Old 08-09-2022, 02:27 PM   #1
linuxman51
Railspeeder Enthusiast #1
linuxman51's Avatar
Default headliner materials and adhesives
Have searched (n00b), and have concluded these few things, for the 940 wagon (with sunroof...dangit), and have a few last minute questions:
1/8th fabric/foam (no thicker than that at least),
permatex adhesive bad. is the 3m headliner adhesive still the stuff to go with?
Has anyone used the headliner/foam combo material (As seen on amazon(tm))? is it good/bad/cheap/to be avoided?
need to get this out of the shop and back in the car sooner rather than later, so getting ducks in a row. (headliner is already out)
Megasquirt Tuning!
Old 08-09-2022, 02:37 PM   #2
culberro
culberro's Avatar
Can vouch for permatex adhesive not being up to the task, it was what one place had and I didn't want to drive across town for the 3m at the time.
Redoing some trim covering today with 3m Super 77. I haven't been able to tell a difference between super 77 or 90 in any application for what it's worth, the slower dry time of S-77 might be more advantageous if you need to reposition anything.
Old 08-09-2022, 02:44 PM   #3
2manyturbos
Get the 3M general trim adhesive for carpets etc. It sprays as well as their headliner adhesive, yet, is much better at hold materials in place.
Old 08-09-2022, 03:17 PM   #4
cwdodson88
+1
The Build Thread
SVEA - PUSHROD TURBO!
Old 08-09-2022, 03:41 PM   #5
linuxman51
linuxman51's Avatar
that's enough of a consensus on the 3m spray for me. and no comments on the all-in-one headliner stuff, so I'll proceed with what I've got (I'd already ordered a roll of thin foam, but if there were no issues skipping one step I was happy to set it aside) and raid the fabric store one of these afternoons.
Old 08-09-2022, 03:47 PM   #6
I used 3M headliner adhesive on the BMW recently. Seems to work nicely with fairly absorbent cloth and did not cause any staining.
https://www.amazon.com/3M-38808-Head...abric-Adhesive
I hate the car and also cannot be free of it. I dream of having a different project but cannot separate myself emotionally from this one and so remain bonded to it like Sisyphus to his great stone.
Old 08-09-2022, 03:59 PM   #7
2manyturbos
I have used it before as well. The headliners came loose within a year or so. I hate to rain on your parade. All the upholstery shops I've had do work for me use the general trim adhesive.
Old 08-09-2022, 04:21 PM   #8
I put this in 2 years ago and it’s still holding
Old 08-09-2022, 04:23 PM   #9
2manyturbos
I hope it continues to hold. If it is a very light cloth, it will probably continue to hold in place.
Old 08-09-2022, 04:40 PM   #10
JohnMc
JohnMc's Avatar
I redid the headliner in the VW Jetta dieselvagen. Degraded original headliner - the cloth was good, the foam was rotten. Took the whole thing out, spent a while scraping at it to get the backing board clean. Then used the 3M 'headliner and fabric' adhesive spray cans. IRC I had two cans, and used both of them. Better a bit too much than not quite enough.
And I bought some headliner material, thin foam and cloth. It's still holding after at least 5 or 6 years.
It's pretty finicky to get it spread and tucked and steetched into position without it getting stuck in the wrong spot. While it's fresh you do get a chance or two to reposition, but pretty much, if it touches, it's stuck. So maybe do a dry 'practice run' the first time, then do it for real? And probably use two people so you can manage both sides.
Start on one end, with the rest of the headliner folder over and back. Spray an area with the glue, work the headliner forward onto the glue a bit, then do the next section, But by bit. The fabric is a bit stretchy so squeeze it into those nooks and corners (after making sure to spray glue in them extra well). Work on forward, let it sit for a while, then come back with a razor blade and cut out all the holes it needs.
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 08-09-2022, 04:56 PM   #11
alschnertz
Enough already!
alschnertz's Avatar
JoAnn Fabrics headliner material + 3M adhesive is what I used on the 745T 12 years ago and it's still holding up.
BUT, this car hasn't had a lot of time parked out in the hot sun since.
Still looks good though.
