The factors that lead to this research:
All of the above can be answered in one way only as it seems, which is to remove the diff, inspect, rehaul and replace the gears. However since there is no shop around that i can trust for this job, i decided to prepare as good as possible to do it. I have also decided to make my own copy of the basic special tools that Volvo used, that will help with accuracy as well as to try doing it in one shot. I really don't want to repeat the procedure until i get things right.
Tools and theory:
Pinion depth: This is usually measured from the upper face of the pinion head (carrier side) to the axle centerline. It is referred as Nominal Pinon Depth (NPD) which is 2,250" / 57,15mm for Dana 30 and this is the basis of the diff tools. This assumes a pinion that is marked as 0 (ie no shims needed set pinion depth). There is another measurement called master housing depth (MHD) which should be 3,625" / 92,07mm for Dana 30 (this will have to be checked). The Master Housing Dimension (MHD) is the distance between the axle centerline and the back of the pinion head including the shims which adjust the pinion depth. Basically the two measurements are the same but they have different reference point. Hope that these make sense !
Diff tool: Here is a pic of the diff tool used for the Volvo diff (you need to read the greenbook or watch the video to understand how this works).
Tools 2284, 2393, 2595, 2597, 2600 and 2841 are common for 1030 and 1031 while 2685 is for 1030 and 2840 is for 1031.
If anyone has got access to tools 2685 or 2840, 2595 & 2841 please let me know to ask for some measurements. I could not find any info on those!
Tool 2284 has a dimension of 279,40mm x 16,15mm but it is really not important as long as it can support the dial gauge and be really straight !
Tool 2393 is used as such:
Basically what is needed to be done is to compare the reading of the gauge dial at zeroing point 2 and the top of tool B. This should be adjusted with shims to the number that the pinion head indicates. Lets assume for checking our measurements a perfect pinion with 0mm deviation.
From my research (and precious help of Gary - gsellstr) the total height of part B is 72,21mm. Also the diameters at number 3 is 76,45mm and at number 2 is 30,04mm.
Remember that this tool measures NPD which should theoretically be 57,15mm measured to the axle centerline (hence the half of the tool's thickness at point 2) so let's check the numbers:
72,21 - 30,04 / 2 = 72,21 - 15,02 = 57,19mm which is very close to the theoretical 57,15mm of Dana 30.
So the tools are based on the Dana 30 dimensions and they can be constructed with the above dimensions. The deviations are probably there due to measurement errors.
Tool 2685 or 2840 are used to adjust the pinion height easily so you don't have to press a bearing on the pinion, test with the above procedure and then if unsuccessful remove the bearing, change the shims and then press again, test etc .. This of course could be solved with an old bearing but still .. this tool makes life easier ! If anyone has access or info, please let me know for some measurements !
Also for carrier backlash adjustment rings 2595 i also have no info, so if anyone has access or info, please let me know for some measurements !
IMO the most important tool is the one for the pinion that we now got some info about.
Sources:
- A grinding noise that can be heard from the rear when the car is travelling with speed (for example 80-100km/h), in gear (usually in 3rd, sometimes in 4th) and the gas is let. As the car is slowing down this grinding noise can be heard. When the clutch is depressed or when in no gear the noise is not heard. I am not sure if the same happens on the 2nd gear due to high revs at that speed. The M90H on the car and the center bearing support have been rehauled (described in my build thread) so i assume that they are not the source of this problem. Also there seems to be nothing hitting the chassis (exhaust or anything else) that could cause this noise and nothing can be heard when in low speeds or when accelerating under any conditions. Pinion preload/bearing/depth as well as carrier backlash should be checked as IMO these could cause such noises.
- My TrueTrac equipped diff has a ratio of 3.73 which combined to the M90H and the power of the car which is 400whp+ i feel that a 3.54 or 3.31 would be more suitable. According to Dave Barton's site the latest M47 240's featured a 3.31 ratio. Of course these ratios are hard to find new, will have to take this into account. The ones that are easily found are 3.15 and 4.10 and up. I have not driven cars with these rear end ratios, so any input would be acceptable. Here are some tables with different rear ratios at given rpms (2800 and 7200 rpm).
- Despite my feeling that my axle is a 1031 (probably swapped by the previous owners many many years ago), given that it features a 12 tooth electronic speed reading system, i will have to solve this mystery. No sticker or anything indicates what kind of diff this is. The following picture found online indicates that the pinion nut is different in size (M20 - M24) so this is something to be verified, but it looks reasonable. Funny enough when i installed the TrueTrac many years ago, i never thought of measuring the ring gear to see what kind of diff i have !
Tools and theory:
Sources:
- https://www.240.se/litteratur/tp30039_2.pdf greenbook referring to the rear axle. Can be found in many places.
- https://www.jeepforum.com/threads/cj7-dana-30-rebuild-and-setup.1121189/ A very nice thread about rebuilding a Jeep Dana 30 differential, with minor differences to ours
- An ancient video on using the diff tool that greenbooks refer to. Unfortunately in Swedish, but i managed to translate it. If someone has some upload space or something i can upload it with external subtitle files. I have cut the video into 2 pieces, the first 30 minutes and the second the rest, since the AI translator had some limitations. Let me know if you are interested ! I will attach the subs files here anyway.
