302ftw?
- May 7, 2010
- Goshen, NY
Thanks! They are 16x7, 4.5in backspacing in front and 5 in the rear. 225 45(?) 16 hankook ventus 2Looking good!
I like the wheels. What are the specs on the wheels/tires?
Checked today, it's a 50 series not 45Thanks! They are 16x7, 4.5in backspacing in front and 5 in the rear. 225 45(?) 16 hankook ventus 2
Some more are about to be thrown in the CNCNice work !!! Love the octopus replacement. @Pietercc - have them in stock?
I'll take one. let me know when they're done.Some more are about to be thrown in the CNC
It wasn't my decision per se, this set is from another gentleman who had them on his 242. The backspacing is different to clear calipers. I couldn't put the fronts on the back if I wanted. As is, I had to slightly roll the rear fenders to clear. Both f and r are basically at the backspacing limit.Wow, I love those rims. I recall the backspacing is different from one pair to the other... any reason you chose to make the front track wider, instead of the rear?
I'd love to see a pic of the clearances, especially of the ones on the rear since that's a size I'd strongly consider.
Thanks! The gingersquad is what my wife and I have called ourselves even before we had kids. Both Irish/Scottish descent and fairly ginger-y. No ipd turbo cam yet, I'm going to do a refurbished head/cam/90+ mani and b23f intake over the winter. Surprisingly quick already, kept up with a SQ5 yesterday (only in 2nd gear till about 60. I'm sure it would crush me on the highway). I am seeing that, when driving more aggressively, the afrs are not consistent. I am wondering if the stock in tank pump can keep up, will probably upgrade to the 740 pump over the winter too. Gratuitous shot because why not.What makes it part of the ginger squad? You have red heads around you?
Car looks so good! I like your little touches inside. Does that already have an IPD turbo cam? If not that really helps with mid and top end power. Without even changing anything else you'll really feel the difference.
