brendon_ak
- Jun 7, 2011
- Hood River, OR
Did you convert it to lh2.2 yet?
hopefully tomorrow I'll knowKeeping me in suspense man, hope the work is worth it
No plans for doing thisDid you convert it to lh2.2 yet?
There are no elfs that come in and do it for meNice work, way to keep at it!
told myself I couldn't go pee until I had it running.
Might be easier to work on it if you take off that baseball mitt.
Most of it came off with spinning the valve in a t shirt, then I did about 5 seconds in a “fine” scotch pad. I also put the valve into the distributor and spun it inside for like 5 secondsGreat news @Jack . Interested to see how the test drive goes but it looks like this is a win. How did you polish the valve? 1000 grit or something fancier?
It’s a mess under the intake and it only goes one wayThat doesn’t look like a good time at all.
Great you got it sorted out and found smoother operation. Hopefully the test drive goes well with no more hanging RPMs.
I can park and suntan there without anyone passing throughYou found a location so far out in the sticks that you can actually park in the driving lane and wander off for a photograph??
That's nowhere near the Bay Area, fer sure... I'm envious.
There's only 1 black M46 speedo gear. It works for both 3.91 and 3.31 rear end gears. The difference is the metal gear in the overdrive. For 3.31 the metal gear has 7 teeth and for 3.91 it has 6 teeth. Look at the housing near the output flange. There should be a 6 or 7 stamped into the housing to indicate which gear was installed.
I think they had 3.73s also, will look it up but also @pinguin what’s the diff ratio on that 242 you got?I think they had 3.73's.The 'New Car Features' greenbook after '81 or so shows what gears came in which models. I gave you some of them but I don't think I had one from '84. Either that or ask John242Ti.
Now I need to find my second black gear and count them teef. Looks like I need a 20 toofer. The donor 242 is 84 but 85 model IIRCOld thread on speedo gears: https://www.turbobricks.com/index.php?threads/speedometer-cable-gear-in-transmission.272631/
