Old 11-10-2021, 01:23 PM   #1601
Finished the engine bay last night. Put on a 2mm spacer behind the water pump pulley (and scratched the paint, as I’m wont to do). Swapped in some Yoshifab timing gears, and replaced the idler pulley, as there was some noise coming out of that area. Hoping that solves that.
One of the captive nuts on the firewall was stripped, so I also spent an entire hour installing a helicoil and some studs to limit wear in those areas.
That reminds me the rear control arm captive nuts need to be replaced. I really don’t want to think about that right now. Crap.
Anyway, pictures. Bonus mouse turd content at the end. Yum.
Old 11-10-2021, 02:36 PM   #1602
Old and boxy but good.
One of my favorites. Thanks for the mouse turd! My first 242 was this color and I've always regretted selling that car.
1982 242 turbo. 338k miles. MVP/ BNE coilovers and 3" exhaust. Flowed 405 with a V15T. Cossie turbine housing with upgraded compressor housing. With wildly uncontrolled wastegate. 90+, IPD remote oil filter. Some other goodness, too. Restored in 2k. Now ready for a 2nd restoration.
Old 11-10-2021, 02:40 PM   #1603
Stiggy Pop
Stiggy Pop's Avatar
I'm up to five cars registered now and nowhere to commute to... mouse turds have become a huge part of my car "maintenance".
Our XC60 was putting out a burnt popcorn smell and I'm pretty sure something was putting acorns in the muffler.
'79 242
943 pickup
Old 11-11-2021, 03:39 AM   #1604
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
uh.. so nice !
Old 11-11-2021, 07:17 AM   #1605
propav8r
F*ck Edgar
propav8r's Avatar
Looks sharp
Originally Posted by 1968 volvo View Post
Tb's ot is a great place full of happy people who want to be your friend. The content of ot is always wholesome and no one ever gets angry or upset. Ever.
My Project
K-Jet to Megasquirt Article
Old 11-12-2021, 09:22 AM   #1606
Old Iron
I Roll
Old Iron's Avatar
Gosh this is cool.
Turbobricked
Originally Posted by Anonymous View Post
No sarcastic replies from Redwood Chair necessary
Old 11-15-2021, 06:55 PM   #1607
Originally Posted by MadDog_945 View Post
uh.. so nice !
Originally Posted by propav8r View Post
Looks sharp
Originally Posted by Old Iron View Post
Gosh this is cool.
Thank you all for the kind words!
Managed to accidentally get some work done on Sunday. Got the seat brackets re-did and the seats installed. Should have probably painted them, but that will be a job for future Harald to do...once they are nice and covered with surface rust. The seats are temporary until I get around to fixing a set of LSCs that have been languishing for (quite) a few years.
So yeah, started it, adjusted base ignition timing, crossed items off list. I think it's ready for its first test drive.
BTW I'm really starting to itch for MIG wire and shielding gas. Cleaning slag and spatter is getting old.
Old 11-15-2021, 07:52 PM   #1608
Tfest
Hipsters ruin everything™
Tfest's Avatar
I look forward to racing you at PIR this spring.
Lifted 240 Build Pages
TB Build Thread
Instagram Page
Tfest is offline   Reply With Quote
Old 11-15-2021, 07:52 PM   #1609
Tfest
Tfest's Avatar
Which would be ****ing hilarious because my car is ****ing stupid.
Old 11-15-2021, 07:54 PM   #1610
Tfest
Tfest's Avatar
how many hrsprs do you think you'll have? I'll have around 330
Old 11-15-2021, 07:57 PM   #1611
Pie in the sky would be 400whp on 92 and 500 on E85 with this setup. Probably not, on account of the exhaust manifold though.
Old 11-18-2021, 01:16 PM   #1612
Sometimes (read:very often) I do things that are detrimental to my own mental wellbeing. This is one of them. My new crankcase ventilation system works too well at ventilating and resulted in a whole lot of oil getting sucked into the intake manifold, resulting in copious amounts of smoke and many dirty looks around the neighborhood. It was bad. Like, worse than Seafoam smoke bad. Like fogged an entire street block bad.
