Old 10-01-2015, 09:26 AM   #1
Sweep
Default Widest wheels on a 940?
Is there any difference between the arches of a 240/740/940? I've found a bit of info for 240s but nothing definitive, I've got some 17" Jag steels that I'm having banded, but need to know how wide we can go, and at what offset as these need to be changed.
What are we all running?
Old 10-01-2015, 12:40 PM   #2
superboosted
You wish you had some..
superboosted's Avatar
i run 9.5,all around...fenders rolled,could prolly do 10" front and 12" rear if you were crafty..
Photobucket can suck it.
Originally Posted by centason View Post
You may get detonation and the kool-aid man loves 940s
superboosted is offline   Reply With Quote
Old 10-01-2015, 03:00 PM   #3
Sweep
9 inch was what I was hoping for so that's handy, I'd certainly like the staggered look so if we could get 10 or 11" rear that'd be ace!
Old 10-02-2015, 05:09 AM   #4
chopperead
What offset do you run 9.5's on
1994 944 2.0 Turbo.
chopperead is offline   Reply With Quote
Old 10-02-2015, 09:40 AM   #5
littlesnides
17x9.5 sawblades were tight on the front of my 93 940 wagon. I had 46mm adapters and it was just outside of flush with the +56mm sawblades. The inside lip of the wheel rubbed on the inside of the car when I turned. I have 2 coils off the front and 1 on the rear. I decided to run 17x8.5 sawblades up front at 46mm, and they sit about flush. I think you could probably run some 9.5's up front if you did some considerable rolling, ran negative offset, and some negative camber. 240's seem to have more room in the front. The back 9.5's are a pretty easy fit at +10. They sit right about flush, but I am still needing a panhard bar to line it up perfect.
littlesnides is offline   Reply With Quote
Old 10-02-2015, 12:18 PM   #6
DET17
Reformed SAABaholic
Not uber wide, running Propus 17x7.5 with 25 spacers all around. My 245.45.17s rub in back,with the plastic liners removed. FWD wheels with 43 OS. When test fitting, I noticed there was probably ~20mm more room inboard. However how much would be eaten up by articulation, unknown.
Old 10-02-2015, 02:15 PM   #7
justlie
I have issues fitting 18x8 with 235/35/18 in the front with DIY coil-overs (Koni Race inserts). The inside is 5mm (or tad less) to the strut tube and the outside is rubbing away the liner in turns. I guess if you cut the liner and pull the fender you can fit more.
1993 Volvo 940 Turbo - B230FT + 16V - M90 - MS3x - HE351CW - Methanol injection - Ford 8.8
1980 Volvo 242 GT - B5254T - M90 - MS3x - HE351CW - 17Z - E85
justlie is offline   Reply With Quote
Old 10-02-2015, 02:17 PM   #8
superboosted
about -10/front and -2/rear
Old 10-03-2015, 08:30 AM   #9
okoye
okoye's Avatar
17x8 et -32 and 17x9 et -24 yes it was in the negatives lol. and that was with a roll.
I'm getting this car back so i'll see if 17x10 fits in the rear. I know i can fit it in the front but 17x9 or 9.5 is the most you can run up front.
Old 10-03-2015, 12:28 PM   #10
jay f.
jay f.'s Avatar
Yes, you'd have to be crafty with a welder to get 12in wheels in the rear as you'd need wider fenders.
10.5 is about the widest you could fit in the rear without needing to heavily modify the fenders.
These threads should help...
http://forums.turbobricks.com/showthread.php?t=194202
http://forums.turbobricks.com/showthread.php?t=302397
jay f. is offline   Reply With Quote
Old 10-03-2015, 12:37 PM   #11
nathaninwa
The Beloved Oarnge Juice
nathaninwa's Avatar
I think it all depends on if you want to tuck or not. I tucked a 255/35/18 on a 8.5 rim with about a finger on each side. A 265 would be tough. I also ran a 7.5 up front with coilovers and just tucked. I'm now on a 960 front fender with 18x8 and 225/40/18 and out back a 18x9.5 rim with 275/35/18 but also had to flare the rear about an inch to get it to tuck and still rub sometimes
962j 815/692@27psi
THIS IS FORSALE V
Old 10-06-2015, 07:24 PM   #12
littlesnides
^^Lookin' good. My 9.5 sawblades were poking in the front at +10 and rubbing the strut housing (with the wheel). I would have to put some more work into getting it to look/fit right. Not what I am after with this car. 8.5s fit at +10 225/45/17 test fit pics:
Old 10-07-2015, 09:55 PM   #13
kingfisher
This should be a sticky
kingfisher is offline   Reply With Quote
Old 10-07-2015, 11:37 PM   #14
superboosted
Truth.
Also my front strut housings are dimpled where the rim is. Have to run stick on weights.
9.5 w/225/45/17 is as wide as you get without serious work.
