Old 11-28-2007, 11:22 PM   #1
Poik
Backwards Turbo
Poik's Avatar
Default Poik's ported 530
So in preparation for the 1993 B230F that is going into my 744 to replace the tired K-block with a frozen turbo, I spent about 8-9 hours porting the 530 head that came with the engine. I gasket matched the intake, smoothed everything and worked the bowls pretty good. On the exhaust I did a decent amount of bowl work and took a bit of material off the roof. I also polished the exhaust ports. In the combustion chambers I smoothed out the pad next to the exhaust valve, slightly unshrouded the valves, and sanded and polished the whole thing.
More pictures here: www.eric-o.com/gallery2/main.php?g2_itemId=4571
Tell me what you think!
Eric Olsson's 242 Turbo | 245 DL | 744 Turbo
Poik is offline   Reply With Quote
Old 11-28-2007, 11:27 PM   #2
CAPT_BLOTTO
#Crush It
CAPT_BLOTTO's Avatar
es ok
Hello My Glorious!
Old 11-28-2007, 11:32 PM   #3
DaytonAE86
DaytonAE86's Avatar
Bigger exhaust valves??? Either way, awesome porting job, seems people go a bit crazy and take way too much out. How much are you porting the 90+??
Originally Posted by Toyotahead
exactly, 3 passengers, air con, and wu-tang at 180 mph
DaytonAE86 is offline   Reply With Quote
Old 11-28-2007, 11:32 PM   #4
DurableSwedish
Hunting for a turbo
DurableSwedish's Avatar
geeze, I could use your services to port a head or 2 for me...Whatever you'd charge would be cheaper then paying a machine shop to do that...
One Volvo left.
1982 244ti (313chp), 2011 Audi S4 (333chp) , 2016 Kawasaki 650R (76chp)
DurableSwedish is offline   Reply With Quote
Old 11-28-2007, 11:33 PM   #5
VolvoPunch
VolvoPunch's Avatar
I like it nice job. Is this your first time porting a head?
VolvoPunch is offline   Reply With Quote
Old 11-28-2007, 11:41 PM   #6
Alex Buchka
8 cylinders
Alex Buchka's Avatar
I'm gonna take a dump in one of your exhaust ports when you aren't looking.
Old 11-28-2007, 11:46 PM   #7
Poik
Backwards Turbo
Poik's Avatar
Stock valves. I haven't ported the 90+ yet, hopefully tomorrow, but as much as I can get away with, it's going to take a lot longer than aluminum! Yes this was the first time porting a head for me, I wanted to get some good practice in before I do up my 16v. Thanks for the compliments!
OH! And a BIG thanks to John (The Aspirator) for the air compressor! Works a **** ton better than my other one!
Old 11-29-2007, 12:28 AM   #8
VolvoPunch
VolvoPunch's Avatar
So have you had the head on a flow bench yet?
Old 11-29-2007, 01:16 AM   #9
Poik
Backwards Turbo
Poik's Avatar
Nope, not enough time, installing the engine this weekend. This was mainly for practice, though I do expect the head flows a significant amount more than stock. When I do my 16v I will have before/after numbers.
Old 11-29-2007, 01:30 AM   #10
Lord Tentacle
Anime Lord
Lord Tentacle's Avatar
it looks dam better than stock
Tentacle SUV 07 xc90 D5; Has been to Cape York and back and survived (look it up)
recently crushed Volvo's
Old 11-29-2007, 01:32 AM   #11
Default head work
Nice job. It will help a lot. Between the head work and the manifold improvements. It helps the engine make a lot more power.
1982 242 turbo. 340k miles. MVP coilovers and 3" exhaust. Flowed 405 with a V15. Cossie turbine housing with upgraded compressor housing. 90+, IPD remote oil filter. Some other goodness, too. Been lots of fun over 25 years. Restored in 2k. Now ready for a 2nd restoration.
Old 11-29-2007, 02:26 AM   #12
VolvoPunch
VolvoPunch's Avatar
I was always told it was a no no to port heads with out having them put on a flow bench because if all the ports do not flow evenly then it can cause problems. Thats just what I heard.
Old 11-29-2007, 02:29 AM   #13
Alex Buchka
8 cylinders
That's a good rule of thumb but if you are careful, know what you are doing, and keep the porting mild it's not a big issue.