I have talked to Tom (The Full Banana), who has one working successfully. I will be reducing the hose diameter from the intake manifold from 19mm to 10mm, and will experiment with using a check valve and a proper PCV valve. I'm also tossing the fibrous filter element in favor of a stainless steel basket and adding a drain check valve.
Old 11-18-2021, 05:08 PM   #1613
Tfest
Tfest's Avatar
Good idea on that vid, I'm uploading my smokeyboy now.
Old 11-19-2021, 06:14 PM   #1614
towerymt
the real Towery
towerymt's Avatar
Gross Polluter II
Old 11-20-2021, 01:37 PM   #1615
Ostensibly found the error in the way I set up the system. Plan is to run an old Corolla PCV valve (all stainless, 10mm barbs on both ends) to restrict flow to the intake manifold. Additionally, a drain check valve will be added.
If anyone knows a Mann+Hummel distributor in North America, please let me know. I can only find them in Australia and the UK.
Old 11-20-2021, 04:28 PM   #1616
cosbySweater
cosbySweater's Avatar
I like this visual. Is the drain to the block connected with 2 90s? Also I still think you should cut the drain hose and get a bigger hose on there for this to work you want as little bends and as much fall as possible and based on where everything is sitting it doesn't look like it's going to work right unless you put a scavenger pump (which I think is better anyway) inline
1992 GMC Typhoon
1995 Porsche 993
2006 Mercedes E320 CDI
Old 11-20-2021, 05:16 PM   #1617
The actual flow path is actually pretty direct. I drew it that way to make the graphic as clear as possible.
The next oil pan is getting a boss welded on to help things.
Old 11-20-2021, 08:02 PM   #1618
cosbySweater
I take it youve never done a leach field.
Old 11-30-2021, 01:30 PM   #1619
Most of the time, when things go wrong, they are my mistake. I make mistakes often. This one, however, is completely unexpected.
To back track, I ended up resolving the exhaust smokiness issue. Replacing the -12 line with a PCV banjo bolt and a PCV valve off a 70s Corolla seemed to resolve the oil siphoning nonsense. The entire exhaust system came off for a power wash. Unfortunately, there was not enough time to run the engine to evaporate the excess water soaked in the mufflers before the next issue reared its head.
While on the stands, a rather large puddle formed itself in no time. Upon further inspection, it became clear that the leak was coming out of the back of the cylinder head. Cursing the stupid valve cover gasket, I set on tearing things down. The result was a bit surprising: rear plug got blown out, and the retainer plate holding it in was blown out as well. What would cause this? Why a broken camshaft thrust pad! Duh! Fortunately I do have some spares sitting around, so downtime should be minimal. I will miss the top end of the fancy race cams…
I have a set of car cams, a set of PZs, and some leads on extra car cams. Plan is to run either car or PZ cams for a while, see about getting this 276* intake cam fixed, sell those and the pentas, turn in as many cores as possible to Yoshifab, and install a set of the more turbo friendly 272s.
As for addressing the cam breakage issue, hopefully it’s simply a matter of filling the distributor slot to deal with the stress riser and add a little bit of strength back.
Old 11-30-2021, 01:48 PM   #1620
Swedbrick
Swedbrick's Avatar
If you are going for a set of regrinds, potentially you could use 2 without the slot right?
Volvo 363 - N/A, Speeduino, GSXR ITB's, half-cage, work in progress
Old 11-30-2021, 01:57 PM   #1621
That's correct. Trick is finding 2 orphaned exhaust cams.
Old 11-30-2021, 02:19 PM   #1622
If you are having cams reground. Can't you have the 8v cams reground for the 16v engine? They are the same cam castings for both. Alternatively, maybe IPD would sell you an unground billet?
Old 11-30-2021, 02:29 PM   #1623
Can't regrind 8v cams to 16v pattern. The lobes are at different angles relative to each other. You could weld a bunch of material, but in the end the process becomes very expensive.
On the billet cams, potentially, but it really depends on whether the final machining happens at the vendor facilities or not, and how willing they are to stray from a standard work order.
Old 11-30-2021, 02:53 PM   #1624
Oh well it was a good thought anyway. I will go look in the barn. I have a 16v head and I think the cams are there with it. What marking am I looking for so I know it's the exhaust?
Old 11-30-2021, 02:55 PM   #1625
It's the one without a slot
