Old 01-16-2013, 09:03 PM   #1
Dawson
Yes?
Dawson's Avatar
Default Getting ready. B20 Dual DCOE Swap Check list
So I believe I've sourced all my parts. Just want to make sure I'm not leaving anything out here.
1) Lynx manifold from Eric @ Hi Performance
2) Weber 45mm DCOE (x2) from Carbs Unlimited
3) Redline "soft mount" kit (x2) also from Carbs Unlimited
4) Redline Linkage bar kit for dual DCOE From Carbs Unlimited
5) Longer Choke cable
6) New Intake/Exhaust gasket
7) New fuel line
Sound like I'm forgetting anything? Or does anyone with more experience know how much tweaking its going to take to make this all work?
To be clear the car already has the Redline 32/36 DGV conversion and a 4-1 Tubular exhaust manifold among other mods. This is all for the '66 in sig.
1966 122s B20, head work, cam, ignition, 45mm DCOE's, M40, IPD springs 'n sways, poly bushings, Bilstein HD's.
1993 Dodge D250
1993 245 Turbo Daily
Dawson is offline   Reply With Quote
Old 01-16-2013, 09:43 PM   #2
Turborg
Turborg's Avatar
Default Air filters?
Don't see them on your list. The long weber manifolds will put the carbs too close to the fender to get air filters on.
Turborg is offline   Reply With Quote
Old 01-16-2013, 09:47 PM   #3
Dawson
Yes?
Dawson's Avatar
Probably just gonna run the stacks with screens. Plus the Lynx manifold is a real shorty that'll let almost any filter option fit later on down the road.
Old 01-16-2013, 09:58 PM   #4
JohnMc
JohnMc's Avatar
You'll probably need a fuel pressure regulator that can drop the pressures down to 2.5, 3 psi. DCOE's have these big firehose float valves, it's easy for a fuel pump to overpower and flood them.
On my car, the choke cables that went to the SU's fit perfectly fine on the DCOE's. Just make sure you don't overtighten the little retaining bolts on the cable housings.
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 01-16-2013, 10:06 PM   #5
Fuel tee and some tuning bits.
Old 01-16-2013, 10:21 PM   #6
JohnMc
JohnMc's Avatar
Very good point, how are the carbs set up? There are thousands of tuning combinations. Idle jets, main jets, air corrector jets, emulsion tubes, accel pump inlet and outlet jets, venturi sizes.
Getting it to run at all is easy. Getting it to run well is hard. Getting it to run perfectly is a true artform.
Old 01-16-2013, 10:26 PM   #7
BDKR
Section 9
BDKR's Avatar
That's going to be epic! Nothing is sexier the dual or triple web's.
In the late 80's I had a Camaro with a straight 6. Sucked all the way up until I got a 73 head, Clifford triple side draft and three Mikuni's. Crap did that thing sound amazing!
For all you Dijkstra fanboys:
Old 01-16-2013, 10:43 PM   #8
Dawson
Yes?
Dawson's Avatar
Getting it to run is one thing. I'm pretty confident in my abilities to build/fab/swap stuff around. But when it comes to that finite tuning stuff, there's an old school Volvo shop a couple towns over and I plan on leaving the car in that guys care for a couple days to get her all dialed in.
Edit: The car has a wideband already, so theoretically it should make the tuning process go a bit smoother...
Old 01-16-2013, 11:10 PM   #9
John V, outside agitator
Little possible thing: I've seen some kits where on the shaft for the levers the actual levers are aluminum, and are postiotied then the pinch screws are cranked down.. The ones I've seen have the aluminum tapped and a short screw going in...I have seen several times friends go savage and somewhat strip the threads , then the arms go out of sync..
They were all whaaaa! waaaaaaaa!.. solution: longer screws and a nut. Now you can crank it down..
Also, the fuel pressure thing.. Don't know the cam you have but I can show you where Ford motorsport says regarding fuel pressure that they run it 5-6 psi, and I have moved mine up just as insurance against full load lean out...
I really have no idea what Amazon has for fuel pipe size but my same generation Saab had 6mm OD so maybe 5mm ID...and a bad case of the ol' vapor lock when running hard, then puttering or shut down then run hard..
Changed to bigger---I used 3/8s pipe, but 5/16 would have been fine and easier to deal with....and vapor lock issue went away...
Din't see "Electric Fuel Pump(s)" on your list....You pump is made by same folks that made my pump and I suffered from block heating the pump..till I went to two Facet pumps in the trunk.
It could be that I had a somewhat hotter motor....
Do you have any ideas what you're going jet it???
Want some ideas?
Sleezattle WA, USA
--> CALL (206) 431-9696<----
www.rallyrace.net/jvab
www.rallyanarchy.com
Vive le Prole-le-ralliat
— Don Marquis
Old 01-16-2013, 11:12 PM   #10
Unless the guys have set up jetting from zero, they may not be a help, see above.^
Get it correct from beginning, and you can almost certainly get it fine tuned..
