 3" maf,
Tentshedtrev is offline   Reply With Quote
Old 10-25-2022, 06:11 PM   #1674
Tfest
Tfest's Avatar
I guess i have a 13 second volvo...
Old 10-25-2022, 06:59 PM   #1675
LC4CARL
Aero challenged
LC4CARL's Avatar
That's before you hit the nitrous...
