Forgot to post the past few days work
Wednesday: Busy day. First I figured out the rad hoses with the revised rad placement
For the lower house I used a Gates 21026, cut in half & flipped the larger engine side to get the correct offset. I used a 1.25" coupler to join it
For the upper hose, the Gates 22373 is the perfect form but the rad neck end is 1.5", and I need 1.375". I may just have to sleeve the rad neck to make it fit
Rad will sit about 3" below the frame rail. I'm probably going to cut off the filler on the end tank, as that requires the 4" drop pictured
After that I removed the drivetrain to work on the further tunnel mods
After much abuse of left & right sides. I'll have to clean it all up & weld the damage later
While I had the drivetrain out, I figured out where the EMS harness could pass through, so I drilled the 2" hole in the firewall
Cleaned up & filed out to 2.125" for the grommet ID. It's going to be close to the back of the motor
After those details were addressed I put the drivetrain back in. Figuring out a routine that works. It's easier with the rad support out, so I think I'll make it a removable panel
Harness clearance. This will need a heat shield
Better fit now with the additional tunnel work
I had shaved the rail cover to clear the booster, that actually wasn't necessary
Drivetrain sits at a better angle
However, the pan is skimming the subframe. That will need to be addressed
Part of the equation here is that the transmission sits higher up - in fact I added a 1" block to raise the trans off the mount, which pretty much levelled things nicely.
Driveline angle looks much better here. I'll remeasure the shaft . Have to figure out the mount.
More room for the downpipe here, with the forward end of the inner transmission rail removed
More welding work I have made for myself - this is on the driver's side.
