hiperfauto
The Librarian
- Nov 18, 2011
- So Cal
The yellow gear is for AW70/71.
Not according to link see bottom diagramThe yellow gear is for AW70/71.
https://www.volvopartswebstore.com/products/Speedometer-gear/1103810/1220484.htmlI dunno, it's parked in a friend's garage in Minneapolis.I think they had 3.73s also, will look it up but also @pinguin what’s the diff ratio on that 242 you got?
Something doesn’t add up in my equation, I seem to recall that the 242 Speedo was reading fine
This is good help. I know what to check
That's an M47. M45 & M47 use the same gears as AW70/71. M46 gears are differentNot according to link see bottom diagram
Idk what’s different on the 85 m46
Either way I still need to figure out what’s what inside
very good@Jack I followed the same procedure re: control valve and also found mine was catching in places as well. After polishing with fine steel wool and thoroughly spraying with carb cleaner it is working well. Still a slight hesitation with revs dropping but much improved also did terminal 11 mod and running 15psi @ 11.6 afr. Thanks for being the guinea pig!
There's only 1 black M46 speedo gear. It works for both 3.91 and 3.31 rear end gears. The difference is the metal gear in the overdrive. For 3.31 the metal gear has 7 teeth and for 3.91 it has 6 teeth. Look at the housing near the output flange. There should be a 6 or 7 stamped into the housing to indicate which gear was installed.
Thank you! Most stressful part was not having a way to test it prior to smogCongrats! Quite a saga
Daughter says "I dont know Jack"I don't know Ja boi? RE license plate
Love the progress and looks incredible, hope it serves her well!!
Nice post office you've got there.
