1982 B21 head - how much to shave for more compression
Jack
junkman
The Ass Cheek Of History
Just found few drops of oil in daughters coolant bottle… head gasket must be going out
Since I’m in there how much should I have a machine shop shave the head for some extra NA power using 91 octane
Is it just shave head and normal timing belt fits without getting a smaller one ?
Sorry for the noob question I read about all this before but never actually done it
Car is an 1982 CIS b21
What cam?
Can the stress of driving with it floored everywhere blow head gaskets?
not really when it's low compression. floored on low compression engine is like 75% power on a high comp engine in terms of stress on a head gasket.
why do you want the car to have more power? needing high octane gas leaves less room for error on 45 year old everything
you can achieve higher dynamic compression with a different cam or advancing the cam timing. ive never been a fan of just shaving the head to get more power and not doing anything else.
is the head currently on the car SCP or LCP?
also which head do you have on their now? is it the dog shit 160 head? do you have a 405 kjet head laying around that you can clean up and swap in?
160 head and I’m taking a 160 head to get machined since it’s what I have
Maybe I’ll just leave it alone that’s a good point
I concur with OVERDRIVE, tight squish is the way.
I was attempting to make a joke about the driver of this car stressing it a bit more than the average B21 240.
The car doesn’t even slowdown much when you downshift
I was on her to downshift more instead of smashing the brakes but then I drove it and realized downshift is mostly just a noise maker
can’t blame everything on daughter
I think in the other thread, folks were saying 1mm skim on the head is no big deal and you can still use a stock timing belt.
More than that you’ll need a timing belt one tooth shorter.
More compression will:
-improve torque across the entire rpm range
-improve fuel economy
-improve engine braking
-increase NOx
It will not
-increase power so much it keeps that $100 bill on the dash out of reach
Milling 1mm you can retain the stock timing belt and not worry about cam timing too much (unless you're me). If you mill 2mm, I would say you absolutely need to add (or adjust, if you already have one) cam timing as it'll be retarded somewhere in the neighborhood of 6-7 degrees. If you'd like we can do the math here with regard to dynamic compression ratio to add information to help you make a more educated decision.
Yes please but I’m not going 2mm just thinking of 1
I’m also pretty sure it’s a B cam
I do have an adjustable cam gear I’m not using is yiu recommend I use it
OK, I'm gonna take a couple liberties here as I've not measured shit on a B21. In the grand scheme of things, it won't matter as we're comparing the same maths. I'll outline my assumptions:
160 head has same chamber volume as 530 (54.5cc uncut)
160 head milled 1mm is the same as 530 (49.5cc)
160 head milled 2mm is the same as 530 (approx 46cc)
Stock head gasket is 0.047" compressed, and 2mm larger diameter than cylinder bore.
Dish in B21F piston is the same as B230F, 8cc.
Zero deck height.
Advertised compression ratios for B21 and B230 are equally bogus.
Given these assumptions, I get a static comp ratio on the B21F of 8.51:1. With a B cam that closes the intake valve at 76* ABDC, your dynamic compression ratio ends up being 6.16:1. Great for post-war 70 octane and totally explains no engine braking.
Now if we mill 1mm, static compression turns into 9.08:1 and dynamic to 6.55:1 IF cam timing didn't move, but it does. Let's say it retards 4* based on 1* per 0.010" milled. That changes your dynamic ratio to 6.30:1. Still not good, but better than it was.
OK, now 2mm. Static goes to 9.54:1, dynamic would be 6.87:1 if you corrected the cam timing from the approx 7* of retard it would experience (I say 7* because it's not quite 1* per 0.010" of head mill). Uncorrected, you're looking at about 6.38:1.
To show what a 0.036" MLS gasket would do, 1mm turns into 9.35:1, 6.74:1 corrected, and 6.47:1 uncorrected. 2mm becomes 9.83:1, 7.07:1 corrected and 6.57:1 uncorrected. MLS gasket is also only 1mm larger than bore diameter, so that plays into it.
None of these require 91 octane. On a naturally aspirated street engine with aluminum heads that I don't want to think about, I like not more than but as close as possible to 8.25 dynamic. 8.5 if I can get a specific tune on it.
The problem here is how damn long the ramps are on the B cam. You can see on may cam page that the intake valve closes at 76* ABDC with 0.015" valve lash, which is 15 degrees later than it's 0.005" lift point (61* ABDC). Not to get crazy and redo all the maths, but if the intake closed at 61* on a stock engine, you'd have a dynamic of 6.98:1. With a 1mm mill, uncorrected, you'd be up to 7.27:1. Corrected, 7.44:1. If you advance it 4* from stock (7 or 8 after milling), with a 0.015" valve lash (76* ABDC intake close), it's 6.80:1.
If you don't want to switch cams, I'd open the lash up on the intake to say 0.018" and try to recover some DCR. If you've got an A or T or even an M, it might be better.
That last bit of info isn't any that you asked for but given the context of the discussion, I thought it pertinent.
