Old 03-10-2016, 01:17 PM   #251
Mikeystoy
I wanted to keep the 85 hvac system, all the controls stayed in the center panel leaving me a lot of space for outlets, gauges, etc
[IMG][/IMG]http://a67.tinypic.com/2chmkbo.jpg
85 Volvo 165
87 Volvo 244
81 ford courier
61 comet S22
61 dodge D300
2x) 71 Plymouth Crickets
82 Jeep wagoneer
71 Plymouth Satellite
73 Plymouth Satellite
58 Desoto Firesweep
67 Chevrolet C10
70 volvo 145
74 Sears custom st16
75 Sears custom ss16
Mikeystoy is offline   Reply With Quote
Old 03-10-2016, 01:19 PM   #252
NO_SPRK
ihazkoolaid
NO_SPRK's Avatar
FYI YoshiFab said he would make 140 rear trailing arm box kits if he gets around 10 orders
69' 145 / 73' 142 / 84' 244
Buyer/Seller Feedback
NO_SPRK is offline   Reply With Quote
Old 03-10-2016, 02:06 PM   #253
cwdodson88
very clean look.
The Build Thread
SVEA - PUSHROD TURBO!
Old 03-10-2016, 02:17 PM   #254
MoCounselor
MoCounselor's Avatar
Any idea how much these would be? If they are reasonable, I'd be in. :D
-Ben
MoCounselor is offline   Reply With Quote
Old 03-10-2016, 02:28 PM   #255
- Stock PSI Or Bust -
-Ben
It's just a couple strips of 1/8" thick steel.
how psi stock cna sprout?
Old 03-10-2016, 02:38 PM   #256
Tfrasca
Tfrasca's Avatar
Originally Posted by Coupid View Post
I like the original speedo a lot but it doesn't leave any room for a tach in the dash. My original cluster had a bad dimmer switch so it didn't alway light up or stay lit so I decided to kill two birds with one stone.
Hopefully I can get used to the KPH speedo but if you've been using them since '98 it can't be too hard of an adjustment. 62MPH =100KPH
Yeah these are the warm LEDs. That photo was with the dimmer turned all the way down. They get super bright but still somewhat match the rest of the interior. I'm very happy with the lighting.
Nice. In the photos I've seen, it looks like you can see the individual LED's in the reflections on the chrome bezels. Is that annoying?
Old 03-10-2016, 09:18 PM   #257
Coupid
Coupid's Avatar
-Ben
+1
I haven't driven with it since I was still sorting some of the wiring and replacing the rest of the bulbs in the dash (HVAC and clock). I got it all buttoned up a few minutes ago and took a few more photos in different light conditions for you:
Full bright on the dimmer, garage lit up
Darkest setting on dimmer, garage lights off:
The Iphone isnt doing it justice, the LEDs look awesome and arent as bright or as white as this photo suggests.
Overall I am very excited about how the interior of the car is coming together:
Just need to get the blue seats redone and it will be perfect!
1988 745T http://forums.turbobricks.com/showthread.php?t=356096
1972 142S http://www.turbobricks.com/forums/sh...d.php?t=311926
1991 780 Sold
1979 244DL Sold
1986 740+T Sold
1983 242T Sold
Coupid is offline   Reply With Quote
Old 03-13-2016, 06:29 PM   #258
Tfrasca
Tfrasca's Avatar
Thanks for the photos. I'm sending my GT cluster off tomorrow.
Old 03-13-2016, 06:56 PM   #259
Coupid
Coupid's Avatar
Can't wait to see it back on your car!
Old 03-13-2016, 07:35 PM   #260
Coupid
Coupid's Avatar
Took Buttercup on a drive to the Mullin Automotive Museum yesterday so the new cluster has over 100 miles on it now!
today I decided to tackle the clock that has been broken since I bought it. I figured there couldn't be much to it so I popped the seal off the back and took a look at the inside. This was clearly disconnected:
I reflowed the solder to it and got it connected again. It doesn't seem to be working so I will try to dig a little deeper. If I can't fix it myself I just won't have a working clock. I'm not spending $100 for one on EBay.
Old 03-15-2016, 10:55 PM   #261
Coupid
Coupid's Avatar
The clock worked for a while this evening when I was driving around. I think the connection I reflowed isn't that strong. The clock fuse is a problem with all VDO clocks so I read an article on Pelican Parts and will retry.
Even with the clock barely working I was able to buy a new bulb for it. Now I think everything is properly illuminated in the dash.
