Smokey77
- Jun 9, 2024
- Goodyear Arizona
So, I did an emissions test to register the car. Lets say that CO was 5.8X requirement!! AZ Phoenix btw. And HC was about 3.8X. NOX was good. So, obviously running rich with a possible cat failure too. Pulled the plugs, cyl 1 barely smelled like fuel, (I couldn't smell it but my co worker did) . 2,3 and 4 wreaked of unburnt fuel. Fuel regulator seems fine (didn't leak when engine off and small fuel line pulled off) new plugs. I haven't touched the 02 sensor yet, and MAF or whatever you want to call it (I don't entirely know the differences yet) looked clean. No idea if they actually work. And don't know if the injectors are leaking or if they are not pulsing correctly. Engine temp is OK and blows hot when I turn on the heat.
So, here are the symptoms. Lack of power (especially when cold) and revs up and down when idle and cold (I live in Arizona now so it is kind of hot all the time lol!) . Warm it isn't noticeable. When I lightly tap and release the throttle, it bogs and wants to stall after throttle is released. Doesn't matter what RPM I rev it to, same thing. Inconsistent misfire even on new plugs when cruising at 30mph plus. And what I find most odd, is a long whistle sound when I turn the engine off. A few seconds and a consistent whistle and then fades out after a moment. No idea if it is related? I tested some of the vacuum lines with flammable brake clean and nothing.
I haven't tried the OBD1 diag yet, I just genuinely don't have the code list or anything. And no check engine light. So everything so far is based off of process of elimination. If anyone can direct me to that, that would be awesome. Really with this I am trying to get opinions of what to do. And hopefully someone else like me who doesn't have much diagnosis experience. Or maybe even less. Will know what to do, if there even is someone else like that on here haha.
I would attach videos but by the looks of it I can't.
