Old 09-04-2008, 07:25 PM   #1
Patdon10
Patdon10's Avatar
Default M46 = m47 driveshaft?
I have an AWful70 installed in my car, and I plan on converting to an M47.
I was going to try to find the front half of the drive shaft from a 240, but if I can't find one, can I pull one that has an m46?
The 245 Restoration.
http://forums.turbobricks.com/showthread.php?t=132952
Buyer/Seller Feedback
http://forums.turbobricks.com/showth...light=Patdon10
Originally Posted by adrianpike View Post
You cannot reduce a Volvo's value, as they're already worthless.
Patdon10 is offline   Reply With Quote
Old 09-04-2008, 07:27 PM   #2
wildmanben
wildmanben's Avatar
I think the answer is no, but I'll let someone else tell you for sure.
Edit: not even all of the 240's with M46's have front half driveshafts that are compatible with other 240's with M46's, so for at least some 240s the answer is definitely no.
Project: 1983 244, B23F+T, 10.3:1, 15 psi, A cam, MSnS-E
Company: Southern Dynamics Consulting. We specialize in data analysis, instrumentation, and monitoring solutions for heavy machinery.
wildmanben is offline   Reply With Quote
Old 09-04-2008, 07:29 PM   #3
Patdon10
Patdon10's Avatar
is this because of a length issue or a yoke issue?
Old 09-04-2008, 07:31 PM   #4
fredsanford740t
fredsanford740t's Avatar
I think the front half of the d/s may be shorter for the M46 due to the overdrive (5th gear) box. The 47 does away with the latter part of the o/d and incorporates 5 true gears.
To be safe just find a complete donor car with all the parts you need and you will have the correct d/s.
Anamorphic Equalizer_ Line-Xesque paint_ M47_ Auto Meter A/F Ratio, Boost, temp_ Tethys_ Racing seats _ GT steering wheel_ 2.5" drop_ 242 GT intake tube_ Python 871XP_ Rebuilt, ported, 10* clipped 42/48 trim Garret_ ported/milled 90+ manifold_ 3" V-band Turbine outlet_ Porsche BOV_ Ported, polished, grooved 530 head_ Stage 3 Clutch_ 20lb. Flywheel
fredsanford740t is offline   Reply With Quote
Old 09-04-2008, 07:52 PM   #5
Tick
ASSFACEHOLE
Tick's Avatar
You can use the rear section of the m46 shaft but you'll need an m47 front half.
67' 220
84' Honda sabre v65
85' Ford Econoline E350 Box Van
90' 740 16v
90' 740 turbo (parts)
00' xc70
Originally Posted by Disco Inferno View Post
**** you, filthy ****ing non-smoker. I hate your type, and when I see you coming I intentionally exhale strongly in your direction.
Tick is offline   Reply With Quote
Old 09-04-2008, 07:55 PM   #6
Karl Buchka
The M47s I've pulled out of 240s have all had guibos between the tranny and the driveshaft, whereas every M46 I've pulled has been a direct bolt on deal.
You're probably going to need an M47 specific front half.
Old 09-04-2008, 08:29 PM   #7
500dollar744ti
still rides with MrDoug
500dollar744ti's Avatar
later m46's have guibos as well, like 1985+ or something, well at least on 740's... either way the front part of the driveshaft is diff than the m46 and the shifter cage is different.
-Matt
1989 Volvo 744T- 16v turbo, '94 FD-block, RSI pistons/rods, GT35R, Tial 38mm, RFL, MSnS-E, DSM spark, 100lb Delphis, 4.6 springs, Bondo header, Heebspeed intake, Q45 90mm TB, Bosch 044 FP, 12x24x3 ebayIC, w/c t5, Clutchnet 4puck/PP, 4.10 G80, IPD sways, 960 brakes.
1998 Volvo S70 T5m- Stock, 229k
1998 Jeep Cherokee XJ- Stock, 154k
1983 Ford F150- '89 5.0 H.O, C6/4x4, F+R LSD 4.10, 7" lift, 35s.
1990 Cobia San Marino 225 ECS- MCM 350 Mag, GM Bowtie Intake, HR-Titan 19p.
500dollar744ti is offline   Reply With Quote
Old 09-04-2008, 10:50 PM   #8
Old and boxy but good.
You could get by with only getting the front section for the M47 driveshaft. But it would be more ideal if you got the complete M47 driveshaft. That's because the rear half of an M46 and the automatic driveshaft has a rubber insert and is a pressed together back half section. The back half of an M47 driveshaft is solid with the rubber guibo joint up by the transmission doing the job of absorbing driveline shock.
1982 242 turbo. 338k miles. MVP/ BNE coilovers and 3" exhaust. Flowed 405 with a V15T. Cossie turbine housing with upgraded compressor housing. With wildly uncontrolled wastegate. 90+, IPD remote oil filter. Some other goodness, too. Restored in 2k. Now ready for a 2nd restoration.
Old 09-05-2008, 08:36 AM   #9
wildmanben
wildmanben's Avatar
The flange was the problem, not only was the bolt pattern different but the flange wasn't the right thickness, which made the driveshaft the wrong length. We ended up putting a different flange on the transmission to fit the driveshaft.
Old 09-05-2008, 08:42 PM   #10
Kjets On a Plane
Kjets On a Plane's Avatar
No guibos on 240 M46s, even 86 cars, interestingly.
Interestingly, 84-86 740/760 with J-type overdrive have a plug and the speedo gear already installed in the tailhousing. You can remove the plug and install the speedo cable fitting/worm gear from a 240, but 86 240s have no plug and an undrilled boss in the tailhousing for the cable speedo. Makes things interesting when putting an 86 240 M46 in a 78 car having to update the reverse and OD wiring and put a different tailhousing and gear on it. Managed to get the job done in 6 hours, but it was a bit of a learning experience and involved pressing a couple bearings and swapping a tailhousing. I knew about the reverse lamp change, circular flange diameter change for the small driveshaft, and 4th gear switch/shifter bracketry changes going in and knew that would add some time, but the undrilled boss for the speedo cable on a J-type OD was a new one.
You should get the whole driveshaft form an M47 240 for an M47 240 honestly. The parts and u-joints will match, you get the stronger 2.5" rear section on the late model cars, and it just fits. In a pinch, the large diameter rear half from an M46 car can be used and still use the same support bearing if you gotta ship one i guess.
How PSI a stock can support?
Always Be Crushing!
Old 03-11-2022, 05:30 PM   #11
Old Iron
I Roll
Old Iron's Avatar
Curious to know if I can use the back half of an aw70 driveshaft with the front half of an m47 driveshaft for my m47 swap. Will it cause any vibration issues or noises? Are they the same between both setups?
Old thread recycling.
Turbobricked
Originally Posted by Anonymous View Post
No sarcastic replies from Redwood Chair necessary
Old 03-11-2022, 07:01 PM   #12
esmth
I'm using the back half of an aw70 driveshaft with an m46 front shaft. No perceptible vibration difference for my mix-n-match. At least for M46 the rear shaft has the rubber damper, where the aw70 shaft didn't. I think for the m47 the giubo takes over that job. I would think they would work together but cannot confirm.
1991 244 LH3.1 M46 402k miles
Old 03-12-2022, 01:11 PM   #13
white855T
You can do it but won't know if you have vibrations till you install it. But it's much better to just get the 2 pieces.
Old 03-16-2022, 06:59 AM   #14
Otto Mattik
board member
Otto Mattik's Avatar
On my old 92 m47, the rear DS section is larger in diameter(I can measure if someone needs the diameter).
