Old 04-04-2021, 05:50 PM   #26
Old Iron
I Roll
Old Iron's Avatar
Ya. I went to NAPA, ACE and tractor supply, no one had the correct size Cleve’s pin!
Turbobricked
Originally Posted by Anonymous View Post
No sarcastic replies from Redwood Chair necessary
Old 04-06-2021, 12:36 PM   #27
Old Iron
I Roll
Old Iron's Avatar
Thanks for all the help. Finally found a spare Clovis pin.
Old 04-06-2021, 08:01 PM   #28
283SD
Clevis pin is what they are called.
Old 04-06-2021, 08:36 PM   #29
A Clovis point is one f the styles of projectile points made in North America around 13,000 years ago.
Old 04-11-2021, 05:23 PM   #30
Old Iron
I Roll
Old Iron's Avatar
Auto correct. And lack of proof reading. Tell that to Siri! ��
Old 03-25-2022, 08:52 AM   #31
Old Iron
I Roll
Old Iron's Avatar
Old post recycle, is the transmission mount the same between m47 and AW auto’s? All I see different on this one is the style of spacers or bushings they the m47 one has. Does the auto one work the same just moved up closer to the engine in the next set of prescribed holes on the underside of the car?
Old 03-26-2022, 09:58 AM   #32
Old Iron
I Roll
Old Iron's Avatar
Also, it this the only wire I need to make up to trick the car into thinking it’s in park and not neutral?
File Type: jpeg 6518949F-CE08-4B9B-AE72-422954E6A50A.jpeg (94.0 KB, 32 views)
Old 03-27-2022, 07:58 PM   #33
Old and boxy but good.
Yes, you only jumper the one wire. The trans mounts are different but can be interchanged. The automatic one is similar to what is used for an M46. The small rectangular mount for the M47 is a bit smaller than the other mounts.
1982 242 turbo. 338k miles. MVP/ BNE coilovers and 3" exhaust. Flowed 405 with a V15T. Cossie turbine housing with upgraded compressor housing. With wildly uncontrolled wastegate. 90+, IPD remote oil filter. Some other goodness, too. Restored in 2k. Now ready for a 2nd restoration.
Old 03-28-2022, 11:55 AM   #34
spock345
spock345's Avatar
I couldn't find a decent durometer mount for my M47 that wouldn't become floppy within a year. A 164 motor mount fixed the problem. Although it transmitted slightly more vibration to the cabin.
So there is another option. I think that is a worthy trade off to keep the shifter from bouncing all over the place on a bumpy road.
1998 S70, grandma-mobile
1980 245
1989 240 B230F, V15 cam, chipped EZK, M47 swap (Lost a fight with a Chevy express van), the millennial falcon