Its when people "get creative" that people have jetting nightmares.
Old 01-16-2013, 11:26 PM   #11
Dawson
Yes?
Dawson's Avatar
Want some ideas?
It is a "universal" kit so I'm a little weary of it already. But regardless, I plan on taking my time and studying it well before slapping it on at the risk of mucking something up.
I have the Isky vv71. And Based on what I've been reading, 4psi ±1 is the ballpark I should shoot for.
Don't know about fuel lines either, at best guess I'd have to say 1/4 or 6mm. Haven't had any issues yet, but i really cant compare the DGV to these cannons.
I'm keeping the stock mechanical pump for now at least. Never had a lick of trouble out of it. Even running all day in 90+ temps.
YES! I would gladly take any tips and tricks for some base settings on these puppies.
Old 01-17-2013, 04:39 PM   #12
bongo
Default jetting
i think if you post more of the specifics of your engine we can help you get closer. do you know your head flow? how big an overbore? here a a few notes i have from similar engines. they are only a ballpark but should get you running****no warranty expressed or implied!
#1 choke-36mm main jet -145 air corrector -155 emulsion F-16 idle-55f8 needle jet-200
#2 choke-36 main-150 air corrector-170 emulsion-f2 idle 55f8 needle jet-225
webers are very precise and once you understand what all of the tuning bits do your wideband and some tweaking can make them work quite well. k
bongo is offline   Reply With Quote
Old 01-17-2013, 05:04 PM   #13
OK , probably the fomatting will suck since I hain't a typist of computer nerd, lets see:
Model Förgasare Halsring Spridare Huvud-munstycke E-rör Luft-
munstycke Lågfarts-
munstycke Acc.mun-stycke Pump-ventil Nål-ven
Motor--cam----carbies-- venturi--aux vent--main--E-tube--air corr-idle acc.--needle-pump
B20 D/K-Kam 2 x 45DCOE 36 4.5 135 F2 175 55F8 40 70 175 6
B20 R-Kam 2 x 40DCOE 36 4.5 135 F2 150 60F8 45 40 200 6
B20 F/R-Kam 2 x 45DCOE 38 4.5 145 F2 170 60F8 45 40 200 6
B20 R-Kam ....2 x 45DCOE 40 4.5 155 F2 130 60F8 45 40 200
Emulsion tube F9 and F16 will work on nearly anything, and is very common on all the OHC cars when hotter cams and comp is used..
Big thing I see everybody do--even alleged heroes---is they always have the throttles closed too much so the progression bleeds aren't able to pee in some fuel..There were--are on my old 45s--don't know if still on latest---a brass plug you could pull on top and see if the throttle plates were uncovering the first of the progression holes...
T'other thing is nobody bothers with the "cold start mechanism", which is like a good Mikuni VM bike carbie in that its an enrichment cicuit, not a "choke" per se..
Make the Cold Start" thang work.. I use bicycle brake cable.
Hate to say it but unless the "guys" are over 55 they probably don't have tons of time working on any carb much less DCOE...
You on the opther hand are motivated..
Set the throttles so the plates are crack open, "volume" control (it ain't idle jet) 1.5+ a smidge turns open
Shoot there's another reason I like electric pumps..In cold weather I run the pumps until I hear the floats are full, then I give it a couple of stomps on the gas, THEN hit starter and it catches, back off as fast as possible holding it around 1000....then easy tip in little bit , little bit as it warms just a bit---2 minutes-and its starting to warm up..
Then at some point if it doesn't idle you'll need an assistant to hold the throttles so you can jump out and start twisting the screws..
A Remote starter is nice..
Old 01-17-2013, 07:02 PM   #14
Fivehundred
Fivehundred's Avatar
Depending on the manifold you may need a taller RH engine mount or a spacer under it to just tip the engine a smidgin.
Have you got the Thackeray washers, I don't see them on your list.
Fivehundred is offline   Reply With Quote
Old 01-17-2013, 07:30 PM   #15
Dawson
Yes?
Dawson's Avatar
Wow thanks for all the info John! I just ordered the carbs so I'll see what's inside 'em once they come in. Then order jets, tubes, needles, etc... from there.
I'll figure out the enrichment circuit linkage as I go. I was actually thinking something along the lines of a bike cable as well.
Even if I can't get it all dialed in, I know this guy with the Volvo shop will take care of it. He's in his 60's, has multiple "round fender" bricks, and will chase you out of the shop if you try to get him to work on anything newer than a 940. Haha!!
I guess I should look into the whole electric pump thing. It's slowly starting to make more sense to me now.
Thanks again for the advice man!
Old 01-17-2013, 07:32 PM   #16
Dawson
Yes?
Dawson's Avatar
It's a shorty manifold. It's going to clear with plenty of room to spare.
What is a Thackeray washer??
