Old 06-01-2021, 11:26 PM   #1
76RA24
Default 1990 245 (millennial falcon)
I have been polluting the VanCity volvos thread with my updates... figured i should just do a thread.
brief history.
bought wagon in 2015 for 600$ approx. 390,000kms
day1 with dads 740
some issues.. bad alternator, no valve cover gasket, exhaust leaks, no guibo joint
leaky fuel pump
Guibo whats that
good points were it was manual rwd wagon.
swapped alternator at farm proceeded to drive 30kms home with no guibo and virtually no valve cover gasket... smokey.
ordered parts from ipd some were bought local.
got the car on the road proper in a couple weeks..
lots of road trips for work ... lots of miles put on had to install some Moog overoad springs
installed Mazda 3 seats at some point
popped a head gasket on my bday one year downtown Van that was fun towed back to mission for dirty replacemnet
re-did headgasket couple months later proper.
at some point I put in a G80, met a Levion at the auto recyclers..
many suspension bushings... some failed new ones. dont buy cheap.
did bilsteins HD, new brakes
need new strut casings mine were 90 with the welded spacer
new ones were still crusty
My old springs were done... the other struts came with better springs.
but got it all cleaned up.
pretty much brings me to now when i had a week off to look for a water leak and ended up cutting rust.
that was 4 months ago...
still finding more.
here is rust repair gallery.
https://imgur.com/a/Zqiu9gK
76RA24 is offline   Reply With Quote
Old 06-02-2021, 09:29 AM   #2
Scaramanga
Impressive work with the rust repairs! Well done!
145 - 1972 / 245 GLT -1991 / V90 D3 AWD -2019
Scaramanga is offline   Reply With Quote
Old 06-02-2021, 10:11 AM   #3
kyote
Living The Dream
kyote's Avatar
IMGUR blocked at work but props on the name
-06 Camry SE 2AZFE
-14 F150 FX4 3.5 EcoBeast
What Kyote sez, more or less
Old 06-02-2021, 10:22 AM   #4
76RA24
How the hell does Rust start here....
seems to never stop... photo dates accroding to phone say i started this about 4months ago.
Old 08-20-2021, 11:49 AM   #5
76RA24
progress has been slow.
I dont like working in the heat. give me the single digits temps again.
rear inner using the weldthru copper stuff... I dont like it as much as the weld thru zinc. but the zinc was sold out at local shop.
dressed down and sealed.
working on the replacement buttcheek
might be the last hole on the inside of the car.
still not sure how I want to address that hole in rear upper crossmember.
I feel like dropping the tank and lowering the axle will be my best method to reach... but getting really tired of not having the volvo on the road.
Old 08-22-2021, 12:04 PM   #6
RedlineDave
RedlineDave's Avatar
What year Mazda seats? Easy swap or wielding required?
RedlineDave is offline   Reply With Quote
Old 08-22-2021, 01:31 PM   #7
76RA24
2004-2005-ish seats.
will take some pics of the base since the seats are out.... dont recall any welding.
I did have to drill out some big rivets to remove the mazda sliders and removed the side airbags...
filled the void with some EVA foam
I am using the original Volvo sliders.
Old 08-23-2021, 01:20 PM   #8
76RA24
Mazda seats...
made flat steel plate adapters..
weld one rust hole...
two more appear.
fun times....
Old 08-23-2021, 01:56 PM   #9
MCHN8
Great work, and "millennial falcon" is just an awesome name.
MCHN8 is offline   Reply With Quote
Old 08-24-2021, 11:22 AM   #10
76RA24
tackled the cross member rust hole...
also where the hell does the water get to this part to rust it out?
Old 09-03-2021, 01:02 AM   #11
76RA24
Well interior floors done.
Rear butt cheek replacement.
Fun is coming to an end.
Old 09-09-2021, 11:33 PM   #12
76RA24
Went slow
Ran out of welding gas again.
Now to deal with some other crusty bits.
All “seems” like surface rust.
Old 11-12-2021, 03:43 PM   #13
76RA24
got the rear belly pan rust stripped and converted...
went on the front fender and bent lower grill valance...
was not impressed that it was bolted and spot welded..
Old 12-22-2021, 03:14 PM   #14
76RA24
painted pretty.
thinned tremclad with acetone and sprayed.
Local parts shop mixed some rattle can silver using the gas door a color match.
still need to put some clear over it... though.
coming along...
got some parts ordered that will be stuck in the US as border crossings became a testing issue...
Old 01-12-2022, 02:06 PM   #15
76RA24
still trying to get some parts across the border...
applying some sound mat.
slow progress but progress.
Old 01-14-2022, 02:36 AM   #16
76RA24
AC mostly removed
Heater control valve swapped.
Will clean and lube the heater fan since dash is apart
Old 01-20-2022, 10:20 PM   #17
76RA24
finished the AC removal.
put some clear on the passenger fender... should be ready to bolt back on this weekend.
Old 02-15-2022, 10:24 PM   #18
76RA24
reassembly.
front bumper bit tweaked.
Dont remember if this came from the volvo or not?
any one have ideas?
looks to be a dead pedal... maybe from the wifes mk4 VW
Interior has sound mat installed..
one layer roofing stuff another layer of vinyl flooring insulation I had from a reno.
Power washed carpets... washed the mazda 3 seats, new seat heaters.... so close.
Old 02-17-2022, 03:00 PM   #19
76RA24
printed up a template to drill holes for power mirrors.
also printed some heated seat blanks for the aftermarket heated seats. will probably paint black when ready to install
Old 02-17-2022, 07:55 PM   #20
threewagons
i am the liquor
threewagons's Avatar
Good job on the rust repair!
Get some 3m cavity wax and the wand kit and blast it everywhere you can, especially where you welded, and it should last a long time
threewagons is offline   Reply With Quote
Old 02-18-2022, 03:07 AM   #21
Scaramanga
Well done! Keep it up
Old 02-18-2022, 06:23 PM   #22
Old Iron
I Roll
Old Iron's Avatar
I love how thoroughly your going through this one! Keep up the good work. Good save.
Turbobricked
Originally Posted by Anonymous View Post
No sarcastic replies from Redwood Chair necessary
Old 03-01-2022, 12:03 PM   #23
76RA24
think your done with the welder.... nope.
Left.
Right
3D printed the front speaker housings for 5.25" speakers.
didnt have any heavy poly for the water sheilds things on the doors so used more foam stuff.
and brace all the old speaker holes with more 3d print
should have printed a bit thinner but ohwell...
fronts got some aluminum braces
Might have to look for door cards in the future.
Old 03-07-2022, 02:15 AM   #24
mblue240
mblue240's Avatar
any one have ideas?
Goes left of the clutch pedal, covers up all the wires that run down the firewall under the A pillar.
Old 03-07-2022, 11:50 AM   #25
76RA24
Just got it fitted last night!
carpets and adash are back in ... progress.
