ZVOLV
<Master Tech>
- Nov 19, 2002
- West Texas
2-1-3 means the ECU is seeing WOT (TPS WOT switch closed to ground) when at idle/light load. Check the voltage on the TPS pins.
3-1-2 is a problem in the EZK to ECU knock enrichment wire - maybe a poor connection, or maybe poor power/ground to the EZK.
Check the engine speed sensor. See if the wire on it is original by checking to see if it has a yellow tracer. The upgraded sensor uses a white marker on the wiring. Way back in the 90s my moms 245 had this kind of issue. It would randomly happen. The classic situation where it won't start for mom then I try it and it runs and is fine for the day. It finally died in front of the house but never set any codes. The dealer replaced the sensor and it was fine after that.
Yes, this song was used in 'Breaking Bad' when Walt stole the white 240 - Walt put the cassette into the stereo and that song was a-playin'.I love this song
Congrats! I'm planning on picking up a 90 745GLE (16V) in August - out in Ohio. Issue I will have is locating all the 16V specific timing & balance shaft belts, etc. It's been in a dis-assembled state for about 20years....
