240 240
Millennium Falcon BIG BLOCK CHEVY SWAPPED
- Mar 3, 2022
- under the car
After a high NO reading at my recent smog inspection I decided to do a seafoam treatment. Upon hotsoak startup I saw smoke at the turbo, which prompted this video.
Turbo still spools. I assume the leak was always there and I only noticed after the white poof cloud. It is probably the reason for the high nox.
Can I seal this leak without turbo removal? or is this the end of the little boosty boy?
can I just weld it shut to pass smog?
I just want a quick fix to pass emissions and get registration card.
Then deal with swapping out a better turbo later if possible.
I also assume my o2 sensor is toast.
plugs are a normal color so I'm not really leaning out.
13c turbo leaking from wastegate arm?
