Old 07-04-2017, 12:37 AM   #476
Coupid
Coupid's Avatar
When I was reassembling the intake and headers I put the throttle linkage on so it was rotating backwards and wouldn't snap back when I released the gas pedal. In the process of figured that out I lubricated every pivot point including where the shaft goes into the firewall. When I went to drive to Cars and Coffee this weekend the shaft slipped out on the freeway. I had enough momentum to exit the freeway and put the shaft back in the plastic grommet in the firewall. Luckily there was a hardware store and I was able to secure it with hose clamps:
I've spent the last day trying to figure out what the thing that is supposed to hold the rod in place is called. FINALLY after a ton of googling I figured out it is a shaft collar.
Does anyone know if it is 5/16 or 3/8?
I just ordered a travel tool kit and am really tempted to drive the Volvo when I go to Car Week in Monterey next month.
1988 745T http://forums.turbobricks.com/showthread.php?t=356096
1972 142S http://www.turbobricks.com/forums/sh...d.php?t=311926
1991 780 Sold
1979 244DL Sold
1986 740+T Sold
1983 242T Sold
Old 07-04-2017, 12:55 AM   #477
The Librarian
The shaft is 5/16".
http://www.piercemanifolds.com/product_p/99024.350.htm
Had you known you needed them, I could have sent them with the studs and washers.
Old 07-04-2017, 01:09 AM   #478
Coupid
Coupid's Avatar
The shaft is 5/16".
Thanks Ian!
Old 07-09-2017, 03:24 PM   #479
Coupid
Coupid's Avatar
The shaft collars arrived and I replaced the janky hose clamp setup. The hose clamps worked fine when I drove to cars and coffee and around town this morning but the collars are way more stable
My latest piece of craftsman tool storage showed up so I put the garage back together again as well!
Old 07-19-2017, 12:26 AM   #480
Coupid
Coupid's Avatar
Went a little too fast over a speedbump at cars and coffee this weekend. Here is the end result:
Easy fix and I happened to have a spare in inventory!
I really need to raise the front of the car but I don't want to dig into the front springs for the 5th time.
Since I was down there I decided to pull the mid part of the exhaust off, recut the end near the headers so it was flush under the adaptor and then exhaust sealant it all back together. I have been fighting a small exhaust leak where the header connects to the exhaust and I think I finally got it since this time everything was loose and I tightened from front to back.
Old 07-19-2017, 01:12 AM   #481
LloydDobler
LloydDobler's Avatar
You don't need the shaft collars if you mount the little arm on the other side of the carb linkage, up against the bearing (where the collar now is). hehe. I did the same thing when I had a weber kit years ago.
Great car, keep posting.
'66 122 - Collectible project
'06 V70 2.5T - Mostly Stock Daily Driver
'03 C70 T5M - Modded summer fun car
'05 V50 T5 AWD - Daughter's first car
LloydDobler is offline   Reply With Quote
Old 07-19-2017, 01:49 AM   #482
Coupid
Coupid's Avatar
I had to keep rereading and looking at my photo but now I totally see what you mean. The clamp off the little arm would keep the rod in place. Just need to rotate it 180degrees. I will probably leave it as it is until the next time I have to disassemble the carb/intake stuff. With the collars in place many more parts would need to fail or fall off for the shaft to slip out of the firewall.
Old 07-20-2017, 11:05 PM   #483
Coupid
Coupid's Avatar
The original owner spent a whole bunch of money tricking out the stereo in the 80s since she was dating a guy who liked speakers. The fronts are super blown but I didn't want modern looking speakers in there. Yesterday I got the bright idea to pull the old drivers out and put in something new.
Old
New
Done
Will probably do the same to the 6x9s in the rear deck since that was so easy
Old 09-22-2017, 12:35 AM   #484
Coupid
Coupid's Avatar
quick update:
Old 11-12-2017, 02:05 PM   #485
brickcupra
hey congrats on your wedding and superb build!!!
I always liked that body style since i saw one back in 87 in Puerto Rico.
I am working on a 92 wagon 240 and It might take light years away to finish it at the pace im going with trial and error.
Stay warm as winter is creeping fast here in Windy Chicago
DZ
Old 11-14-2017, 09:52 PM   #486
JCol91
Macaracachimba
JCol91's Avatar
Must've been a beautiful sight back in '87. I long for the day to see one running and hopefully with a for sale sign! Nowadays they're unicorns.
DZ
'95 855 Turbo - SOLD
'93 244 N/A - 18" Eikers, IPD Sways, Torque and Panhard rods, GT Style Braces, Eibach/Lesjöfors? Red Springs, Bilstein Tourings, M47
IG: @stock_bricks
Flickr: @JCol91
JCol91 is offline   Reply With Quote
Old 11-18-2017, 01:44 AM   #487
240keith
Floats your Boat
240keith's Avatar
car looked dang good last weekend bud!
