the_hairy_baboon
- Dec 1, 2021
Getting the replacement part (#1276825) is easy: https://www.ipdusa.com/products/16450/Engine-Air-Filter-240-Turbo-Genuine-Volvo-1276825-125728
But what's the best method to actually replace it? At least on my B21FT there's the whole venturi / distributor on top. In theory if you disconnect any fuel line you should put new copper washers, and since there's a lot of injectors / fuel lines in/out then there's a lot of chance for leaks. But if I don't remove those then there's a limit to how far to the side I can push/pull the distributor out of the way. Can't seem to find a video on it period.
Should I first remove the rubber top thingy (#1346989) (on potentially both sides), then unclip distributor/venturi assembly, and that should give enough clearance to get the old filter out and a new one in?
