comanche250
- Jul 12, 2024
- Okanagan, Canada
They're both 1991 model cars so I figured the dash harnesses would be the sameThey are definitely different. That said, they may not be different in a way that will affect your conversion. The only way to know is to examine the bulkhead connector wires/pins and see how closely they compare. The 95 dash harness definitely has a different type of connector for the instrument cluster connections.
Everyone? I told you right from the start this is straight forward, just time consuming.View attachment 29131View attachment 29132View attachment 29133
the two harnesses are quite similar on the dash side, I'm sure you could get away with using the regina dash harness, however it takes an extra 10 minutes to get the rest of the harness out, and I haven't tested it so the wiring could be different. But the main thing (circled in yellow) between the turbo lh2.4 harness and the regina (and I guess the non turbo 2.4 harness) is the battery is on opposite sides of the engine bay, and respectively the main battery power junction box is on opposite sides. I'm sure you could extend the wires if needed.
The regina engine harness actually disconnects from the rest of the left hand engine bay harness which can be handy. I also like how it comes up from the side by the alternator, opposed to the 2.4 harness coming up behind the engine right on the firewall.
Overall, its really not as bad as everyone makes it out to be. The hardest part for me was getting the right hand connectors past the heater matrix box and out/in the hole. The dash isn't really that hard to pull. If you have a nice regina car, just get the entire turbo harness and expect it to take 3-4 days. I had the engine and wiring harness out in one day. I'll probably have the engine in tomorrow after work.
Ah more of a play the forum in general. When I was first looking into the swap there is still very little actual information on how to do the swap, most of the threads are filled with smart asses saying to just buy a turbo/2.4 car it's not worth building a Regina car. I was even told that myself when I first joined and started asking questions.Everyone? I told you right from the start this is straight forward, just time consuming.
I told you the same thing because it is much easier to just buy the correct car. You still have issues ahead of you. The ABS systems are on the opposite side of the engine compartment for a reason. The swap is possible, just time consuming. I've sold the harnesses to folks on here that have done the swap. 10 years ago, finding a Turbo car was no problem. These days, finding any 940 in good condition is getting to be difficult.Ah more of a play the forum in general. When I was first looking into the swap there is still very little actual information on how to do the swap, most of the threads are filled with smart asses saying to just buy a turbo/2.4 car it's not worth building a Regina car. I was even told that myself when I first joined and started asking questions.
Oh my car doesn't have ABS or airbags. I grew up to a family that went to pick and pull and pulled a working engine to replace a blown up one in our car instead of buying a new car so buying the car I like them swapping the engine in I like is just second nature for me. I dumped a little turbo diesel in my Toyota before.I told you the same thing because it is much easier to just buy the correct car. You still have issues ahead of you. The ABS systems are on the opposite side of the engine compartment for a reason. The swap is possible, just time consuming. I've sold the harnesses to folks on here that have done the swap. 10 years ago, finding a Turbo car was no problem. These days, finding any 940 in good condition is getting to be difficult.
That certainly simplifies the swap. Any Volvo 7-9 1991 and newer here in the US was ABS equipped, as far as I have seen. Any 1990 and newer Volvo came with air bags.Oh my car doesn't have ABS or airbags. I grew up to a family that went to pick and pull and pulled a working engine to replace a blown up one in our car instead of buying a new car so buying the car I like them swapping the engine in I like is just second nature for me. I dumped a little turbo diesel in my Toyota before.
Oh interesting. Canada must have different regulations, although we have DTRLs in all our cars.That certainly simplifies the swap. Any Volvo 7-9 1991 and newer here in the US was ABS equipped, as far as I have seen. Any 1990 and newer Volvo came with air bags.
That's extremely weird, I have a '91 940 that has both ABS and airbags. What did your steering wheel look like, before you pulled the car apart?Oh my car doesn't have ABS or airbags.
Well there's no clock spring, just a metal ring for the horn.That's extremely weird, I have a '91 940 that has both ABS and airbags. What did your steering wheel look like, before you pulled the car apart?
This isn't related to your swap, I'm just genuinely curious as I also haven't seen a '90+ Volvo without airbags or ABS.
It's a Canadian car, assembled in Nova Scotia.It may have been one of the Tourist Volvo 740s brought over from Europe. I’ve seen some really strange combinations when they come to the US via that program.
That doesn't surprise me. 92-93 240s built for the Canadian market didn't get ABS as standard equipment.Well there's no clock spring, just a metal ring for the horn.