-Black on Tan-
225, XXX Miles!
-B cam-
Single Rounds / Flathood
Originally Posted by Mr.Borrie View Post
Is this real life?
No.
This is TB.
240keith is offline   Reply With Quote
Old 01-05-2018, 12:30 AM   #488
Coupid
Coupid's Avatar
Big update:
I made the mistake of poking at the rust in the driver's side rocker panel...
What a stupid mistake that was!
It made me really consider my options and after some deliberation I decided to sell the car. I had test driven a Porsche 944 and was convinced this was a good path forward.
There was some interest in Buttercup but no one pulled the trigger.
Tonight I was thinking about my options and realized that I had a third option. I am going to sell the wheels, buy some steelies or virgos and use the difference to start the bodywork or improve the front suspension and brakes.
My dream with the 944 was to drive up to Pebble this year and all around the state. Tonight as I was driving Buttercup around for the first time in a month I realized there was no reason I couldn't do that in the Volvo. It would also be a lot more reliable and easy to maintain myself.
Disaster averted!! I'm looking forward to the next steps and glad I get a second chance.
Old 01-05-2018, 12:42 AM   #489
Cwazywazy
Single jingle
Cwazywazy's Avatar
Good to hear. Can you buy replacement rockers to weld in?
I don't know what I have
Old 01-05-2018, 12:58 AM   #490
240keith
Floats your Boat
240keith's Avatar
Originally Posted by Coupid View Post
Big update:
Disaster averted!!
Im glad you figured this out before you sold it ...
next time I see you, ask me about Dave ... hed be a good guy to talk to about the rockers ...
Old 01-05-2018, 01:36 AM   #491
Coupid
Coupid's Avatar
Me too Keith! Thanks I will ask next time
Old 01-05-2018, 02:14 AM   #492
Vol242vo
Keep it clean...
Vol242vo's Avatar
Right on, nice to hear.
Derek
1 Owner - 85k mile 1980 242
-Project Thread-
Follow on IG: @vol242vo
Old 01-05-2018, 02:03 PM   #493
MoCounselor
MoCounselor's Avatar
You made the right call, Colin! Glad to see that buttercup will live on in your care!
MoCounselor is offline   Reply With Quote
Old 01-05-2018, 02:12 PM   #494
Tfrasca
Tfrasca's Avatar
I have some 15x5.5 164 wheels with good tires. I bought them new from VP when I got the car on the road a couple years ago, and only used them for 6 months or so.
Old 01-05-2018, 06:06 PM   #495
sksmith
sksmith's Avatar
Glad to hear you're keeping her!
FYI - New rockers are available.
Old 01-05-2018, 11:29 PM   #496
Coupid
Coupid's Avatar
Thanks guys!
That is tempting, someone was interested in the Gottis and had the same wheels to potentially trade. If that falls through I would be interested.
Does anyone know if I can use steelies off a 240? They should be fine but 140 wheels wouldn't fit on a 240 if I am thinking about this correctly.
Yeah, I know I have seen them on VP and even EBay from time to time. The challenge is that I don't have a welder, grinder or any of the requisite skills.
I ordered all new bushings, tie rods and ball joints for the front end today. The plan is to replace all that, possible raise the front a little or lower the back end more. I also ordered an adjustable FPR from Malpassi for the eventual DCOEs.
Excited to see where this all goes!
Old 01-06-2018, 12:13 AM   #497
240keith
Floats your Boat
240keith's Avatar
Ive got a set of 240 steelies if you want / need to try - loan is free - sale is cheap..
Ive also go some sawblades
Old 01-06-2018, 12:46 PM   #498
- Stock PSI Or Bust -
Yes but 14's don't really work well on 140's and they'll have 20 mm of poke / wrong offset.
Late 140 wheels bolt up, early ones don't, again the offset will be goofy without spacers.
how psi stock cna sprout?
Old 01-06-2018, 11:06 PM   #499
Coupid
Coupid's Avatar
Good point, I'll hold out for 140 wheels or just hold on to the current wheels.
Old 01-08-2018, 11:22 AM   #500
NO_SPRK
ihazkoolaid
NO_SPRK's Avatar
i have a few sets of 164 wheels.
even a rare 1yr only 5.5" wide wheel set in a et25 offset. they will poke a little but look soo nice with the deeper dish
69' 145 / 73' 142 / 84' 244
Buyer/Seller Feedback
NO_SPRK is offline   Reply With Quote
