dbarton
Dejected by Volvo Corp.
- Nov 17, 2002
- Prosper, TX
Put these on with new mounts about a month ago. Will they last or will they explode?
3/16 inch galvanized cable.
Dave B.
Dave B.
Are those to help stiffen them up?
I dont like how you have the SS cable sandwiched between the aluminum and the steel. That will for sure wear out the Aluminum engine mounting bracket
If you want to do something similar. Go around the outside so the mounting surfaces can sit flat.
Kewl nicopress.
I'm betting the wire just migrates with the bushing as it sags.
Another TB? 'solution' in search of a problem?
Only if the cables are loosely sandwiched. They're sandwiched in there tight. There will be no movement of the cable against the aluminum.
Dave
Kewl nicopress.
Diesel mounts and done is the usual solution.
Sure, if your engine makes stock levels of power. With any torque they deflect enough for the intake manifold bracketry to make all sorts of fun noises as it rubs on other things.
What side do these bolt up to on a stock b230f?I way exaggerated that price. I just looked, and they're only $1.75. Mid 80's Dodge D100 V8.
You could also use some Dodge pickup motor mounts, with 'failsafe' tabs:
They're like $5 on RockAuto. I ran one for a long while on the driver side of my 16VT drivetrain. Never broke it. Although I was using a ratchet strap as well.
EDIT: I way exaggerated that price. I just looked, and they're only $1.75. Mid 80's Dodge D100 V8.
If I had a welder and matching welding talent, I would make some great mounts all the way out to the frame rails, VERTICAL, not tilted, maybe using hydraulic mounts and they would likely do everything I wanted.
