Congrats
@Jack ! Momentous accomplishment.
thank you, finally
First drive must feel so good! Great work!
thank you! heck yes, but the real drive will come in a few days.
That's fantastic! Been a lot of work. Completely renewed everywhere. Amazing car.
How many T shirts do you think it took to finish the car?
For wax try out Blitz wax made by One Grand. Easy to put on. Melts in your hand and lasts pretty long. Before wax I would polish with P21S gloss polish. Have to wax the car right after using the polish.
Thank you, It's super close to being done. I still need to button up the interior and recheck everything once I drive it more. I'll give those a try
speaking of interior..
Yesterday
I started to put everything extra away, did more cleaning, replaced few odds and ends
removed the "rear wash" button. Replaced bulbs in hazard and defrost. What was the first year of the late model switches? I cant remember
replaced the clock lightbulb
car was missing the key/seatbelt buzzer. Installed one
today.
Driver rear door window seal had a big piece missing. I replaced it with a whole one but still not that great. rubber etc around here turns rock hard. It's been a while since I found some decent soft window guide seals. If anyone has a set LMK. Apparently they only make the rear ones new ?
All the power windows are SUPER slow to go up/down. I pulled the driver rear window regulator. Cleaned it all up and regreased it.
caked in old grease
I forgot to take a picture of the window regulator transmission with old grease. Unlike the older regulators that unscrew the newer style access cover is pinned on
old
3 screws
new
4 hammered on pins? I broke those off
cleaned off most of the grease, put some heat and lube where the pivots are, then worked it until it all started to feel smooth. Picture shows all the dirt/old grease coming out
I added more grease later (this is me working with a drop light)
I drilled for self tappers, I didnt feel like making a legitimate thread. pressure washed the inside of the DR door, installed the regulator, "new" seal and glass. This window now goes up and down properly. I just need to do the same for the 3 other doors. DF is painfully slow going back up ... like takes 3 min with some help to fully close.. It got dark so Im done for today
