I did not get to the front shocks yesterday. I only had an hour window to mess with the 144 so I tuned the carb and timing instead.
I read that Weber 38/38 DGAS carbs can be a bit sensitive to changes. After the work done on the head gasket and the carb spacer, the car wasn’t running as perfectly as it used to. At 1/4 throttle it had a flat spot. Which was annoying when you were driving away from a stop- the car would feel like it was going to die as you slipped the clutch.
I found this instruction on how to tune the 38 DGAS and followed it exactly:
Redline Weber 38 DGAS tuning
I found out the choke was not opening fully , so I adjusted that. I also found the mixture screws were a few turns different from one another- like it had been mistakenly tuned like a 32/36.
I was relieved to find that after the adjustment was complete, the idle mixture screws were about 1.5 to 2 turns out, right where they’re supposed to be according to Redline. So the jetting is appropriate.
I also advanced the timing a few degrees. It’s a bit tricky to see the timing marks because the AC compressor is in the way. But it’s at about 15* at idle, and around 40* full advance. I know that’s a bit on the high side, so I may back that down later. Especially in hot weather.
On the test drive, the car felt better! No more flat spot, and no pinging. It just drove like it supposed to, like it did before the head gasket replacement. The only thing is that I may have the idle set too high. It hangs sometimes, like it’s getting into the timing advance.
I’m curious to see how it starts up in the cold tomorrow morning. I’ll check the choke, and maybe back that idle down.