Old 01-17-2013, 07:51 PM   #17
JohnMc
JohnMc's Avatar
What kind of choke cables are on the car now? My PV had the dual SU's with choke cables going to both - the worked as is on the cold start valves on the DCOE's. Maybe I slid some extra cable back through the firewall behind the dash, maybe not. But either way I didn't trim the cables or the housing, just hooked them right up as is.
Old 01-17-2013, 07:53 PM   #18
JohnMc
JohnMc's Avatar
And PS:
I'm a bit curious what my carbs have in them now. I have 40's (probably a little too small), 36mm chokes. I utterly forget all the other jets.
Mine's a 2.1L bottom end, R-Sport head, W-81 cam, 4:1 header.
Old 01-17-2013, 09:28 PM   #19
They're short flat wound springs, like maybe a coil and three quarters...
Go on the mounting studs..
Post piccies of your "soft mount kit"
If its a flat thing with rings of rubber bonded both sides, you should imagine cranking down the nuts for the carbies and the raised rubber being a nice fulcrum.. BE CAREFUL....very easy to snap a corner off...
Oh and this is the desired pump, or one of them, I always mount 2 pumps.
Just for when the time comes.
Old 01-17-2013, 09:35 PM   #20
Dawson
Yes?
Dawson's Avatar
Oh so basically a lock washer?
I'm gonna go Google that pump right now, be right back...
Old 01-17-2013, 09:35 PM   #21
One thing to think of when you got it all hooked up and plumbed---oh and I didn't see an answer about the arms on the cross shaft if they're aluminum with a pinch bolt---let me know---note that the accelerator pumps don't mess around..
They give a real good squirt so don't sit there cranking and stompin and cranking and stomping, especially in real cold temps, they'll squirt a LOT of fuel and real easy to wet the plugs...then it'll never start..
2 stomps initially, 1/8 throttle, crank....no start let the starter cool down 2-30 seconds. 2 stomps , 1/8 throttle crank....
Old 01-17-2013, 09:41 PM   #22
Beat ya Nener neener
Shop good, price is all over the place. NAPA lists them and often stock them.
.. In UK they call 'em Silver top for moderate motors
up to 200:
The specification is: 12volt, neg earth, 5.0-6.0 psi, flow rate 27galls/hr thread 1/8th nptf.
and Red Top for 200 up
The specification is: 12volt, neg earth, 6.0-7.25 psi, flow rate 35 galls/hr, thread 1/4tr nptf.
EDIT:
http://www.racerpartswholesale.com/product/1744/Facet_Fuel_Pumps
Facet High Performance Fuel Pump, 1/4 NPT fitting 6.5-7.5 Max. Pressure
$119.99 $99.99
Facet® High Performance Gold-Flo® Solid State Pump
6.5-7.5 PSI @ 45 GPH.
Fitting size: 1/4-18 Internal.
24 inch lift
Last edited by John V, outside agitator; 01-17-2013 at 09:44 PM.. Reason: Beat ya Nener neener
Old 01-17-2013, 09:56 PM   #23
badvlvo
Bad for Babies
badvlvo's Avatar
Basically what John is saying here is also what I have experienced.
I drove on sidedrafts in the winter in Reno, 20 degree starts weren't a problem but flooding was easy. Only did it once, for some reason I forgot what car I was driving and oops, got to change the plugs in the snow. The Alfa didn't drive in the winter, but cold starts were one stab, crank, and as soon as it starts to light apply 1/4 throttle until it clears out. When it was really cold out I would have to hold the throttle open for about 30 seconds before it would idle. Neighbors hated it, but oh well, that's life.
Around 5psi is what everyone says is best for fuel pressure, I ran about 4.5 on the last car with sidedrafts, also ran that on the downdrafts on my various VW crap and my 911.
Good fuel pump and adequate fuel lines should be a consideration as recommended.
As for the linkage, stripping the aluminum isn't really a matter of IF, it's a matter of WHEN. Mess with it enough and the threads just can't hang on. But a nut and bolt on it right from the beginning and then you won't have to worry. I had the throttle cable arm slip on my Ghia between Tonopah and Reno late at night on the way home from Vegas years ago. Rigged it to get home, but really could have been a headache.
Before you attempt to tune the carbs do your homework. Read up on them and it will become much easier to dial in properly, and you won't wind up fighting the changes you have already made. Tuning parts are spendy compared to Holley stuff, but if you take your time and sort it properly you won't have to make too many changes.
Died at age 35
Old 01-18-2013, 07:46 AM   #24
Fivehundred
No, it isn't a lock washer. The Webers are mounted loose, otherwise the fuel in the float chambers frothes. What you should have is two plates with O rings to go between the carb and the manifold. The Thackeray washer is left with 1mm or so of clearance between the coils. Loose enough so there is movement, tight enough so there are no air leaks.
Old 01-18-2013, 01:30 PM   #25
Dawson
Yes?
Dawson's Avatar
Well I bought the "soft mount" kit. We'll see what is included when it all comes in.