Tomorrow my Yoshifab Adjustable Torque Rods should be here along with some replacement IPD swaybar endlinks. The torque rods will allow me to pull the rear end further forward. They will center the wheels in the arches so I can take out even more of the rake. Moving the rear end forward should make the rear springs happier since they are a tad out of alignment with the mounting points.
Old 03-16-2016, 12:06 AM   #262
NO_SPRK
ihazkoolaid
NO_SPRK's Avatar
Great job on the clock. I didn't pull oNE in the JY because I was told they never work.
Old 03-16-2016, 12:15 AM   #263
Tfrasca
Tfrasca's Avatar
Looking good. I'm interested to see if you get much more NVH with the torque rods. I've been going back and forth on the Yoshifab ones or shortening stockers w/ poly bushings.
Old 03-16-2016, 12:43 AM   #264
Coupid
Coupid's Avatar
Here is the article I found. http://www.pelicanparts.com/techarti...ock_repair.htm I think Volvo VDO clocks must be "Type 1"
I'll have first hand driving experience in the next few days and obviously let you know what I find out. The whole driveline and the springs will be a lot happier I'm sure. I've heard the same things about NVH but Josh had them in stock and I'm sick of having the rear end of the car up in the air since I couldn't comfortably clear the 8 inch wide rims in the back with the rear end pushed all the way to the back of the wheel arch.
Old 03-16-2016, 11:08 PM   #265
Coupid
Coupid's Avatar
Got a lot done tonight!
Yoshifab Adjustable Torque Arms
IPD Front Sway Endlinks
First I jumped on the bits from Yoshifab. The shipping was incredibly fast and the parts are really nicely made. I jacked the car up and popped the original arms off. The new ones popped right in and then I was able to adjust them to bring the rear towards the front of the car. So smooth and easy:
The tire had about 1/2 inch of clearance to the rear of the opening until I put these on. I may have overshot a little bit and tomorrow I will look at pushing it back a little. The springs are in alignment again so I think they will be a lot happier. Instead of taking it for a drive I decided to put on the new endlinks since I was on a roll.
When I put the 28mm front sway on the car IPD was sold out of endlink kits. I ordered some bushings that I thought were similar enough. As you can tell from the photo that was pretty stupid...
Slowly but surely!
Old 03-17-2016, 09:46 PM   #266
Coupid
Coupid's Avatar
Alright got the torque arms set where I want them. With how far forward the rear end was set last night, the driveshaft was forcing the pumpkin out of alignment.
Today I centered the wheels in the arches and took it out for a spin.
As you can see I have lowered it a little more and can probably go a little lower in the back since there is more clearance in the middle of the wheel opening. I'll do that this weekend since I will then have to redo the adjustments to the panhard and torque rods.
Old 03-17-2016, 11:00 PM   #267
MoCounselor
Looking GREAT man!!!!!
Old 03-18-2016, 12:05 AM   #268
amerbritcan
Hnnnnnng
amerbritcan's Avatar
Definitely looks very raked. I typically like rake, but I do feel it'll look a lot better if you bring the back down a bit.
1990 745tic
1984 244DL (parts)
Originally Posted by My Mom
Get a bike
Poopie scissors
Old 03-18-2016, 07:30 PM   #269
Coupid
Coupid's Avatar
Thanks!
The angle of the photo might eventuate the rake. There is about another inch I can lower the rear which will make it sit roughly flat
Old 03-18-2016, 08:01 PM   #270
cwdodson88
I think it looks perfect! Great work!
looks symmetrical from the tire to the arch, I like it!
Old 03-18-2016, 08:06 PM   #271
Coupid
Coupid's Avatar
Thanks for spotting this on Craigslist Keith!
Picked it from from a guy who's uncle collected jerry cans:
A little surface rust on the bottom so I will fix that and also take the opportunity to steel wool and paint the inside of the buttcheeks
Old 03-18-2016, 08:07 PM   #272
NO_SPRK
ihazkoolaid
NO_SPRK's Avatar
you lucky dog! keep an eye out for another one.
Old 03-18-2016, 08:38 PM   #273
MoCounselor
Sweet!!!
Old 03-18-2016, 08:54 PM   #274
MikeSr.
What, me worry?
MikeSr.'s Avatar
I love that yellow-makes me miss the Banana Boat.
I coulda had a V8!
Old 03-18-2016, 09:41 PM   #275
Tfrasca
Tfrasca's Avatar
Lucky!