Old 10-10-2015, 07:58 PM   #15
Magnum TE
Broke another B230F+T
Magnum TE's Avatar
I don't know how you can run a 245 with only a 25mm spacer. I'm running a 225x45x17 8.5" canisto (also a 43OS) with 32mm spacers I was rubbing tire on the strut tube. I'm running ~40mm of spacer in front now and I've got 5mm tire to strut tube clearance.
It's got to be hit and miss on how the strut tubes are angled on the knuckle, because that's the only thing geometrically speaking that can cause an inconsistency like this.
My fenders liners are out, lips are cut, rolled, and pulled, so no clearance issues on the fender.
Goldie Bricks - '92 940T : B230F+T MSnS-e...
The Black - '98 318i : stock drive-train DD
I have some cool stuff done to my cars
The Gold Car: Owner since 2001
B230F+T MS1nS-E / Ford T5, 1pc DL
ebay FMIC / Mechman Alternator
T3 60/.63 ATP WG / 98#/hr injectors
Full 3" Turbo to tail / IPD TP Cam
IPD bars / Coilovers
Koni Dampners / Lower Chassis brace
NIW-T3 camber plates / Full poly front end
Full Kaplhenke Rear end
-Torque rods -PH Bar -Subframe
Daily Driver
Magnum TE is offline   Reply With Quote
Old 10-10-2015, 08:04 PM   #16
Magnum TE
Magnum TE's Avatar
get a framing square and measure from the hub to the strut tube on the front, that will let u know what kind of offset you can run. You're gona want at least 10mm clearance there for the tire, and also you don't want the tire to be so close to the inside of the car that it's going to rub the sway bar.... mine does and it pisses me off to no end
Old 10-13-2015, 10:50 PM   #17
volvo4ever8611
would a 18x8.5 fit in front on a volvo 740 and a 18x10 out back plan on going with coilovers.... and if i can make them fit what offset would be best i prefer the staggered look for how i want the end result on the car to look. thanks all for any advice provided.
volvo4ever8611 is offline   Reply With Quote
Old 10-14-2015, 11:08 AM   #18
littlesnides
You should be ok. You won't have to worry about the top of the tire hitting the spring seat. For the front, I wouldn't recommend going much higher offset than +10. That would sit you about flush (from my findings). If you run some negative camber you could probably tuck the wheels then. My 9.5's at +10 in the rear sit about flush. I haven't rolled my fenders and rub very slightly on 225/45/17 in back. With an extra .5" (12.7mm) You would probably want to push them out more so you would need an offset closer to 0. Its all math and measuring really... That should give you an idea of where to start.
Old 10-14-2015, 11:34 AM   #19
Chigga 744SE
Taiwan Panda Racing Unit
I'm getting back to the grove with the box, has anyone with issue on fitting on front fenders?
right now I have 19x8.5, final ET is around 10, 215/45/19, it rubs without liner and rolled fenders when turning, but it looks like ass when you look from the front, is the overall diameter just too large?
I'm planning to go down to 17"s or 18"s coming Spring.
Chigga 744SE is offline   Reply With Quote
Old 10-14-2015, 11:43 AM   #20
AndrewNance
Amateur hour!
AndrewNance's Avatar
That is a massive wheel and tire. I'm thinking most people run 2x5/45 or even 40 on 17" wheels.
'71 142
'80 245
Feedback
Old 10-14-2015, 12:01 PM   #21
fortbrick
fortbrick's Avatar
I run 215/45/17 with my style 5's. 17x8 et20 with 20mm adapters. Needed to roll the rears, have not needed to touch the front fenders yet. Slight rub on the fender liner through turns with bumps.
I'll try to add a few photos here.
Front fender
Rear fender clearance before lowering more
Old 10-14-2015, 12:03 PM   #22
Ursan
الله الفول السوداني شطائر
Ursan's Avatar
Originally Posted by littlesnides View Post
Is there a reason you mounted your wheels like that?
And this. This question comes up too often.
how psi a stock can support?
I think this might be my chariot if I can jew the price down.
Old 10-14-2015, 01:38 PM   #23
nathaninwa
nathaninwa's Avatar
This depends on how low you want your car
Old 10-14-2015, 02:16 PM   #24
littlesnides
[QUOTE=Ursan;5261510]Is there a reason you mounted your wheels like that?
It was a test fit
Old 10-14-2015, 03:00 PM   #25
PNW940Pwnage
This is kinda related...I had recently inquired about tire sizes.
I can tell you that, in the rear at least, 16x8 with 245/50 rubber fits just fine with zero rubbing jumping up and down on the rear bumper. lol. 1.5 coils are cut, and the car is gutted (so it sat a bit high considering the springs were cut).
Dunno if that helps at all, but people suggested that combo would rub, and it's nowhere near rubbing at all. I could run 255/55 and it would still be fine. '95 945.
PNW940Pwnage is offline   Reply With Quote
