84B23F
- Feb 11, 2008
- Kansas, USA
For around $10.00 (US) in parts (LED & Float), a cheap coolant level sensor can be created.
Stainless Steel Vertical Float - Ebay price around $6.00.
Green LED Pilot Light - Ebay price, around $5.00
On bottom side of coolant reservoir, I mounted the float. Between the top-edge of that center hole and that horizontal rib above it, I drilled out a hole in the center-line of those two points mentioned on bottom side with a drill press, via smaller drill bit first, then a larger sized bit. This is a top-side photo showing float.
I used a 4" side grinder on tank's bottom-mounting bracket so float's nut would seat within this bracket. When tightening nut, I used a hemostat (hemostatic clamp) to hold threaded part, and a wrench; once threaded part started to spin, I stopped tightening it.
One wire of float is hooked to a ground next to reservoir tank, and the other float wire goes thru firewall (where main wiring harness goes thru) and into vehicle's interior (inside, I fished wire across heater box), and hooked wire to ground side of LED light. For the positive wire, I hooked it to other side of LED, and ran this wire over to fuse box, and inserted it onto a fuse holder via alligator clamp.
Mounting LED - If mounted further inward on cluster, it will not seat flush, for LED I used.
It is mounted so when I'm driving at night, the steering wheel blocks this side light from my eyes; although dark nail polish could be used to block this side light. The cluster's night lights are not needed with LED mounted there. This 20ma draw LED is quite bright if pointed towards your eyes at night.
Operation - I have filled reservoir tank so when engine is cold, the LED will not be lit, except when anti-freeze solution is moving about. Once engine is warmed up, the LED stays lit most all of the time.
Footnote - Nothing fancy here, but I could have used a Bosch relay setup to set-off a buzzer. That float is good for a one amp draw, so using a 20ma LED does not overload it. Only with time will I be able to determine if an issue exist with float in tank; I have a spare tank in case there is an issue.
