245TICSweden
- Aug 13, 2023
So, after a long journey, my 1985 245 Turbo Intercooler B21ET has started to run very rough when cold, it shutters/misfires really bad.
It's better under hard(ish) acceleration, but trying to maintain a constant speed at low/medium throttle is almost impossible.
Idle is okay(ish) and the car does not die, the issues starts when applying throttle.
Then when it gets warm after about 5 minutes of driving, it runs perfectly. Same when restarting after stopping for a while.
The car starts each time without issue, cold or warm. Fuel consumption is not affected. No smoke from exhaust during the rough cold running.
I've tried spraying start gas on the distributors during idle when cold, but there is no effect to the idle.
When searching around this and other forums, it seems most have issues with the car being hard to start/dying during ide when cold, this is however not my issue.
I've seen some recommendations to search for vacuum leaks, but has anyone here had a similar problem and what are your tips/experiences?
