122power
dude
- Feb 20, 2009
Have a 1995 945t with abs and a low brake pedal. Its pretty much down to the floor. Car still stops fine but the low pedal is supposed to be higher. Previous owner panic braked over some railroad tracks and cycled the abs, since then the pedal has been low. He tried to bleed it to no avail. I have bled the system and even swapped out the master cylinder, bled it and still the same symptom. Booster still assists on braking, no leaks anywhere, I have used a half of a big bottle of fluid bleeding it with the wife pumping. Even bled the lines at the abs pump just for gee whiz. Bled the master at the side ports too. I dont know if I can cycle the abs motor or not? Or maybe the combination valve below the master? I have another 945 NA and know what the pedal is supposed to feel like. This one doesnt give any resistance in the pedal until its near the floor. Any ideas? Im kinda at a loss.