Old 11-29-2007, 02:30 AM   #14
adrianpike
adrianpike's Avatar
Well then 95% of the fast cars on this board must be ticking timebombs then.
I would check CC volume myself, though.
I'm looking to buy, PM me if you've got any of it: LS bits, 93 850 bumper, ford 8.8", T5 WC, T56, Mustang IRS
Adrian is omniscient, you will never escape his wrath. - 500dollar744ti
doug was here
adrianpike is offline   Reply With Quote
Old 11-29-2007, 02:30 AM   #15
Poik
Backwards Turbo
Poik's Avatar
Well it's a good thing I repeated the same things on each port then. But seriously, when you get your head flowed, they usually just flow cylinder 1 and give you those numbers, not every cylinder. Also, many professional head porters do not use a flow bench.
Old 11-29-2007, 03:55 AM   #16
Kjets On a Plane
Kjets On a Plane's Avatar
The stock head has plenty if icky differences in the ports, let alone the manifolds. If you do decent work and pay attention to do the same thing on every hole, I very much doubt that it would be in any way worse than stock.
How PSI a stock can support?
Always Be Crushing!
Old 11-29-2007, 05:18 AM   #17
coldfusion21
NA is so slow...
If you get a fresh 1/4" shank carbide burr and have the air compressor to power a die grinder that 90+ wont take more than an hour or so at most. The carbide chews through that cast iron like butter.
novolvo.
coldfusion21 is offline   Reply With Quote
Old 11-29-2007, 05:59 AM   #18
aibast
aibast's Avatar
just ported my 480 head. Ehh, more or less just took away some bad castings and smoothed out a little. Took about 30 min to do.
But nice work on your head
Volvo Nilsson 740 "van" 1987 - B230K automatic to M46+OD swaped ex hearse
Volvo S80 2002 - D5 automatic daily eco cruiser 44mpg average
aibast is offline   Reply With Quote
Old 11-29-2007, 10:14 AM   #19
Boris740
Broad Member
Boris740's Avatar
I just came back from a local pro where I took my partially 531 head for some opinions on what to do about the exhaust side. I was told to round off the short side radius as much as possible even to the point of rounding off some the bottom part of the seat. Sounds scary but this is a well respected shop. They build two cycle bikes and racing snowmobiles. They also have a dyno and a flow bench.
Got knock? Got Megasquirt? Check out Knocksense knock indicator and KnocksenseMS indicating Megasquirt interface.http://www.viatrack.ca/
Boris740 is offline   Reply With Quote
Old 11-29-2007, 10:23 AM   #20
EricF
Volvospeed Spy
EricF's Avatar
Yeah, that's why I go in small steps in every cylinder and always feel with my fingers the shape of each port after every small step. It is very difficult to make them very different this way. Common sense prevails...
Head looks nice, though I might have done a little more de-shrouding on the exhaust valve. I think you know enough to have your reasons though
-Eric
- 1995 850 T5-R Yellow - Back on the Road
- 2006 Dolphin Boats 22 Bull Center Console - 250 ETEC
EricF is offline   Reply With Quote
Old 11-29-2007, 10:30 AM   #21
Karl Buchka
That doesn't sound right. You need that short side radius to get even flow through the bowl don't you?
Old 11-29-2007, 06:42 PM   #22
Poik
Backwards Turbo
Poik's Avatar
Yeah like James said, the stock casting already has discrepancies between the ports, especially in the bowls. The pictures don't do it justice, to really know how the ports turned out you would just have to use your finger, that's where the huge difference over stock can be easily determined. On the short side radius i just lightly sanded the sharp edges so that now it's a smooth sharp angle instead of a sharp sharp angle
Old 11-30-2007, 08:39 PM   #23
Poik
Backwards Turbo
Poik's Avatar
Just finishing up porting the 90+, didn't take too long. God, this engine is going to rape.
Old 12-01-2007, 06:47 PM   #24
klr142
Turbo, what?
klr142's Avatar
Any metal left between the coolant passages and the top of the exhaust runners?
Just because something looks pretty doesn't it mean it actually will act pretty. But I'm not saying that it won't act pretty either...
Old 12-03-2007, 12:29 AM   #25
Poik
Backwards Turbo
Poik's Avatar
Yeah there is some left. There are a few small holes here and there, but I don't think I will have to worry about them, as when I'm in boost the pressure shouldn't let any water in, and I plan to be in boost most of the time.
