Old 09-20-2022, 10:30 PM   #1
DD Ranch
DD Ranch's Avatar
Default Track Day Prep - 240 - Battery Tie Down
For those who have done this kind of thing before ...
To get through Safety for an SCCA Track Day, the car has to have a battery tie-down and battery terminal covers.
What have people done for the battery tie down for a 240? Nothing I've seen is going to work without some modification to it anyway.
Florida Chapter VCOA
DD Ranch is offline   Reply With Quote
Old 09-20-2022, 11:35 PM   #2
sloopy
2-digit whp
sloopy's Avatar
I don't know anything about scca rules, but I'll share what I've done with my small lithium battery. I removed the battery tray which leaves you with a nice little metal platform which I laid some adhesive-backed rubber strips on. Then I made a simple bracket and put a rubber strip on that. I held it down with these nice j-hooks which have flat edges and they grab onto the battery platform's edges perfectly.
https://i.imgur.com/myQk25K.jpg
But then I decided to just go with a cam buckle strap. I laid two layers of duct tape on the battery platform's edges to prevent abrasion against the strap.
https://i.imgur.com/82Uk2NU.jpg
1992 volvo 240 wagon: black
> engine: b230f, a-cam, tube header
> drivetrain: m47ii, 4.10 gear, wavetrac lsd
> front suspension: bne coilover, 200 lb/in spring, koni sport damper, bne qsrc v2, bne strut mount, 23 mm bar
> rear suspension: lesjofors 131-188 lb/in spring, koni sport damper, 19 mm bar
> wheel: 15x7 multi-x
> tire: 225/60R15 bfgoodrich radial t/a
> misc: 6 lb lithium battery
sloopy is offline   Reply With Quote
Old 09-21-2022, 02:00 AM   #3
rb92673
For endurance racing we use J-hooks or threaded rods, through the sheet metal with a solid metal strap on top. The battery should also not be able to slide around.
Something like this. https://bangshift.com/bangshift1320/...-on-the-cheap/
Old 09-21-2022, 07:54 AM   #4
I.M. Weasel
I just welded 3/8" all thread in and made the top with wide metal strap material with a piece of rubber under it.
Living life one day at a time. Stopping to smell the oil slick beneath my Volvos.
Old 09-21-2022, 12:38 PM   #5
culberro
culberro's Avatar
I used an old motorcycle chain, some angle iron, and a long bolt to make a hold down. It wrapped around the battery and tray, and held it all together. This was years ago, and I wish I still had it!
Head work: https://forums.turbobricks.com/showthread.php?t=349975
Temp Sender Adapters: https://forums.turbobricks.com/showthread.php?t=348169
Old 09-21-2022, 02:49 PM   #6
122power
dude
122power's Avatar
I have a plastic box with a metal bar across the top of battery. Long bolts hold it down to nuts welded on floor. While doing a race it came loose. - i didnt install it this way. The battery moved just enough to weaken the welded nuts and break free. Yikes! So if you use a box, secure the box to the floor, and then battery seperate.
The bottom my box wasn't secured but is now!
Save the Volvo's.
Ring,ring,ring
"Hello"
"Do you work on Volvo ...
*Click - bzzzzzz*
Old 09-21-2022, 05:36 PM   #7
Cwazywazy
Single jingle
Cwazywazy's Avatar
Ratchet strap
Old 09-21-2022, 06:30 PM   #8
Here's the FancybrickersTM solution:
I hate the car and also cannot be free of it. I dream of having a different project but cannot separate myself emotionally from this one and so remain bonded to it like Sisyphus to his great stone.
Old 09-21-2022, 08:44 PM   #9
DD Ranch
DD Ranch's Avatar
Yeah, that one's way too sexy for just one day!!!!
Seriously, thanks for all the suggestions, guys. Very helpful.
Old 09-21-2022, 09:00 PM   #10
Quin
ಠ_ಠ
personally i like a wingnut on a battery tiedown. i would be very annoyed to get caught without a torx bit or whatever in a moment where i need to yank the battery.
Originally Posted by apachechef View Post
have you tried searching over on the turbobricks forums? a lot of jerks there, but some good info
Quin is online now   Reply With Quote
Old 09-22-2022, 01:39 AM   #11
cosbySweater
cosbySweater's Avatar
Rachet strap
1992 GMC Typhoon
1995 Porsche 993
2006 Mercedes E320 CDI
Old 09-23-2022, 04:56 AM   #12
rearwheelpeel
Slow Learner
rearwheelpeel's Avatar
rearwheelpeel is offline   Reply With Quote
Old 09-23-2022, 11:43 PM   #13
Jack
junkman
Jack's Avatar
^almost like a big zip tie
I love you even more Jack.
Old 09-24-2022, 03:03 AM   #14
2manyturbos
A ratchet strap is even allowed for Autocross. I doubt it will pass tech for a track day. Accordind to the rules here, any flexible hold down method is unacceptable.
https://timetrials.scca.com/pages/full-safety-rules
